NSU-G24C2
NSU-G24C2
    TRIPPLITE
    PDUETHERNETSWITCH
NSU-G24C2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 24-Port Gigabit Ethernet Switch with 12 Outlet PDU, 2 SFP Ports MODEL NUMBER: NSU-G24C2 Highlights ● Ideal for racks with limited space such as wall-mount racks ● 1.44kW 12A 120V Basic Power Distribution Unit (PDU) with 12 NEMA 5-15R AC outlets ● 24-port Gigabit Ethernet Switch, Auto-Negotiable, Plug-and-Play Functionality. ● 2 Combo SFP (Mini-GBIC) ports for uplink to other switches via optical fiber ● Low power consumption with Green Ethernet Technology Package Includes Combines a Basic PDU and an Unmanaged 24-Port Gigabit Ethernet Switch with 2 SFP uplink ports in a single, space-saving 1U rack-mount design. Description Tripp Lite's NSU-G24C2 combines a 1.44kW single-phase 120V Basic Power Distribution Unit (PDU) and an Unmanaged 24-Port Gigabit Ethernet Switch with 2 Combo SFP (Small Form-Factor Pluggable) uplink ports for an all-in-one 1U rack-mount solution. It is perfect for racks in smaller, distributed networks where space is at a premium by providing both power and Ethernet connectivity in only 1U of rack space. The power distribution unit supplies continuous AC power from a connected UPS system or alternate source and contains 12 NEMA 5-15R outlets allowing you to power critical IT equipment. The Gigabit Ethernet Network Switch has 24 RJ45 ports that support auto-negotiable 10/100/1000 Mbps and auto MDI/MDIX cross-over detection functions for true “plug and play” capability. Two Combo SFP ports can uplink to other switches using optical fiber. Utilizing Green Ethernet technology, power consumption is automatically lowered by (i) turning off Ethernet ports not in use or connected to a shutdown computer, and (ii) detecting the connected network cable lengths to adjust the power usage to only what is necessary. Constructed of heavy-duty steel housing, the NSU-G24C2 has a rugged design built for years of reliable performance. Features Power Distribution Unit (PDU):1.44kW 12A 120V Basic Power Distribution Unit12 NEMA 5-15R AC outletsNEMA 5-15P input plug; 6 ft. line cord12 Amps Unmanaged Ethernet Switch:24 RJ45 Gigabit Ethernet portsAuto-negotiable 10/100/1000 Mbps Ethernet on all ports selects port speed automatically based on the capabilities of the clientAuto MDI/MDIX crossover detection provides true, plug-and-play functionalityTwo SFP (Mini-GBIC) ports for uplinking to other switches using optical fiber. Each SFP port is shared with a RJ45 port. When the SFP port is active, the corresponding RJ-45 port will be disabled.48 Gbps switching capacity at FullDuplexStore-and-Forward switching method2Mb RAM for data buffering8K address MAC address tableSupports Jumbo Frames up to 9216 BytesPower ON/OFF LED illuminates to indicate that the switch is receiving powerRJ45 LED's Per Port (Left LED Blinks Green for Activity, Right LED is off for 10/100 Mbps speeds, and solid Green for 1000 Mbps)Compliant with IEEE 802.3ab (1000BASE-T GbE), IEEE 802.3u (100BASE-TX Fast Ethernet), IEEE 802.3i (10BASE-T Ethernet), IEEE 802.3x (Full Duplex/Flow Control), IEEE 802.3 (NWAY Auto-Negotiation), 802.3ac (VLAN) and 802.3az (Energy Efficient Ethernet) Power Management:Using Green Ethernet technology, energy efficiency is maximized by (i) turning off Ethernet ports not in use or connected to a shutdown computer and (ii) adjusting power usage relative to network cable lengths 1/4 ● NSU-G24C2 PDU Ethernet Switch 1U Combo ● Mounting hardware ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Rack-mount Configuration:1U Horizontal 19-inch rackmountConstructed of heavy-duty steel housing Works with the Most Popular Web Browsers The NSU-G24C2 is browser-based and works independently from the connected computer's operating system. Because switch compatibility is based on common hardware standards, rather than system software dependencies, the NSU-G24C2 accommodates most platforms. Preferred web browsers include Google Chrome (on both Windows and macOS) and Microsoft Edge (Windows only). Specifications OVERVIEW UPC Code 037332184009 Product Type Switch/PDU Combination PDU Type Basic INPUT Electrical Consumption (Max) 10W Maximum Input Amps 12 PDU Plug Type NEMA 5-15P Voltage Compatibility (VAC) 120 Input Phase Single-Phase Input Plug Type NEMA 5-15P Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 OUTPUT Output Circuit Breakers 12A Output Receptacles (12) 5-15R POWER Power Consumption (Watts) 10 Power Consumption Detail PDU supports up to 12A total; Network switch consumes up to 10 watts USER INTERFACE, ALERTS & CONTROLS LED Indicators Power LED (Green for Power On), (x2) RJ45 LED's Per Port (Left LED Blinks Green for Activity, Right LED is off for 10/100 Mbps speeds, and solid Green for 1000 Mbps) PHYSICAL Primary Form Factor Rackmount Color Black 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Minimum Required Rack Depth (cm) 28.96 Minimum Required Rack Depth (inches) 11.4 PDU Form Factor Horizontal (1U) Shipping Dimensions (hwd / in.) 4.40 x 12.50 x 21.40 Shipping Dimensions (hwd / cm) 11.18 x 31.75 x 54.36 Shipping Weight (lbs.) 7.60 Shipping Weight (kg) 3.45 Unit Dimensions (hwd / in.) 1.710 x 18.660 x 8.400 Unit Dimensions (hwd / cm) 4.34 x 47.4 x 21.34 Unit Weight (lbs.) 6.75 Unit Weight (kg) 3.06 Rack Units 1 ENVIRONMENTAL Storage Temperature Range 14 to 158 F (-10 to 70 C) Relative Humidity 5 to 95% RH, Non-Condensing Operating Temperature 32 to 104 F (0 to 40 C) COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) Network Compatibility Details Auto-negotiable Switching Capacity 48 Gbps Switching Capacity Details 2 Gbps per port with full duplex CONNECTIONS Number of Ports 24 RJ45 Ports 24 RJ45 Ports Detail 22x 10/100/1000BASE-T; 2x Combo RJ45/SFP SFP Uplink Ports 2 SFP Uplink Ports Detail 2x Combo Mini-GBIC SFP Uplinks PoE Supported Ports 0 Network Switch Ports (22) 10/100/1000 (RJ45); (2) Combo RJ45/SFP; Console (RJ45) FEATURES & SPECIFICATIONS MAC Addresses 8000 Jumbo Frames 9000 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Console Port No MAC Auto Learning No RMON No SNMP No Storm Control No DHCP Snooping No Auto MDI/MDIX Crossover Detection Yes STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 60950-1 (Canada); UL 60950-1 Product Compliance RoHS; IEEE 802.3 Auto-Negotiation; IEEE 802.3ab 1000Base-T; IEEE 802.3ac (VLAN); IEEE 802.3az (Energy Efficient Ethernet); IEEE 802.3i 10Base-T; IEEE 802.3u 100Base-TX/FX; IEEE 802.3x Flow Control; REACH; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
NSU-G24C2 价格&库存
很抱歉,暂时无法提供与“NSU-G24C2”相匹配的价格&库存,您可以联系我们找货
