HR10A-7R-N
HR10A-7R-N
    HRS(广濑)
HR10A-7R-N 数据手册
High performance miniature circular connectors HR10 Series Features 1. A simple, yet highly reliable design for compact, high density applications Although small in size, the HR10 series are full featured connectors with a well integrated design. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2. Extremely easy mating/unmating operations Easy to operable, the single-action push-pull lock structure allows for quick and efficient locking and unlocking. Product Specifications Shell size No. of contacts Rated current 7 4 5 6 2A 10 10 12 2A 13 20 2A Shell size No. of contacts Rated voltage 7 4 5 6 AC150V, DC200V AC100V, DC140V AC100V, DC140V 10 10 12 AC100V, DC140V 13 20 AC100V, DC140V Ratings Ratings Ratings Operation temperature range -25 to +85ç Storage temperature range -10 to +60ç Items Specifications Conditions 1. Contact resistance 10mø min. Measured at DC 1A 2. Insulation resistance 1,000Mø min. Measured at DC 100V 3. Withstanding voltage No flashover or dielectric breakdown. AC 300V for one minute, 4 contacts : AC 500V for 1 minute 4. Vibration resistance No electrical discontinuity of 10µs or greater 10 to 55Hz/cycle, amplitude : 0.75mm, 3 axis directions, for 2 hours each 5. Shock resistance No electrical discontinuity of 10µs or greater Acceleration : 490m/s2, duration : 11ms 3 directions, 3 times each 6. Mating Cycles Contact resistance : 15mø min. 1,000 times 7. Temperature cycle Insulation resistance : 1,000Mø min. -55ç : 30minutes➝Normal temperature : 10 to 15 minutes➝ 85ç : 30minutes➝Normal temperature : 10 to 15minutes, left for 5 cycles. 8. Humidity resistance 5Mø min. (at high humidity) 50Mø min. (at dry) Temperature : 40ç, relative humidity : 90 to 95%, left for 96 hours In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2017.12y 1 HR10 Series●High performance miniature circular connectors Materials / Finish Items Material Finish Remarks Exterior Zinc alloy, brass Matte finished nickel plating ---------------- Insulator Polyamide resin, PBT resin ---------------- Blue, Black Contact Copper alloy HR10 : Gold plating HR10A : Silver plating ---------------- Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. HR10A - 7 P - 3 P C (**) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. q w e r t y u qModel name : Indicates the HR10A Series. The part type is identified as follows. HR10A : Lower cost type HR10G : Shield type HR10B : Coaxial contact type wShell size : The shell size is the outer shell diameter or the mating interface end of the plug. eShell type P : Plug R : Receptacle J : Jack rNumber of contacts tContact form P : Male contact S : Female contact yContact termination method: None : Solder termination C : Crimp termination uOther specifications : A two-digit character is added to indicate other specifications as needed. 2 HR10 Series●High performance miniature circular connectors Diagrams of Connectors in Combination Male Pin side Female Pin side (HR10 • HR10A HR10G Type Receptacle) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (HR10 Type Plug) (HR10 Type Jack) (HR10A Type Plug) (HR10A Type Jack) (HR10B Type Receptacle) (HR10B Type Plug) (HR10A-[ ]T Type Receptacle) (HR10A-[ ]T Type Plug) (HR10A-[ ]T Type Jack) Notes 1 : When using a plug with male terminal, be sure to use a receptacle or jack fitted with female terminal. 2 : Standard finish of the terminal is gold plating for the HR10, and silver plating for the HR10A and HR10G. Be sure to use male and female connectors of the same plating. 