B140-1A0-WP-1
B140-1A0-WP-1
    TRIPPLITE
    DVIOVERCAT5/6EXTENDERVIDEOW
B140-1A0-WP-1 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DVI over Cat5/6 Extender, Wall Plate Receiver for Video, DVI-I Single Link, RJ45, Up to 200 ft. (60 m) MODEL NUMBER: B140-1A0-WP-1 Highlights ● Supports video resolutions up to 1920 x 1080, including 1080p ● Easy RJ45 connector on wallplate back ● Built-in equalization control for image adjustment ● Compatible with all major operating systems ● Plug and play—no software or drivers to download System Requirements Package Includes Receiver wallplate extends a DVI-D single-link signal via one Cat5e/6 patch cable up to 200 ft. with a Tripp Lite B140-002 or B140-004 extender/splitter transmitter unit (sold separately). Description The B140-1A0-WP-1 DVI over Cat5/6 Extender works in tandem with Tripp Lite's B140-002 or B140-004 extender/splitter transmitter unit (sold separately) to extend a DVI-D single-link signal over a single Cat5e/6 patch cable. It can extend a 1920 x 1080 (@ 60 Hz) signal up to 150-ft. (45.72 m) and a 1024 x 768 signal (@ 60 Hz) up to 200-ft. (60.96 m). It's ideal for digital sign applications in schools, churches, trade shows, retail settings and anywhere else a high-resolution DVI signal needs to be delivered over a long distance. Just connect a B140-002 or B140-004 transmitter to the DVI source using a DVI cable, such as Tripp Lite's P561-Series. Connect the B140-1A0-WP-1 to the transmitter using a Cat5e/6 cable (for best results, we recommend Tripp Lite N202-Series 24 AWG solid-wire Cat5e/6 cable) and connect to the display using a DVI cable. To expand the range and the number of displays, add up to three B140-110 remote repeaters and an active receiver to each channel for a total of four displays per channel. A 1920 x 1080 (@ 60 Hz) signal can be extended up to 125-ft. (38.1 m) to the next unit in the chain, and a 1024 x 768 signal (@ 60 Hz) up to 175-ft. (53.34 m). The B140-1A0-WP-1 works with all operating systems. Its plug-and-play technology means no software or drivers need to be downloaded and installed. Built-in equalization control allows for manual adjustment of the video image. Complies with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Features Extend DVI-D Signal via Cat5e/6 Patch Cable Up to 200-ft. (60.96 m) ● Ideal for digital sign applications in schools, churches, trade shows and retail settings ● Works in tandem with Tripp Lite B140-002 or B140-004 extender/splitter transmitters (sold separately) ● Extends a 1920 x 1080 (@ 60 Hz) signal up to 150-ft. (45.72 m) ● Extends a 1024 x 768 signal (@ 60 Hz) up to 200-ft. (60.96 m) Even More Distance and Flexibility ● Add up to 3 B140-110 remote repeaters and an active receiver for total of 4 displays per channel ● Can extend 1920 x 1080 (@ 60 Hz) signal up to 125-ft. (38.1 m) to next unit in chain 1/5 ● B140-1A0-WP-1 DVI over Cat5/6 Extender ● External power supply w/NEMA 1-15P plug and 5-ft. (1.52 m) cord (Input: 100-240V, 50/60 Hz, 0.5A; Output: 5V, 2A) ● Screwdriver for adjusting equalization ● Mounting hardware ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Can extend 1024 x 768 (@ 60 Hz) signal up to 175-ft. (53.34 m) to next unit in chain Convenient Plug-and-Play Setup ● No software or drivers required ● Compatible with all major operating systems ● Easy RJ45 connector on back—no 110 punchdown necessary ● HDCP compatible ● Built-in equalization control for image adjustment TAA Compliant ● Complies with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332163004 Product Type Receiver Technology Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 720P Range (ft) 200 Max 1080P Range (ft) 150 Max 1280 x 720 (720p) Range (ft) 150 Max 1920 x 1080 (1080p) Range (ft) 150 Receiver/Transceiver Video Output DVI-I Receiver - Number of Video Outputs 1 Range Extension using other Tripp Lite product 175ft @ 1024 x 768 XGA 125ft @ 1920 x 1080 UXGA Recommended Cabling N202-Series Cat6 Patch Cable Other Tripp Lite product used to extend range B140-110 HDR Support No 3D Video Supported Yes Maximum Signal Range (ft) 200 Maximum Signal Range (m) 61 Maximum Signal Range Details 200 ft @ 1024 x 768 XGA150 ft @ 1920 x 1080 UXGA INPUT 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.4 AC Plug Type NEMA 1-15P Power Source Unit (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators Power (Green); Activity (Orange) PHYSICAL Color White Number of Displays 1 Form Factor/Mounting Options Wallplate Shipping Dimensions (hwd / in.) 2.20 x 7.20 x 6.50 Shipping Dimensions (hwd / cm) 5.59 x 18.29 x 16.51 Shipping Weight (lbs.) 0.75 Shipping Weight (kg) 0.34 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 11.43 x 6.99 x 2.54 Unit Packaging Type Box Unit Weight (lbs.) 0.57 Unit Weight (kg) 0.26 Housing Plastic ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 200 Max 480P Range (ft) 200 Max 1440 x 900 Range (ft) 200 Max 1080i Range (ft) 150 Max 480i Range (ft) 200 Max 640 x 480 Range (ft) 200 Max 800 x 600 Range (ft) 200 Max 1600 x 1200 Range (ft) 200 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK) FEATURES & SPECIFICATIONS Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer Yes STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B140-1A0-WP-1 价格&库存
很抱歉,暂时无法提供与“B140-1A0-WP-1”相匹配的价格&库存,您可以联系我们找货
