B130-101-U
B130-101-U
    TRIPPLITE
    VGA OVER CAT5 EXTENDER USB
B130-101-U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States VGA over Cat5/6 Extender Kit, Transmitter/Receiver for Video, USB Powered, Up to 500 ft. (152 m), TAA Highlights ● Extends a 1920 x 1440 (60Hz) signal up to 350-ft. (106.68 m), or a 1024 x 768 (60Hz) signal up to 500-ft. (152.4 m), when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6) ● USB-powered...no external AC power needed ● Built-in VGA dongles...no need for additional VGA cables ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B130-101-U System Requirements ● Computer with VGA graphics card ● Display monitor or projector with VGA Package Includes Allows VGA display devices to be connected up to 500 ft. away from the source computer, well beyond the standard VGA cable range. Description Tripp Lite's USB-powered VGA over Cat5 Extender Kit allows you to extend a 1920 x 1440 (60Hz) signal up to 350-ft. (106.68 m), or a 1024 x 768 (60Hz) signal up to 500-ft. (152.4 m), when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6). Ideal for digital signage applications, classroom or auditorium projectors, and more. Extender draws needed power from a USB connection at the computer...no external AC adapters required. Receiver unit includes Gain adjustment for brightness/darkness control, and Equalization adjustment for sharp, clear images. VGA "dongles" allow for direct attachment to video equipment...no additional VGA cables required. Kit includes a Transmitter with VGA and USB (power) pigtails, and a Receiver with VGA pigtail. Also included is a small adjustment screwdriver for the EQ and GAIN controls. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Features ● Extends a 1920 x 1440 (60Hz) signal up to 350-ft. (106.68 m), or a 1024 x 768 (60Hz) signal up to 500ft. (152.4 m), when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6) ● USB-powered...no external AC power needed ● Built-in VGA dongles...no need for additional VGA cables ● Built-in Equalization and Gain controls for the sharpest images ● Uses readily available Cat5e or Cat6 solid conductor cable ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332166593 1/4 ● VGA over Cat5 Transmitter ● VGA over Cat5 Receiver ● EQ and GAIN adjustment screwdriver 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Type Extender Kit Technology VGA/SVGA; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920x1440 @ 60Hz Max 720P Range (ft) 350 Max 1080P Range (ft) 350 Max 1280 x 720 (720p) Range (ft) 350 Max 1920 x 1080 (1080p) Range (ft) 350 Max 1920 x 1200 Range (ft) 350 Transmitter Video Input VGA Transmitter - Number of Video Outputs 1 Receiver/Transceiver Video Output VGA Receiver - Number of Video Outputs 1 Range Extension using other Tripp Lite product 1000ft @ 1024 x 768 (60Hz) 500ft @ 1920 x 1440 (60Hz) Recommended Cabling Solid Wire Cat6 Cables (Tripp Lite's N202-Series) Other Tripp Lite product used to extend range B132-110A HDR Support No 3D Video Supported No Maximum Signal Range (ft) 500 Maximum Signal Range (m) 152 Maximum Signal Range Details 500 ft @ 1024 x 768 (60Hz)350 ft @ 1920 x 1440 (60Hz) INPUT Bus Powered No POWER Power Source Type USB Power Source Transmitter end only (Included) Power Over Cable (PoC) Support No USER INTERFACE, ALERTS & CONTROLS LED Indicators TX & RX: Green = Power; Orange = Signal Transmission PHYSICAL Color Black 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Number of Displays 1 Form Factor/Mounting Options Pigtail Receiver Unit Dimensions (hwd / in.) 2.4 x 0.94 x 2.04 Receiver Unit Weight (lbs.) 0.15 Shipping Dimensions (hwd / in.) 1.70 x 7.90 x 5.60 Shipping Dimensions (hwd / cm) 4.32 x 20.07 x 14.22 Shipping Weight (lbs.) 0.44 Shipping Weight (kg) 0.20 Transmitter Unit Dimensions (hwd / in.) 2.4 x 0.94 x 2.04 Transmitter Unit Weight (lbs.) 0.15 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Housing Plastic ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Relative Humidity 10% to 90% RH, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 500 Max 480P Range (ft) 500 Max 1440 x 900 Range (ft) 350 Max 1080i Range (ft) 350 Max 480i Range (ft) 500 Max 640 x 480 Range (ft) 500 Max 800 x 600 Range (ft) 500 Max 1600 x 1200 Range (ft) 350 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported No USB Extension Support No CONNECTIONS 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Number of Ports 1 Side A - Connector 1 HD15 (MALE) Side A - Connector 2 RJ45 (FEMALE) Side A - Connector 3 USB A (MALE) Side B - Connector 1 HD15 (MALE) Side B - Connector 2 RJ45 (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer Yes STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B130-101-U 价格&库存
很抱歉,暂时无法提供与“B130-101-U”相匹配的价格&库存,您可以联系我们找货