3 HR10 Series●High performance miniature circular connectors HR10 type HR10 type connectors, use a gold plated contact as the standard plating specification. Silver plating is used on the contacts for other series such as HR10A and HR10G. To avoid mixing gold and silver contacts, please be sure to confirm the plating specification when using HR10 type connectors with HR10A or HR10G connectors. Plug Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ØB ØC ØD A Max HR10-7P-6S(73) (Representative example) Unit : mm Part No. HRS No. HR10-7P-4P(73) 110-0021-6 73 HR10-7P-4S(73) 110-0022-9 73 HR10-7P-6P(73) 110-0023-1 73 HR10-7P-6S(73) 110-0024-4 73 HR10-10P-12P(73) 110-0025-7 73 HR10-10P-12S(73) 110-0026-0 73 No. of Contacts A ØB ØC ØD Weight 28.5 11 7 5.2 8g 32.5 14 9.5 7.2 15g 4 6 12 Receptacle A 5.7 ØC ØB 6.3 D HR10-7R-6S(73) E(HEX) (Representative example) Unit : mm Part No. HRS No. HR10-7R-4S(73) 110-0031-0 73 HR10-7R-4P(73) 110-0032-2 73 HR10-7R-6S(73) 110-0033-5 73 HR10-7R-6P(73) 110-0034-8 73 HR10-10R-12S(73) 110-0035-0 73 HR10-10R-12P(73) 110-0036-3 73 Remarks : For mounting holes, see page 20. 4 No. of Contacts A ØB ØC D E Weight 14 11 8.85 M8×0.5 10 3.5g 16 14 11.9 M11×0.75 13 6g 4 6 12 HR10 Series●High performance miniature circular connectors Receptacle (PCB dip type) G ØA 5.7 F ØB E Dip post dia. Ø0.55 C D(HEX) HR10-7R-6SA(73) (Representative example) HRS No. No. of Contacts HR10-7R-4SA(73) Part No. 110-0059-9 73 4 HR10-7R-6SA(73) 110-0050-4 73 HR10-7R-6PA(73) 110-0061-0 73 HR10-10R-12SA(73) 110-0049-5 73 HR10-10R-12PA(73) 110-0055-8 73 6 ØA ØB C D 11 8.85 M8×0.5 10 E F 14 11.9 M11×0.75 Weight 3g 6.3 12 G 0.5 13 15.5 5g Remarks : 1. For mounting holes, see page 20. 2. For dip post arrangement, see page 16. Jack A Max ØD ØB 5.5 ØC Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit : mm HR10-7J-6S(73) (Representative example) Unit : mm Part No. HRS No. HR10-7J-4S(73) 110-0027-2 73 HR10-7J-4P(73) 110-0028-5 73 HR10-7J-6S(73) 110-0029-8 73 HR10-7J-6P(73) 110-0030-7 73 HR10-10J-12S(73) 110-0037-6 73 HR10-10J-12P(73) 110-0038-9 73 No. of Contacts A ØB ØC ØD Weight 28.5 11 8.85 5.2 7g 32.5 14 11.9 7.2 14g 4 6 12 5 HR10 Series●High performance miniature circular connectors HR10A•10G Types HR10A connectors are a lower-cost version, yet still provide a high "Value Add" while preserving the superior characteristics of the HR10 connectors. Cable clamps are crimped using a special crimping tool, and the shells have a rubber boot which provides a flexible design that helps to prevent cable twisting. The HR10G connector is a shielded type connector which has an internal contacting structure between the plug shell and receptacle shell. Contacts in both HR10A and 10G connectors are silver plated as standard. Plug (Solder type) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ØD ØB ØC A (Representative example) HR10A-7P-6P(73) Unit : mm Part No. HR10A-7P-4P(73) HR10A-7P-4S(73) HR10A-7P-5P(73) HR10A-7P-5S(73) HR10A-7P-6P(73) HR10A-7P-6S(73) HR10A-10P-10P(73) HR10A-10P-10S(73) HR10A-10P-12P(73) HR10A-10P-12S(73) HR10A-13P-20P(73) HR10A-13P-20S(73) HRS No. 110-0301-2 73 110-0302-5 73 110-0318-5 73 110-0319-8 73 110-0303-8 73 110-0304-0 73 110-0407-3 73 110-0408-6 73 110-0401-7 73 110-0402-0 73 110-0713-0 73 110-0716-8 73 No. of Contacts A ØB ØC ØD Weight 35 11.5 7 5 9g 43 14.7 9.5 4 5 6 10 16g 12 20 7 59 19 13 37g Plug(Crimp type) HR10A-7P-6PC(73) ØD ØC ØB A (Representative example) Unit : mm Part