1000 Eaton Boulevard
Cleveland, OH 44122
United States
3-Port HDMI Switch for Video and Audio,
1920x1200 at 60Hz/1080p (HDMI F/3xF) with
Remote Control
MODEL NUMBER: B119-003-1
Highlights
Connect up to three HDMI
peripherals to one HDTV
Easily switch between devices
with remote control
Display HD video resolutions up
to 1080p, and computer video
resolutions up to 1920 x 1200
System Requirements
HDMI-enabled TV or peripheral
devices
Package Includes
Description
Tripp Lite's 3-to-1 HDMI switch allows you to effortlessly switch between three HDMI video source devices
such as HD satellite box, HD-DVD, Sony PS3, etc., to one HDTV. The unit supports 1.65Gbps signal
rates. Display HD video resolutions up to 1080p, and computer video resolutions up to 1920 x 1200.
Switch between devices with either a pushbutton on the unit or the included remote control. Supports both
audio and video digital signals as well as High-Speed HDMI v1.3 and 3D. HDCP v1.3 and EDID
compatible. 1-year limited warranty.
Features
Switch between three HDMI source devices connected to a single port on a monitor
Switch devices via pushbutton or the included remote control
Extend the range of the included remote control using a B119-000-REC IR receiver unit (sold
separately), allowing you to locate the B119-003-1 out of sight while still being able to switch devices
using the remote
Supports up to 36-bit Deep Color (12-bits per channel)
Supports DTS-HD, Dolby True HD and 7.1 Channel Surround Sound audio
Supports High-Speed HDMI v1.3 and 3D
HDCP v1.3 and EDID compatible
Plug and play; No software or drivers required
Specifications
OVERVIEW
1/3
B119-003-1 HDMI Switch
Remote Control
External Power Supply with
NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output:
5V, 1.2A, 4.9 ft.)
Owner’s Manual
Cleveland, OH 44122
United States
UPC Code
037332181084
Technology
HDMI; IR
VIDEO
Max Supported Video Resolution
1080p @60Hz
Max Supported Color Depth
12-bit
3D Video Supported
Yes
AUDIO
Audio Specification
7.1 Surround Sound, Dolby True HD, DTS-HD, DSD
INPUT
Voltage Compatibility (VAC)
100; 110; 120; 127; 200; 208; 220; 230; 240
POWER
External Power Supply Plug(s)
NEMA 1-15P North America
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 0.8A
External Power Supply Output
Specs (V / A)
5V / 1.2A
External Power Supply Cord Length
(ft.)
5
(m.)
1.5
DC Barrel Plug
OD: 5.5 x 2.1 x 10mm, Positive Pin, Negative Sleeve
Power Consumption (Watts)
6
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Green (Power, Output, Input 1, Input 2, Input 3)
PHYSICAL
Color
Black
Material of Construction
Steel
Shipping Dimensions (hwd / in.)
2.00 x 8.00 x 6.00
Shipping Dimensions (hwd / cm)
5.08 x 20.32 x 15.24
Shipping Weight (lbs.)
1.10
Shipping Weight (kg)
0.50
Unit Dimensions (hwd / in.)
0.900 x 4.400 x 3.000
Unit Dimensions (hwd / cm)
2.4 x 11.1 x 7.5
Unit Packaging Type
Box
2/3
Cleveland, OH 44122
United States
Unit Weight (lbs.)
0.9
Unit Weight (kg)
0.41
ENVIRONMENTAL
Operating Temperature Range
32 to 104 F (0 to 40 C)
Storage Temperature Range
-4 to 158 F (-20 to 70 C)
Relative Humidity
5% to 90% RH, Non-Condensing
BTUs
20.5 BTU/Hr
COMMUNICATIONS
EDID Compatible
Yes
IR Remote Extension Support
Yes
Consumer Electronics Control (CEC)
Supported
Yes
CONNECTIONS
Number of Ports
3
Side A - Connector 1
(3) HDMI (FEMALE)
Side B - Connector 1
HDMI (FEMALE)
Connector Plating
Gold
FEATURES & SPECIFICATIONS
HDCP Specification
1.4
Driver Required
No
STANDARDS & COMPLIANCE
External Power Supply Certifications
CE; FCC; UL; RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“B119-003-1”相匹配的价格&库存,您可以联系我们找货
