76000660
76000660
    DIGIINTERNATIONAL
    HUB ETHERNET 1 PORT 802.3AF
76000660 数据手册
Product Data Sheet Digi EasyPower™ Accessory The Digi EasyPower family provides simple, safe and efficient device power over existing LAN data cabling (Ethernet). It is ideal for applications where power outlets are not available at the optimal device location. h itc Sw D Ea igi sy w Po Dig DIG DIGI > Each port has a replaceable fuse for recovery from power surge or lightning damage > Each port auto-detects the power requirement and offers transparent 10/100Mb operation > Each port is compatible with IEEE 802.3af > Includes a six-port model and a single-port model for powering small concentrations of IEEE 802.3af devices > Two-year warranty IO NE i e On Pr PL TS TS IA A eI n i O ort DigealP R Features/Benefits > Each port is current limited for short circuit protection with power isolation of 1KV between ports ONE er int er C Overview The Digi EasyPower provides a safe, efficient and simple way to power 802.3af devices without the use of an external power supply for each device. Power is supplied over the existing LAN data cabling system, allowing you to add power to the LAN without laying down new cables. In addition, it greatly improves the range of installation locations for Digi’s device servers, no longer requiring them to be located near a power outlet. For safety, Digi EasyPower has its own DC to DC converter that is voltage isolated from the other ports. Each module is separately fused and protected from any unexpected current surge. If a power surge should occur, either through a building’s electrical system or a lightning strike, the Digi EasyPower Hub takes the force and helps protect the valuable equipment attached to it. When used with an uninterruptible power supply, the Digi EasyPower device provides non-stop power for up to six connected devices. This eliminates the need for installing costly uninterruptible power supplies for each LAN device, saving time and extra expense. Continuous operation of powered LAN devices is assured, while costly downtime is avoided. Digi International, the leader in Connectware, makes device networking easy by developing products and technologies that are cost-effective and easy to use. With over 20 million ports shipped worldwide, Digi has been offering the highest levels of performance, flexibility and quality since 1985. ® Connectware™ www.digi.com Features/Specifications POWER REQUIREMENTS INTERFACES One or six female RJ-45 data ports • Shielded jacks for Category 5 UTP (two pair wire) or 100-ohm STP (two pair wire) • Distance: 100 meters One or six female RJ-45 data+power on Ethernet ports (Power over Ethernet) LED INDICATORS • • • • AC power input • Voltage: 100-240V autoranging (50Hz - 60Hz) • Connector: 3-pin with ground • Chassis grounding: yes • Power supply: one standard, optional dual load-sharing DC port power output • Power Enabling: IEEE 802.3af • Power pins: unused pairs, pins 4,5(+), 7,8(-) • Max. power/port: 20W (42V *0.35A max.) • Max power-all ports active: 20*20W = 400W • Port to port isolation: 1000V RMS • Overload protection: if current reaches 350mA to 500mA for greater than 100 milliseconds ENVIRONMENTAL • Operating temperature: 0˚ C to 40˚ C (32˚ F to 105˚ F) • Storage temperature: -10˚ C to 60˚ C (14˚ F to 140˚ F) • Relative humidity: 10% to 90% non-condensing • Operating altitude: -1,000 to 10,000 feet Detect (green) Fuse blown (yellow) Power from chassis (green) Power forwarding (green) DIMENSIONS Single Port • Length: 6.0 in (15.24 cm) • Width: 3.0 in (7.62 cm) • Depth: 1.0 in (2.54 cm) • Weight: 14.6 oz (0.41 kg) Six Port • Length: 14.0 in (35.56 cm) • Width: 10.0 in (25.40 cm) • Depth: 2.5 in (6.35 cm) • Weight: 6.0 lbs (2.7 kg) Six-Port Model WARRANTY 14" • Two-year warranty Single-Port Model 2.5" 10" Data port to Ethernet hub Data port to Digi product 6" 1" 3" MODEL......................PART NUMBERS Model North America Six-Port Model • Six power & data ports - IEEE 802.3af compliant 76000661 Single-Port Model • Single power & data port - IEEE 802.3af compliant 76000660 International 76000715 76000714 DIGI SERVICE AND SUPPORT You can purchase with confidence knowing that Digi is here to support you with expert technical support. Digi Internationa l 11001 Bren Road E. Minnetonka, MN 55343 USA PH: 877-912-3444 952-912-3444 FX: 952-912-4952 Email: info@digi.com www.digi.com Digi Internationa l GmbH Digi Internationa l (HK) Limited Joseph-von-Fraunhofer Str. 23 D-44227 Dortmund Germany PH: +49-231-9747-0 FX: +49-231-9747-111 www.digi.de Suite 1703-05, 17/F., K Wah Centre 191 Java Road North Point, Hong Kong PH: +852-2833-1008 FX: +852-2572-9989 www.digi.cn http://support.digi.com NetSilicon 411 Waverley Oaks Road #304 Waltham, MA 02452 USA PH: 800-243-2333, 781-647-1234 FX: 781-893-1338 Email: info@netsilicon.com www.netsilicon.com © 2003-2004 Digi International Inc. Digi, Digi International, the Digi logo, the Digi Connectware logo, Digi EasyPower and NetSilicon are trademarks or registered trademarks of Digi International, Inc. in the United States and other countries worldwide. All other trademarks are the property of their respective owners. 91001193 A2/704 ® Connectware™
76000660 价格&库存
很抱歉,暂时无法提供与“76000660”相匹配的价格&库存,您可以联系我们找货
  • 1+2163.362471+279.86396