No. HR10A-7P-4PC(73) HR10A-7P-4SC(73) HR10A-7P-6PC(73) HR10A-7P-6SC(73) HR10A-10P-10PC(73) HR10A-10P-10SC(73) HR10A-10P-12PC(73) HR10A-10P-12SC(73) HR10A-13P-20PC(73) HR10A-13P-20SC(73) 6 HRS No. 110-0501-1 73 110-0502-4 73 110-0503-7 73 110-0504-0 73 110-0601-6 73 110-0602-9 73 110-0603-1 73 110-0604-4 73 110-0701-0 73 110-0702-3 73 No. of Contacts A ØB ØC ØD Weight 35 11.5 7 5 9g 43 14.7 9.5 4 6 10 12 20 16g 7 59 19 13 37g HR10 Series●High performance miniature circular connectors Receptacle (Solder type) A ØB 5.7 ØC F D E(HEX) Part No. HR10A-7R-4S(73) HR10A-7R-4P(73) HR10A-7R-5S(73) HR10A-7R-5P(73) HR10A-7R-6S(73) HR10A-7R-6P(73) HR10A-10R-10S(71) HR10A-10R-10P(73) HR10A-10R-12S(71) HR10A-10R-12P(73) HR10A-13R-20S(73) HR10A-13R-20P(73) HR10G-7R-4S(73) HR10G-7R-4P(73) HR10G-7R-6S(73) HR10G-7R-6P(73) HR10G-10R-10S(71) HR10G-10R-10P(73) HR10G-10R-12S(71) HR10G-10R-12P(73) HRS No. 110-0305-3 73 110-0306-6 73 110-0320-7 73 110-0321-0 73 110-0307-9 73 110-0308-1 73 110-0409-9 71 110-0410-8 73 110-0403-2 71 110-0404-5 73 110-0714-2 73 110-0715-5 73 110-1601-1 73 110-1602-4 73 110-1605-2 73 110-1606-5 73 110-1607-8 71 110-1608-0 73 110-1609-3 71 110-1610-2 73 (Representative example) No. of Contacts Unit : mm A ØB ØC D E 14 11 8.85 M8×0.5 10 E Weight Remarks 4 5 3g 6.3 6 10 16 14 11.9 M11×0.75 13 19.2 20.2 18 15.4 M14×0.75 17 14 11 8.85 M8×0.5 10 5g 12 20 9.3 8g 4 3g 6 6.3 Shield type 10 16 14 11.9 M11×0.75 13 5g 12 Remarks : For mounting holes, see page 20. Receptacle (Crimp type) F HR10A-10R-12SC(71) Part No. HR10A-7R-4SC(73) HR10A-7R-4PC(73) HR10A-7R-6SC(73) HR10A-7R-6PC(73) HR10A-10R-10SC(71) HR10A-10R-10PC(71) HR10A-10R-12SC(71) HR10A-10R-12PC(71) HR10A-13R-20SC(73) HR10A-13R-20PC(73) HR10G-7R-4SC(73) HR10G-7R-4PC(73) HR10G-7R-6SC(73) HR10G-7R-6PC(73) HR10G-10R-10SC(71) HR10G-10R-10PC(71) HR10G-10R-12SC(71) HR10G-10R-12PC(71) HR10G-13R-20SC(73) HR10G-13R-20PC(73) HRS No. 110-0506-5 73 110-0505-2 73 110-0508-0 73 110-0507-8 73 110-0606-0 71 110-0605-7 71 110-0608-5 71 110-0607-2 71 110-0703-6 73 110-0704-9 73 110-1701-6 73 110-1702-9 73 110-1705-7 73 110-1706-0 73 110-1707-2 71 110-1708-5 71 110-1709-8 71 110-1710-7 71 110-1711-0 73 110-1712-2 73 ØB E ØA Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HR10A-7R-6S(73) C D(HEX) (Representative example) No. of Contacts ØA ØB C D 11 8.85 M8×0.5 10 E 4 6 6.3 10 14 11.9 M11×0.75 13 18 15.4 M14×0.75 17 12 20 9.3 15 6.3 12 12.2 12 12.2 12 12.2 12 12.2 4 11 8.85 M8×0.5 10 6 10 14 11.9 M11×0.75 13 18 15.4 M14×0.75 17 12 20 F Weight 12 12.2 3g 12 12.2 12 12.2 5g 12 12.2 9.3 15 Unit : mm Remarks 8g 3g Shield type 5g 8g Remarks : For mounting holes, see page 20. 7 HR10 Series●High performance miniature circular connectors Receptacle (Dip type) G ØA 5.7 F ØB E Dip post dia. 0.2∞0.5 C (Representative example) HR10A-7R-6SB(73) D(HEX) Unit : mm Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. No. of Contacts HR10A-7R-4SB(73) 110-0314-4 73 HR10A-7R-4PB(73) 110-0315-7 73 HR10A-7R-5SB(73) 110-0322-2 73 5 HR10A-7R-6SB(73) HR10A-7R-6PB(73) 110-0316-0 73 110-0317-2 73 6 HR10A-10R-10SB(71) 110-0413-6 71 HR10A-10R-10PB(71) 110-0414-9 71 HR10A-10R-12SB(71) 110-0415-1 71 HR10A-10R-12PB(71) 110-0416-4 71 HR10A-13R-20SB(73) 110-0707-7 73 HR10A-13R-20PB(73) 110-0708-0 73 HR10G-7R-4SB(73) 110-1801-0 73 HR10G-7R-4PB(73) 110-1802-3 73 HR10G-7R-6SB(73) 110-1805-1 73 HR10G-7R-6PB(73) 110-1806-4 73 HR10G-10R-10SB(71) HR10G-10R-10PB(71) 110-1807-7 71 110-1808-0 71 HR10G-10R-12SB(71) 110-1809-2 71 HR10G-10R-12PB(71) 110-1810-1 71 HR10G-13R-20SB(73) 110-1811-4 73 HR10G-13R-20PB(73) 110-1812-7 73 ØA ØB C D 11 8.85 M8×0.5 10 E F G Weight Remarks 4 3g 6.3 0.5 15.6 10 14 11.9 M11×0.75 13 18 15.4 M14×0.75 17 11 8.85 M8×0.5 10 5g 12 20 9.3 0 17.8 8g 4 3g 6 6.3 0.5 15.6 Shield type 10 14 11.9 M11×0.75 13 18 15.4 M14×0.75 17 5g 12 20 9.3 0 17.8 8g Remarks : 1. For mounting holes, see page 20. 