for DEVELOPERS
ENDLESS POSSIBILITIES with CloudGate
• Build your own expansion card
• Develop software to meet your requirements
• As simple or full featured as you need it to be
for DEVE LOPERS
ENDLESS
POSSIBILITIES
with CloudGate
Flexibility is built into CloudGate’s design. CloudGate’s extensive range of tools for developers puts the power in
your hands to adapt and tailor CloudGate to your specific solution while benefiting from a secure, stable and
reliable gateway platform.
The CloudGate Breadboard Card and Development Card allow you to quickly develop and prototype
your solution. The Breadboard Card provides an ‘in form factor’ solution for small prototype runs while the
Development card allows quick software prototyping with CloudGate’s multiple different interfaces.
for software developer
Breadboard card
for hardware developer
• Extended format card with headers for all interfaces
• Includes headers for access to USB, USB on the go, RS-232, I2C, SPI/SD
and GPIO lines.
• On board temperature sensor, relay, SD card slot and RS232 serial port
• Ideal for prototyping your own expansion card
• Fits in the front expansion slot of the CloudGate
• Supports 3 types of connections:
–– All signals on the back connector can be tapped off on breadboard area
near this connector
–– 2.54mm pitch components can be soldered on main breadboard area
–– 3.5mm pitch connectors can be soldered on front two rows to provide a
more reliable and longterm connection
• Adapter boards are available online to integrate fine-pitch components (see
www.breadboard‑adapters.com)
Software Development Kit
Hardware Development Kit
The CloudGate software development kit is available free of charge via CloudGate Universe at
cloudgate.option.com. The software development kit includes a full toolchain that allows native
applications to be built for CloudGate along with an extensive API that gives access to all the device
management, provisioning and networking functions of the CloudGate.
The CloudGate hardware developer’s kit includes all
the schematics and specifications necessary for you to
build your own CloudGate accessory card. By building
your own card you can tailor CloudGate to the specifics
of your solution. Option actively markets our partner
solutions to our customers worldwide.
Since CloudGate is based on the open source routing platform OpenWrt many open source
packages are already available for CloudGate and can be quickly and simply built with your
software. The CloudGate SDK build system produces signed CloudGate software image files that
can be provisioned locally or via CloudGate Universe.
As part of the continual product improvement process, OPTION reserves the right to alter the specifications of this product.
© 2014 OPTION. Option and the Option logo are registered trademarks of OPTION. All third-party trademarks are the property of the respective owners.
Option nv - Gaston Geenslaan 14 - 3001 Leuven Belgium - T +32 16 317 411 - F +32 16 207 164
1. Create a free
developer account
2. Develop, test
& debug
www.option.com
3. Deploy your
development
DataSheet_v1.2
Developer card
很抱歉,暂时无法提供与“CG1108-11980”相匹配的价格&库存,您可以联系我们找货
