1000 Eaton Boulevard
Cleveland, OH 44122
United States
Although most installations will not require power, a Micro USB port is provided in the event power is
needed. Using a Micro USB cable(such as Tripp Lite's UR05C-Series), connect the Micro USB port to a
Highlights
Extend a 1080p @ 24Hz (or
1920 x 1200) HDMI signal up to
150-ft. (45.72 m) from the
source
When extending a 1080p @
24Hz (or 1920 x 1200) signal
more than 75-ft. (22.86 m), use
cable made with 24Awg wiring,
such as the P568-100-HD
No external power required in
most installations
24Awg HDMI cable is also
needed when extending a 3D
signal more than 50-ft. (15.24
m). A 3D signal can be
extended up to 125-ft. (38.1 m)
using 24Awg HDMI cable
Supports DTS-HD, Dolby True
HD and 7.1 Channel Surround
Sound Audio
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
USB wall charger, the USB port on your monitor, or the USB port on a computer.
HDMI Signal Booster / Extender, 1920 x 1200
(1080p) 24Hz, Up to 150 ft. (45 m), (HDMI
F/F),TAA
MODEL NUMBER: B122-000
Package Includes
Description
Tripp Lite's B122-000 HDMI Signal Extender increases the distance a 1080p @ 24Hz (or 1920 x 1200)
signal can be transmitted beyond the recommended 16-ft. (4.88 m). It supports computer video
resolutions up to 1920 x 1200, and HD resolutions up to 1080p @ 24Hz, as well as a maximum distance
of 150-ft. (45.72 m) from the source. Use P568-Series HDMI cables in most applications. When extending
a 1080p @ 24Hz (or 1920 x 1200) signal more than 75-ft. (22.86 m), use cable made with 24Awg wiring,
such as the P568-100-HD. (Lengths over 100-ft. (30.5 m) are available from Tripp Lite as a custom order)
24Awg HDMI cable is also needed when extending a 3D signal more than 50-ft. (15.24 m). A 3D signal
can be extended up to 125-ft. (38.1 m) using 24Awg HDMI cable. Simply connect the longer cable
between the source and the B122-000, and the shorter cable (16-ft. (4.88 m) or less) between the adapter
and the monitor. Software or drivers are not required. HDCP compliant. Compatible with the Federal
Trade Agreements Act (TAA) for GSA Schedule purchases.
Features
Extend a 1080p @ 24Hz (or 1920 x 1200) HDMI signal up to 150-ft. (45.72 m) from the source
When extending a 1080p @ 24Hz (or 1920 x 1200) signal more than 75-ft. (22.86 m), use cable made
with 24Awg wiring, such as the P568-100-HD. (Lengths over 100-ft. (30.5 m) are available from Tripp
Supports DTS-HD, Dolby True HD and 7.1 Channel Surround Sound Audio
HDCP compliant
No software or drivers required
No external power required in most installations
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
1/5
Extender
Owner's Manual
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332133144
Product Type
Signal Booster
Technology
HDMI
VIDEO
Video Input
HDMI (FEMALE)
Video Output
HDMI (FEMALE)
Number of Monitors Supported
1
Video Ports
HDMI (FEMALE)
Video Ports Details
HDMI 1.4; HDCP 1.4
Resolutions Supported
1920 x 1200 (1080p) @ 24Hz, up to 150 ft.
Max Supported Video Resolution
1920x1200 @ 24Hz
Max 720P Range (ft)
150
Max 1080P Range (ft)
150
Max 1280 x 720 (720p) Range (ft)
125
Max 1920 x 1080 (1080p) Range (ft)
125
Max 1920 x 1200 Range (ft)
125
Signal Range (ft)
150
Signal Range (m)
45.72
Recommended Cabling
24 AWG
Max Supported Color Depth
24-bit True Color
HDR Support
No
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
Maximum Signal Range (ft)
150
Maximum Signal Range (m)
46
Maximum Signal Range Details
AUDIO
Audio Ports
HDMI (FEMALE)
Audio Ports Details
HDMI (Female) port allows for pass-through audio
Audio Input
HDMI
2/5
Cleveland, OH 44122
United States
Audio Output
HDMI
Audio Specification
Pass-through audio
INPUT
Bus Powered
No
Product Length (in.)
2.362
Product Length (cm.)
6
Product Length (ft.)
0.197
Product Length (m.)
0.06
POWER
Power Source Type
USB
Power Source
Unit (Optional)
Power Over Cable (PoC) Support
No
PHYSICAL
Color
Black
Material of Construction
PC (Plastic)
Included Mounting Accessories
No
Number of Displays
1
Form Factor/Mounting Options
Box
Shipping Dimensions (hwd / in.)
1.30 x 6.14 x 4.80
Shipping Dimensions (hwd / cm)
3.30 x 15.60 x 12.19
Shipping Weight (lbs.)
0.03
Shipping Weight (kg)
0.01
Unit Dimensions (hwd / in.)
2.360 x 0.600 x 1.020
Unit Packaging Type
Box
Unit Weight (lbs.)
0.03
Unit Weight (kg)
0.01
Housing
Plastic
ENVIRONMENTAL
Operating Temperature Range
32 to 104 °F (0 to 40 °C)
Storage Temperature Range
5 to 122 °F (-15 to 50 °C)
Relative Humidity
0% to 85% RH, Non-Condensing
COMMUNICATIONS
3/5
Cleveland, OH 44122
United States
Max 1024 x 768 Range (ft)
150
Signal Range (ft.)
150
Signal Range (m)
46
Max 480P Range (ft)
153
Max 1440 x 900 Range (ft)
150
Max 1080i Range (ft)
150
Max 480i Range (ft)
153
Max 640 x 480 Range (ft)
150
Max 800 x 600 Range (ft)
150
Max 1600 x 1200 Range (ft)
150
EDID Compatible
Yes
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
Yes
USB Extension Support
No
CONNECTIONS
Number of Ports
1
Side A - Connector 1
HDMI (FEMALE)
Side A - Connector 2
MICRO-USB B (FEMALE)
Side B - Connector 1
HDMI (FEMALE)
FEATURES & SPECIFICATIONS
HDCP Specification
1.4
Driver Required
No
10/100 Ethernet Extension Support
No
Built-In Equalizer
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
4/5
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“B122-000”相匹配的价格&库存,您可以联系我们找货