2. For dip post arrangement, see page 16. ØD 0.2 ØC B 1 ØE 2 Dust cap HR10-7R-C ØA (Representative example) Unit : mm Part No. HR10-7R-C HR10-10R-C HR10A-13R-C 8 HRS No. 110-0058-6 00 110-0052-0 00 110-0452-8 00 ØA 11 14 17.5 B 7 8.5 11.5 ØC 8 10.8 14 ØD 11.2 14.1 18.1 ØE 13 15 19 HR10 Series●High performance miniature circular connectors Jack (Solder type) A HR10A-7J-6S(73) ØD ØC ØB 5.5 (Representative example) HRS No. HR10A-7J-4S(73) 110-0309-4 73 HR10A-7J-4P(73) 110-0310-3 73 HR10A-7J-6S(73) 110-0311-6 73 HR10A-7J-6P(73) 110-0312-9 73 HR10A-10J-10S(73) 110-0411-0 73 HR10A-10J-10P(73) 110-0412-3 73 HR10A-10J-12S(73) 110-0405-8 73 HR10A-10J-12P(73) 110-0406-0 73 No. of Contacts A ØB ØC ØD Weight 35.3 11 8.85 5 9g 43.5 14 11.9 7 16g 4 6 10 12 Jack (Crimp type) A HR10A-7J-6SC(73) ØE ØC D ØB Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit : mm Part No. (Representative example) Unit : mm HRS No. No. of Contacts HR10A-7J-4SC(73) Part No. 110-0510-2 73 4 HR10A-7J-6SC(73) 110-0512-8 73 6 HR10A-10J-10SC(73) 110-0610-7 73 10 HR10A-10J-12SC(73) 110-0612-2 73 12 HR10A-13J-20SC(73) 110-0705-1 73 HR10A-13J-20PC(73) 110-0706-4 73 20 A ØB ØC 35.3 11 8.85 43.5 14 11.9 58.5 18 15.4 D ØE Weight 5 9g 5.5 16g 7 8.5 37g 9 HR10 Series●High performance miniature circular connectors HR10B Type Connector The HR10B connector combines 10 signal lines and one coaxial contact in the standard number 10 shell. Performance specifications for the coaxial contacts are on the 11 page. ØB Ø14.7 Plug Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A HR10B-10P-10PC(73) (Representative example) Unit : mm HRS No. A ØB HR10B-10P-10PC(73) Part No. 110-0901-0 73 50 5 HR10B-10PA-10PC(73) 110-0906-3 73 43 7 Applicable coaxial contact HR10B-2.5CJ(73) Ø11.9 Ø14 Receptacle M11∞0.75 6.3 13(HEX) 12 HR10B-10R-10SC(71) (Representative example) Unit : mm Part No. HR10B-10R-10SC(71) Remarks : For mounting holes, see page 20. 10 HRS No. Applicable coaxial contact 110-0902-2 71 HR10B-2.5CP(73) HR10 Series●High performance miniature circular connectors Coaxial contacts The coaxial contacts shown here are for use with the HR10B connector.These contacts have locking barbs and are inserted from the rear of connector.Please use the following information to select the correct terminals. Materials / Finish Part Material Plug shell Finish Brass Jack shell Gold plating Insulator Tetrafluoride resin Male pin Phosphor bronze Female pin Beryllium copper Description Test data Impedance 50ø Insulation resistance 1000Mø or more at DC250V Contact resistance Center 6.5mø or less and outer 4mø or less at DC1A Gold plating Withstanding voltage AC250V r.m.s for 1minute V.S.W.R 1.3 or less for 0 to 1000MHz Pull force 4.9N (500gf) or more Plug 3.6 5.2 4.1 (clamp) 18.05 HR10B-2.5CP(73) Ø4.2 Ø3.8 Ø1.1 7.1 (Representative example) Unit : mm Part No. HR10B-2.5CP(73) HRS No. Applicable cable Applicable connector 110-0904-8 73 0.8D-QEW-CW(By Fjikura wire) HR10B-10R-10SC(71) Jack 5.2 4.1 3.6 (clamp) 18.2 Ø1.1 7.25 HR10B-2.5CJ(73) Ø4.2 Ø2.65 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Performance (Representative example) Unit : mm Part No. HR10B-2.5CJ(73) HRS No. 110-0903-5 73 Applicable cable Applicable connector 0.8D-QEW-CW(By Fjikura wire) HR10B-10P-10PC(73) 11 HR10 Series●High performance miniature circular connectors Cable connecting methods HR10B-2.5CP(73) HR10B-2.5CJ(73) 1. Cable end treatment Fig.1 11±0.5 1. Dimensions for cable end treatment are shown in Fig 1. 