1000 Eaton Boulevard
Cleveland, OH 44122
United States
DVI Signal Booster / Extender, Dual-Link,
2560x1600 60Hz, up to 150 ft. (45 m), (DVI F/F),
TAA
Highlights
Extend a DVI-D Dual Link signal
up to 150-ft. (45.72 m) from the
source
Use P560-Series DVI Dual-Link
cables in most applications.
When extending a 2560 x 1600
video signal more than 75-ft.
(22.86 m), use cable made with
24Awg wiring
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
MODEL NUMBER: B120-000
Package Includes
Description
Tripp Lite's B120-000 DVI Dual Link Signal Extender increases the distance a DVI-D signal can be
transmitted beyond the recommended 16-ft. (4.88 m). It supports video resolutions up to 2560 x 1600 @
60Hz, and a maximum distance of 150-ft. (45.72 m) from the source. Use P560-Series DVI Dual-Link
cables in most applications. When extending a 2560 x 1600 video signal more than 75-ft. (22.86 m), use
cable made with 24Awg wiring. (Available from Tripp Lite as a custom order) Simply connect the longer
cable between the source and the B120-000, and the shorter cable (16-ft. (4.88 m) or less) between the
adapter and the monitor. Software or drivers are not required. Built-in Equalization control to adjust the
video image. HDCP and DDC compatible. Compliant with the Federal Trade Agreements Act (TAA) for
GSA Schedule purchases.
Features
Extend a DVI-D Dual Link signal up to 150-ft. (45.72 m) from the source
Supports a maximum video resolution of 2560 x 1600 @ 60Hz
Use P560-Series DVI Dual-Link cables in most applications
When extending a 2560 x 1600 video signal more than 75-ft. (22.86 m), use a cable made with 24Awg
wiring (Available from Tripp Lite as a custom order)
Built-in Equalization control to adjust the video image
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332130297
Product Type
Signal Booster
1/4
Extender
External Power Supply with
NEMA 1-15P Plug ( Input: 100240V, 50/60Hz, 0.5A; Output:
5V, 2A)
Screwdriver for Equalization
adjustment
Owner's Manual
Cleveland, OH 44122
United States
Technology
DVI
Host Connector
DVI-I DUAL LINK (FEMALE)
VIDEO
Video Input
Video Output
Resolutions Supported
Extend a 2560 x 1600 @ 60Hz signal up to 150 ft. using 24Awg cable; Extend a 2560 x 1600 @ 60Hz signal up to
100 ft. using 28Awg cable
Supported Resolutions
2560x1600
Max Supported Video Resolution
2560x1600 @ 60Hz
Max 720P Range (ft)
150
Max 1080P Range (ft)
150
Max 1280 x 720 (720p) Range (ft)
150
Max 1920 x 1080 (1080p) Range (ft)
150
Max 1920 x 1200 Range (ft)
150
Max 2560 x 1600 Range (ft)
150
Signal Range (ft)
150
Signal Range (m)
45
Recommended Cabling
P560-Series
HDR Support
No
3D Video Supported
Yes
Maximum Signal Range (ft)
150
Maximum Signal Range (m)
46
Maximum Signal Range Details
150 ft via 24 AWG Cable100 ft via 28 AWG Cable
INPUT
Voltage Compatibility (VAC)
100; 110; 120; 125; 127; 200; 208; 220; 230; 240
Bus Powered
No
Product Length (in.)
2.4
Product Length (cm.)
6.1
Product Length (ft.)
0.2
Product Length (m.)
0.061
POWER
Power Source Type
AC Adapter
External Power Supply Plug(s)
NEMA 1-15P North America
2/4
Cleveland, OH 44122
United States
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 0.5A
External Power Supply Output
Specs (V / A)
5V / 2A
External Power Supply Cord Length
(ft.)
4.5
(m.)
1.4
AC Plug Type
NEMA 1-15P
Power Source
Unit (Included)
Power Over Cable (PoC) Support
No
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A
DC Barrel Plug
OD: 5.5 x 2.1 x 12mm, Positive Pin, Negative Sleeve
PHYSICAL
Color
Black
Material of Construction
Plastic
Number of Displays
1
Form Factor/Mounting Options
Box
Shipping Dimensions (hwd / in.)
7.00 x 6.40 x 2.20
Shipping Dimensions (hwd / cm)
17.78 x 16.26 x 5.59
Shipping Weight (lbs.)
0.53
Shipping Weight (kg)
0.24
Unit Dimensions (hwd / in.)
2.400 x 2.040 x 0.940
Unit Packaging Type
Box
Unit Weight (lbs.)
0.1
Unit Weight (kg)
0.05
Housing
Plastic
ENVIRONMENTAL
Operating Temperature Range
32 to 104°F (0 to 40°C)
Storage Temperature Range
14 to 158 F (-10 to 70 C)
Relative Humidity
0% to 85%, Non-Condensing
COMMUNICATIONS
Max 1024 x 768 Range (ft)
150
Max 480P Range (ft)
150
Max 1440 x 900 Range (ft)
150
3/4
Cleveland, OH 44122
United States
Max 1080i Range (ft)
150
Max 1920 x 1440 Range (ft)
150
Max 480i Range (ft)
150
Max 640 x 480 Range (ft)
150
Max 800 x 600 Range (ft)
150
Max 1600 x 1200 Range (ft)
150
Max 2048 x 1536 Range (ft)
150
EDID Compatible
Yes
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
Yes
USB Extension Support
No
CONNECTIONS
Number of Ports
2
Side A - Connector 1
Side B - Connector 1
FEATURES & SPECIFICATIONS
Driver Required
No
10/100 Ethernet Extension Support
No
Built-In Equalizer
Yes
STANDARDS & COMPLIANCE
External Power Supply Certifications
FCC; PSE; TUV; UL; cUL
Product Compliance
RoHS; REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“B120-000”相匹配的价格&库存,您可以联系我们找货
