NSU-G16
NSU-G16
    TRIPPLITE
    PDUETHERNETSWITCH
NSU-G16 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 16-Port Gigabit Ethernet Switch with 8 Outlet PDU Highlights ● Combines a Basic PDU and an Unmanaged 16-Port Gigabit Ethernet Switch in only 1U or rack space ● Ideal for racks with limited space such as wall-mount racks ● 1.44kW 12A 120V Basic Power Distribution Unit (PDU) with 8 NEMA 5-15R AC outlets ● 16-port Gigabit Ethernet Switch, Auto-Negotiable, Plug-and-Play Functionality ● Low power consumption with Green Ethernet Technology MODEL NUMBER: NSU-G16 Package Includes Combines a Basic PDU and an Unmanaged 16-Port Gigabit Ethernet Switch in a single, space-saving 1U rack-mount design. Description Tripp Lite's NSU-G16 combines a 1.44kW single-phase 120V Basic Power Distribution Unit (PDU) with an Unmanaged 16-Port Gigabit Ethernet Switch for an all-in-one 1U rack-mount solution. It is perfect for racks in smaller, distributed networks where space is at a premium by providing both power and Ethernet connectivity in only 1U of rack space. The power distribution unit supplies continuous AC power from a connected UPS system or alternate source and contains 8 NEMA 5-15R outlets allowing you to power critical IT equipment. The Gigabit Ethernet Network Switch has 16 RJ45 ports that support autonegotiable 10/100/1000 Mbps and auto MDI/MDIX cross-over detection functions for true “plug and play” capability. Utilizing Green Ethernet technology, power consumption is automatically lowered by (i) turning off Ethernet ports not in use or connected to a shutdown computer, and (ii) detecting the connected network cable lengths to adjust the power usage to only what is necessary. Constructed of heavy-duty steel housing, the NSU-G16 has a rugged design built for years of reliable performance. Features Tripp Lite's NSU-G16 combines a 1.44kW single-phase 120V Basic Power Distribution Unit (PDU) with an Unmanaged 16-Port Gigabit Ethernet Switch for an all-in-one 1U rack-mount solution.Power Distribution Unit (PDU):1.44kW 12A 120V Basic Power Distribution Unit8 NEMA 5-15R AC outletsNEMA 5-15P input plug; 6 ft. line cord12 Amps Unmanaged Ethernet Switch:16 RJ45 Gigabit Ethernet portsAuto-negotiable 10/100/1000 Mbps Ethernet on all ports selects port speed automatically based on the capabilities of the clientAuto MDI/MDIX crossover detection provides true, plug-and-play functionality32 Gbps switching capacity at Full-DuplexStore-and-Forward switching method2Mb RAM for data buffering8K address MAC address tableSupports Jumbo Frames up to 9216 BytesPower ON/OFF LED illuminates to indicate that the switch is receiving powerRJ45 LED's Per Port (Left LED Blinks Green for Activity, Right LED is off for 10/100 Mbps speeds, and solid Green for 1000 Mbps)Compliant with IEEE 802.3ab (1000BASE-T GbE), IEEE 802.3u (100BASE-TX Fast Ethernet), IEEE 802.3i (10BASE-T Ethernet), IEEE 802.3x (Full Duplex/Flow Control), IEEE 802.3 (NWAY Auto-Negotiation), 802.3ac (VLAN) and 802.3az (Energy Efficient Ethernet) Power Management:Using Green Ethernet technology, energy efficiency is maximized by (i) turning off Ethernet ports not in use or connected to a shutdown computer and (ii) adjusting power usage relative to network cable lengths Rack-mount Configuration:1U Horizontal 19-inch rackmountConstructed of heavy-duty steel housing 1/4 ● NSU-G16 ● Rack-mount hardware ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Works with the Most Popular Web Browsers The NSU-G16 is browser-based and works independently from the connected computer's operating system. Because switch compatibility is based on common hardware standards, rather than system software dependencies, the NSU-G16 accommodates most platforms. Preferred web browsers include Google Chrome (on both Windows and macOS) and Microsoft Edge (Windows only). Specifications OVERVIEW UPC Code 037332184016 Product Type Switch/PDU Combination PDU Type Basic INPUT Electrical Consumption (Max) 10W Maximum Input Amps 12 PDU Plug Type NEMA 5-15P Voltage Compatibility (VAC) 120 Input Phase Single-Phase Input Plug Type NEMA 5-15P Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 OUTPUT Output Circuit Breakers 12A Output Receptacles (8) 5-15R POWER Power Consumption (Watts) 10 Power Consumption Detail PDU supports up to 12A total; Network switch consumes up to 10 watts USER INTERFACE, ALERTS & CONTROLS LED Indicators Power LED (Green for Power On), (x2) RJ45 LED's Per Port (Left LED Blinks Green for Activity, Right LED is off for 10/100 Mbps speeds, and solid Green for 1000 Mbps) PHYSICAL Primary Form Factor Rackmount Color Black Minimum Required Rack Depth (cm) 28.96 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Minimum Required Rack Depth (inches) 11.4 PDU Form Factor Horizontal (1U) Shipping Dimensions (hwd / in.) 4.40 x 12.40 x 21.00 Shipping Dimensions (hwd / cm) 11.18 x 31.50 x 53.34 Shipping Weight (lbs.) 7.40 Shipping Weight (kg) 3.36 Unit Dimensions (hwd / in.) 1.710 x 18.660 x 8.400 Unit Dimensions (hwd / cm) 4.34 x 47.4 x 21.34 Unit Weight (lbs.) 6 Unit Weight (kg) 2.72 Rack Units 1 ENVIRONMENTAL Storage Temperature Range 14 to 158 F (-10 to 70 C) Relative Humidity 5 to 95% RH, Non-Condensing Operating Temperature 32 to 104 F (0 to 40 C) COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) Network Compatibility Details Auto-negotiable Switching Capacity 32 Gbps Switching Capacity Details 2 Gbps per port with full duplex CONNECTIONS Number of Ports 16 RJ45 Ports 16 RJ45 Ports Detail 16x 10/100/1000BASE-T SFP Uplink Ports 0 PoE Supported Ports 0 Network Switch Ports (16) 10/100/1000 (RJ45) FEATURES & SPECIFICATIONS MAC Addresses 8000 Jumbo Frames 9000 Console Port No MAC Auto Learning No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States RMON No SNMP No Storm Control No DHCP Snooping No Auto MDI/MDIX Crossover Detection Yes STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 60950-1 (Canada); UL 60950-1 Product Compliance RoHS; IEEE 802.3 Auto-Negotiation; IEEE 802.3ab 1000Base-T; IEEE 802.3ac (VLAN); IEEE 802.3az (Energy Efficient Ethernet); IEEE 802.3i 10Base-T; IEEE 802.3u 100Base-TX/FX; IEEE 802.3x Flow Control; REACH; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
NSU-G16 价格&库存
很抱歉,暂时无法提供与“NSU-G16”相匹配的价格&库存,您可以联系我们找货