2. Termination is described below. (1) Strip cable outer jacket as indicated. (2) Slit outer jacket on both sides per Fig.1. (3) Fold back outer cover. (4) Remove insulator from cable. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.4±0.2 3.7±0.2 (2.5) Slit cable outer jaket 2 pieces (180° reverse side) 2. Soldering male pin to cable center conductor Fig.2 Male pin 1. Solder male pin to cable center conductor as indicated in Fig.2. (1) Pre-solder the solder pot of pin with Ø0.5mm string solder. (2) Male pin should fit flush against the cable insulator as shown. (3) Remove any excess solder from the pin with a knife.This surface must be smooth. (4) A properly soldered terminal will yield 500gf when stretched. Soldering Should fix flush Contact fixing jig such as vise 3. Crimping cable outer conductor Fig.3 15±0.2 Clamp Connector Remove excess insulator material (remaining after clamping is complated) with a knife or aimilarobject. 12 1. Insert the cable into the connector and make sure to push it all the way in. To confirm that the cable is fully inserted, make sure that the depth is 1.5 ± 0.2mm by measuring from the end of the connector to the tip of the male contact by using a vernier calipers or other suitable measuring device. 2. Use the HR10-TC-01 tool to crimp the metal fitting to the cable. HR10 Series●High performance miniature circular connectors HR10A-( )T Type (Threaded Coupling Type) HR10A-( )T connector is a new product having a threaded coupling locking mechanism. Electric parformance is same as HR10 and HR10A push-pull locking type connectors. Plug (Solder type) HR10A-10TP-12P(73) (Representative example) Unit : mm Part No. HR10A-7TP-6P(73) HR10A-7TP-6P(74) HR10A-10TP-12P(73) HR10A-10TPA-12S(73) HR10A-10WTP-12P(73) HR10A-10WTP-12S(73) HR10A-13TPD-20P(73) HRS No. 110-0331-3 73 110-0331-3 74 110-0432-0 73 110-0446-5 73 110-1101-9 73 110-1106-2 73 110-1015-9 73 No. of Contacts ØA B ØC D ØE 6 12 M10×0.75 7 35 5 17 M13×0.75 43 7 45.8 6.5 56.5 7 12 20 Remarks Gold plating 9.5 15 M12×0.75 20 M17×1 13 * *Waterproof plug need resin filling inside when connector assembly. When mated, the connector against water penetration. Plug (Crimp type) HR10A-10TP-12PC(73) Ø7 Ø9.5 Ø17 43 M13∞0.75 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ØA B ØC ØE D (Representative example) Unit : mm Part No. HR10A-10TP-12PC(73) HRS No. No. of Contacts 110-0455-6 73 12 13 HR10 Series●High performance miniature circular connectors Receptacle (Solder type) E 5.7 ØD B C A F(HEX) HR10A-10TR-12S(73) (Representative example) Unit : mm Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. No. of Contacts HR10-7TR-6S(73) 110-0089-0 73 6 HR10A-10TR-12S(73) 110-0453-0 73 HR10A-10WTR-12S(73) 110-1104-7 73 A B M10×0.75 M13×0.75 12 M12×0.75 6.3 6.8 C ØD E F Remarks M8×0.5 11 14 10 Gold plating 14 16 13 M11×0.75 M10.5×0.75 Remarks : For mounting hole, see page 15(10TR,10WTR) 20(7TR). Receptacle (Crimp type) B ØA C E HR10A-10TR-12SC(73) D (Representative example) F(HEX) Unit : mm Part No. HR10A-10TR-12SC(73) HR10A-13TR-20SC(73) HRS No. 110-0456-9 73 110-1002-7 73 No. of Contacts 12 20 ØA 14 18 B 12 15 C 6.3 9.3 D M13×0.75 M17×1 E M11×0.75 M14×0.75 F 13 17 Remarks : For mounting hole, see page 15 Receptacle (Dip