B136-101
B136-101
    TRIPPLITE
    VIDEO/AUDIOEXTENDER700FT
B136-101 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Component Video with Stereo Audio over Cat5/Cat6 Extender Kit, In-Line Transmitter and Receiver, Up to 700 ft. (213 m) Highlights ● Comes with both local and remote units ● Extends a 1080i (60Hz) Component Video and Stereo Audio signal up to 300-ft. (91.44 m) when using 24Awg, Solid Wire UTP cable (Tripp Lite N202-Series); or, up to 400-ft. (121.92 m) when using ZeroSkew UTP cable (Tripp Lite P524-01K) ● No External Power required MODEL NUMBER: B136-101 Package Includes Description Tripp Lite's B136-101 Component Video + Stereo Audio extender kit comes with both local and remote units, allowing you to place a TV, Projector, etc, up to 700-ft. (213.36 m) away from the source. A 1080i (60Hz) Component Video and Stereo Audio signal can be extended up to 300-ft. (91.44 m) when using 24Awg, Solid Wire UTP cable (Tripp Lite N202-Series); or, up to 400-ft. (121.92 m) when using Zero-Skew UTP cable (Tripp Lite P524-01K). A 480p (60Hz) Component Video and Stereo Audio signal can be extended up to 500-ft. (152.4 m) when using 24Awg, Solid Wire UTP cable (Tripp Lite N202-Series); or, up to 700-ft. (213.36 m) when using Zero-Skew UTP cable (Tripp Lite P524-01K). Built-in RCA connectors plug directly into the source and display, without the need for additional cables....no power required. Please note: Left and Right channel audio are combined on the transmitter end for one complete sound. Features ● Comes with both local and remote units ● Built-in RCA connectors plug directly into the source and display, without the need for additional cables ● Extends a 1080i (60Hz) Component Video and Stereo Audio signal up to 300-ft. (91.44 m) when using 24Awg, Solid Wire UTP cable (Tripp Lite N202-Series); or, up to 400-ft. (121.92 m) when using ZeroSkew UTP cable (Tripp Lite P524-01K) ● No external power required Specifications OVERVIEW UPC Code 037332155467 Product Type Extender Kit Technology Component; Stereo Audio; Cat5/5e; Cat6 1/4 ● B136-101 Component Video + Stereo Audio Extender Kit ( 2pc ) ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States VIDEO Max Supported Video Resolution 1920x1080 (1080i @ 60Hz) Max 720P Range (ft) 400 Max 1280 x 720 (720p) Range (ft) 328 Transmitter Video Input Component (RCA) Transmitter - Number of Video Outputs 1 Receiver/Transceiver Video Output Component (RCA) Receiver - Number of Video Outputs 1 Recommended Cabling P524-01K HDR Support No 3D Video Supported Yes Maximum Signal Range (ft) 700 Maximum Signal Range (m) 213 AUDIO Audio Input RCA (x2) Stereo Audio Output RCA (x2) Stereo Audio Specification Stereo Audio INPUT Bus Powered No POWER Power Over Cable (PoC) Support No PHYSICAL Color Black Number of Displays 1 Form Factor/Mounting Options Pigtail Receiver Unit Dimensions (hwd / in.) 2.42 x 1.95 x 1.0 Receiver Unit Weight (lbs.) 0.1 Shipping Dimensions (hwd / in.) 2.00 x 4.80 x 5.30 Shipping Dimensions (hwd / cm) 5.08 x 12.19 x 13.46 Shipping Weight (lbs.) 0.40 Shipping Weight (kg) 0.18 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Transmitter Unit Dimensions (hwd / in.) 2.42 x 1.95 x 1.0 Transmitter Unit Weight (lbs.) 0.1 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Housing Plastic ENVIRONMENTAL Operating Temperature Range 32 to 104°F (0 to 40°C) Storage Temperature Range 14 to 158 F (-10 to 70 C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 400 Max 480P Range (ft) 700 Max 1440 x 900 Range (ft) 400 Max 1080i Range (ft) 400 Max 480i Range (ft) 700 Max 640 x 480 Range (ft) 700 Max 800 x 600 Range (ft) 450 Max 1600 x 1200 Range (ft) 350 EDID Compatible No IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported No USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 (5) RCA (MALE) Side A - Connector 2 RJ45 (FEMALE) Side B - Connector 1 (5) RCA (MALE) Side B - Connector 2 RJ45 (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS Driver Required No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B136-101 价格&库存
很抱歉,暂时无法提供与“B136-101”相匹配的价格&库存,您可以联系我们找货
