1000 Eaton Boulevard
Cleveland, OH 44122
United States
VGA over Cat5/6 Extender, Box-Style Receiver
for Video, Up to 1000 ft. (305 m), TAA
Highlights
Works with a B132-002-2 or
B132-004-2 local transmitter unit
to extend a 1920 x 1440 (60Hz)
video signal up to 500 ft., or a
1024 x 768 (60Hz) video signal
up to 1,000 ft.
24Awg, Solid Wire Cat5e/6
cable, such as Tripp Lite's
N022-01K-GY (Cat5) and N22201K-GY (Cat6), is required to
achieve maximum distance and
resolution
For optimal image quality
between 500 and 1,000 ft., use
Zero-Skew cable, such as Tripp
Lite P524-01K
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
MODEL NUMBER: B132-100-1
System Requirements
Features
Package Includes
Works with a B132-002-2 or B132-004-2 local transmitter unit to extend a 1920 x 1440 (60Hz) video
signal up to 500 ft., or a 1024 x 768 (60Hz) video signal up to 1,000 ft.
24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6),
is required to achieve maximum distance and resolution
For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P52401K
Features built-in Equalization and Gain controls to adjust the video image
Includes mounting hardware that allows unit to be wallmounted, rackmounted or pole mounted
Ideal for digital signage situations, such as retail, schools, churches, etc..
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
1 year limited waranty.
Specifications
OVERVIEW
UPC Code
037332160126
Product Type
Receiver
Technology
VGA/SVGA; Cat5/5e; Cat6
VIDEO
Max Supported Video Resolution
1920x1440 @ 60Hz
Max 720P Range (ft)
500
Max 1080P Range (ft)
500
1/4
Extender remote (Receiver) unit
Mini-Screwdriver for EQ/Gain
adjustment
Mounting Hardware
External Power Supply with
NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output:
5V, 2A, 5 ft.)
Owner’s Manual
Cleveland, OH 44122
United States
Max 1280 x 720 (720p) Range (ft)
500
Max 1920 x 1080 (1080p) Range (ft)
500
Max 1920 x 1200 Range (ft)
500
Receiver/Transceiver Video Output
VGA
Receiver - Number of Video Outputs
1
Range Extension using other Tripp
Lite product
1000ft @ 1024 x 768 (60Hz) 500ft @ 1920 x 1440 (60Hz)
Recommended Cabling
Solid Wire Cat6 Cables (Tripp Lite's N202-Series)
Other Tripp Lite product used to
extend range
B132-110A
HDR Support
No
3D Video Supported
No
Maximum Signal Range (ft)
1000
Maximum Signal Range (m)
305
Maximum Signal Range Details
1000 ft @ 1024 x 768 (60Hz)500 ft @ 1920 x 1440 (60Hz)
INPUT
Bus Powered
No
POWER
Power Source Type
AC Adapter
External Power Supply Plug(s)
NEMA 1-15P North America
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 0.5A
External Power Supply Output
Specs (V / A)
5V / 2A
External Power Supply Cord Length
(ft.)
4.5
(m.)
1.38
AC Plug Type
NEMA 1-15P
Power Source
Unit (Included)
Power Over Cable (PoC) Support
No
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft.
DC Barrel Plug
OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Red (Power); RJ45: Green (Connection), Orange (Data Transmission)
PHYSICAL
2/4
Cleveland, OH 44122
United States
Color
Black
Included Mounting Accessories
Wallmount
Number of Displays
1
Optional Mounting Accessory Notes
Can DIN Mount using Tripp Lite Bracket B110-DIN-02
Form Factor/Mounting Options
Box; Wall-mount
Shipping Dimensions (hwd / in.)
2.20 x 7.20 x 6.50
Shipping Dimensions (hwd / cm)
5.59 x 18.29 x 16.51
Shipping Weight (lbs.)
1.00
Shipping Weight (kg)
0.45
Unit Dimensions (hwd / in.)
1.000 x 2.500 x 3.600
Unit Dimensions (hwd / cm)
2.54 x 6.35 x 9.14
Unit Packaging Type
Box
Unit Weight (lbs.)
0.45
Unit Weight (kg)
0.20
Housing
Metal
ENVIRONMENTAL
Operating Temperature Range
32 to 122 F (0 to 50 C)
Storage Temperature Range
-4 to 158 (-20 to 70 C)
Relative Humidity
10% to 90% RH, Non-Condensing
COMMUNICATIONS
Max 1024 x 768 Range (ft)
1000
Max 480P Range (ft)
1000
Max 1440 x 900 Range (ft)
500
Max 1080i Range (ft)
500
Max 1920 x 1440 Range (ft)
500
Max 480i Range (ft)
1000
Max 640 x 480 Range (ft)
1000
Max 800 x 600 Range (ft)
1000
Max 1600 x 1200 Range (ft)
500
EDID Compatible
Yes
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
No
3/4
Cleveland, OH 44122
United States
USB Extension Support
No
CONNECTIONS
Number of Ports
1
Side A - Connector 1
RJ45 (FEMALE)
Side B - Connector 1
HD15 (FEMALE)
FEATURES & SPECIFICATIONS
Driver Required
No
10/100 Ethernet Extension Support
No
Built-In Equalizer
Yes
STANDARDS & COMPLIANCE
External Power Supply Certifications
FCC; PSE; TUV; UL; cUL
Product Compliance
RoHS; REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“B132-100-1”相匹配的价格&库存,您可以联系我们找货