type) G 5.7 F ØA E Dip post H C B HR10A-10TR-12PB(73) D(HEX) (Representative example) Unit : mm Part No. HR10A-7TR-6SA(73) HRS No. 110-0330-0 73 HR10A-10TR-12SB(73) 110-0433-3 73 HR10A-10TR-12PB(73) 110-0457-1 73 HR10A-10TR-12PE(73) 110-0445-2 73 HR10A-10WTR-12SB(73) 110-1102-1 73 HR10A-13TR-20SB(73) 110-1014-6 73 No. of Contacts 6 ØA 11 12 14 20 18 B M10×0.75 C M8×0.5 M13×0.75 M11×0.75 M12×0.75 M10.5×0.75 M17×1 M14×0.75 D 10 E F 6.3 0.5 13 6.8 17 9.3 Remarks : 1.For mounting holes, see page 15. However, 7TR size shell be referred to page 20 on the shell size 7. 2.For dip post arrangement, see page 16. 14 0 G 15.5 H Ø0.55 15.6 15.5 14 0.2×0.5 15.6 17.8 HR10 Series●High performance miniature circular connectors Jack (Solder type) ØA ØC B D HR10A-10TJ-12S(73) (Representative example) Part No. HRS No. No. of Contacts HR10A-10TJ-12S(73) 110-0436-1 73 HR10A-10TJ-12P(73) 110-0459-7 73 HR10A-10WTJ-12S(73) 110-1103-4 73 12 ØA B ØC D 14.7 41.3 7 M13×0.75 14 46.5 6.5 M12×0.75 Remarks * *Waterproof jack need resin filling inside when connector assembly. When mated, the connector against water penetration. Panel mounting hole dimensions (Screw coupling) The mounting hole dimensions shown below are for connectors to be tightened by a hexagonal nut from the back of the panel. The dimensions below apply only to the HR10A-( )T and not the 7TR. For the dimensions of connectors of other types, see page 20. .1 +0 0 Ø10.6 +0.1 0 .1 1 Ø1 8.6 +0.1 0 1.6 +0.1 0 Type Type HR10A-10TR HR10A-10TR (Panel thickness thickness 11to (Panel to2mm) 2mm) 1 0. + 0 1 . 14 Ø 9.6 +0.1 0 9.6 +0.1 0 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit : mm Type HR10A-10WTR (Panel thickness 1 to 2mm) Type HR10A-13TR (Panel thickness 1 to 1.5mm) 15 HR10 Series●High performance miniature circular connectors Contact Male contact Unit : mm 1.2 Type 1 1.15 A Part No. HRS No. Applicable cable Type of plating Loose HR10-PC-111 110-0515 6 Partial gold plating contact HR10-PC-112 110-0513 0 Silver plating A 10 26 to 30 AWG Reel HR10-PC-211 110-0516 9 Partial gold plating contact HR10-PC-212 110-0514 3 Silver plating Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Remarks : 1. Use cables with a coating outside diameter of 1mm or less. 2. Loose piece terminal are available in packs. Each pack contains 100 terminals. Strip terminals are available in reels. Each reel contains 10,000 terminals. Female contact Unit : mm 1.2 A 1 1.15 Type Part No. HRS No. Applicable cable Type of plating Loose HR12-SC-111 112-0410 0 Partial gold plating contact HR12-SC-112 112-0411 3 Silver plating A 10 26 to 30 AWG HR12-SC-211 112-0407 6 Partial gold plating Reel contact HR12-SC-212 112-0408 9 Silver plating Remarks : 1. Use cables with a coating outside diameter of 1mm or less. 2. Loose piece terminal are available in packs. Each pack contains 100 terminals. Strip terminals are available in reels. Each reel contains 10,000 terminals. Receptacle dip post arrangement dimensions 7 10 9 2 1 5 4 2 3 3 1 5 2.5 1.8 1.8 6 Ø0.8+0.1  0 (5 Places) 1 2.55 4 1 2.55 10-size 10 cores 1.8 1.8 1 9 8 1.77 2.71 3 12 11 6 5 1 5 6 2 10 7 2.85 0.95 1 1.1 8 4 1.77 2.71 10-size 12 cores 2 3 4 7 9 10 17 18 19 20 0.8 0.8 2.4 2.4 4 4 13-size 20 cores 7-size 5 cores Remarks : 1.The above figures are views from the mating side and pin inserts from the wiring-connection side. 2.Dimensional tolerance of ±0.05 is recommended for the board arrangement. 16 8 11 12 13 14 15 16 2.85 0.95 7-size 6 cores 0.48 0.9 1.8 Ø0.8+0.1  0 (20 Places) 2.38 0.95 0.95 2.58 1.38 7-size 4 cores 0.9 1.8 3 2.11 0.55 1.13 1.13 4 1.56 1.13 2 Ø0.8+0.1  0 (12 Places) Ø0.8+0.1  0 (10 Places) 2.38 2 2.75 5 3 Ø0.8+0.1  0 (6 Places) 1 1 1 6 2.5 4 1.56 1.13 Ø0.8+0.1  0 (4 Places) HR10 Series●High performance miniature circular connectors Tools Type Item Part No. HRS No. Manual Manual crimping tool HT802/HR12-SC-1 150-0400-3 CM-105C 901-0001-0 Automatic crimping machine body Applicable terminal HR10-PC-112 HR12-SC-112 _______ Applicable cable 26 to 30AWG _______ HR10-PC-211 212 Automatic Applicator AP105-HR12-1 901-2015-9 26 to 30AWG HR12-SC-211 212 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Cable crimping tool Extractor HR10-TC-01 150-0036-2 HR10A-TC-02 150-0041-2 HR12-SC-TP 150-0050-3 RP6-SC-TP 150-0039-0 HR10B-TP 150-0061-0 _______ (HR10B-2.5CP(73), HR10B-2.5CJ(73)) Ø5, Ø7 HR12-SC-112 HR12-SC-212 HR10-PC-112 HR10-PC-212 _______ HR10B-2.5CP(73) HR10B-2.5CJ(73) (HT802/HR12-SC-1) Hand Crimp Tool (HR12-SC-TP) (HR10A-TC-02) Hand Cable Crimp Tool (RP6-SC-TP) Extraction Tool Auto Crimp Tool CM-105C (HR10B-TP) Coaxial Contact Removal Tool 17 HR10 Series●High performance miniature circular connectors How to use a connector 1.Inserting 2.Withdrawing Panel HR10 TYPE Receptacle Plug Cable B A Panel Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HR10A TYPE Receptacle Panel Plug connection sleeve Cable Panel Plug Cable A Plug connection sleeve Cable B Hold the plug at point A, align the plug guide with the receptacle guide, and push the plug straight. The plug will mate with the receptacle smoothly. Hold the plug connection sleeve B and pull the sleeve straight. The plug will come off easily. Connecting tools When terminating the wires, use the jigs noted below for easy assembly / disassembly of the connector parts. HR10-10P-T02 18 HR10-10J-T04 Part No. HRS No. HR10-7P-T01 150-0009-0 Applicable connector HR10-7P HR10-10P-T02 150-0010-9 HR10-10P HR10-7J-T03 150-0011-1 HR10-7J HR10-10J-T04 150-0012-4 HR10-10J HR10-13P-T05 150-0059-8 HR10-13P HR10-13J-T06 150-0060-7 HR10-13J HR10 Series●High performance miniature circular connectors Cable assembly procedure on plug side This applies also to the jack side assembly procedure. No special procedure is given here for the receptacle side because no special procedure is necessary. P shell unit Clamp washer Plug body Tightener Cable HR10 TYPE Bifurcated part About 2 Face A C Face B Spanner jaw distance Spanner jaw distance HR10A TYPE Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Cord bushing P shell unit Clamp Plug body Cable A About 2 for solder type 0 2 -0.5 for crimp type Boss 2 or more Set screw D Table 2 spanner jaw distance Table 3 cable end processing dimensions Size 7 10 13 HR10 8 11 ____ HR10A 7.5 9.5 13 Size 7 10 13 Dimension C Dimension D for HR10A for HR10 Solder type Crimp type 5.5 or less 10 15 to 20 7 or less 16 ____ 25 HR10 TYPE 1 2 3 4 5 Table 1 Size 7 10 13 Tightening force 1.5N·m(15kg·cm) 2N·m(20kg·cm) HR10A TYPE Use cables with a nominal sectional area of 0.129mm2 (26 AWG) at the finish outside diameters applicable for each size. After processing the cable ends according to the dimensions in the above drawings, fit the parts to the cable as shown in the drawings. Fit the parts to the cable in the following order: tightener, clamp washer, and plug body. Fit the parts to the cable in the following order: cord bushing and plug body. (solder type) Insert the P shell unit into the assembly tool stand and solder it. (crimp type) After crimping the appropriate crimp terminal to the cable core, insert the crimp terminal into the terminal hole in the P shell unit. Assemble the connector in the following steps. 1. Screw the plug body into the thread in the P shell unit with the tightening force shown in Table 1 using a torque wrench with a fixed torque. Before tightening the plug body,slacken part C so that no load is applied to the soldered wires. 2. Apply the clamp washer to the bifurcated part of the plug body, and then tighten the tightener until surface B touches the plug body surface A. Note : In order to prevent looseing, please apply an adhesive at the thread of plug body. 1. Fix by caulking the clamp accompanying the cable with the cable crimping tool(HR10A-TC-02) 2. Screw the plug body into the thread in the P shell until with a tightening force shown in Table 1 using a torque wrench with a fixed torque. Before tightening the plug body, slacken the part D so that no load is applied to the soldered wires. 3. Tighten the set screw so that the tip of the screw presses one of the two bosses on the clamp. Fix the set screw with a tightening torque of 0.3N (3kg·cm). 4. Attach the cord bushing to the plug body. Note : In order to prevent looseing, please apply an adhesive at the thread of plug body. This completes the work. For any question on using the plugs, contact our sales or engineering department. 19 HR10 Series●High performance miniature circular connectors Recommended Mounting Hole Mounting hole dimension shown here is tight by hexagon nut from back side. A Map mark 7 size A 1.6 +0.1 0 B 5.1 +0.1 0 C 8.1 +0.1 0 Panel thickness 10 size 13 size 2.6 +0.1 0 B Shell size +0.1 0 8.6 +0.1 0 11.1 +0.1 0 14.1 +0.1 0 6.6 0.7 to 2 ØC 0.8 to 1.5 Contact Arrangement Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Shell size 7 size 10 size Contact arrangement No. of contacts Withstanding voltage Current rating Insulation resistance Contact resistance Solder pot inside dia. Shell size 4 AC500V for a minute 5 6 10 AC300V for a minute 2A MIN 1,000Mø MAX 10mø Ø0.8 10 size 12 13 size Contact arrangement No. of contacts Withstanding voltage Current rating Insulation resistance Contact resistance Solder pot inside dia. 10+coaxial contact 20 AC300V for a minute 2A MIN 1,000Mø MAX 30mø ____ Notes 1. The contact arrangement shown here is the mating surface of socket insert assembled. 2. The withstanding voltage shown here is test voltage value. 3. The isulation resistance value is measured at DC100V. 4. The contact resistance value is measured at DC1A. 20 MAX 10mø Ø0.8 HR10 Series●High performance miniature circular connectors Precautions Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1. Switch off the power of the circuit before disconnecting or plugging-in the connector. 2. Use a connector with socket contacts at the power side of the circuit. 3. Make sure that the coupling is in completely locked position. 4. Cable clamping, cable rotation, and other forces may vary with the cable construction. Please make sure that your cable is suitable for use with these connectors before usage and production. 5. This product series uses silver plated contacts. Silver reacts easily to exposure to sulfur gas so the below conditions may cause tarnishing.  ・Dusty environments  ・Area with a high concentration area of gases such as sulfur dioxide gas, hydrogen sulfide gas, nitrogen dioxide gas and so on. Example; In close proximity to factory exhaust, automotive emissions, etc.  ・Close to heaters, or in other areas marked by extreme temperature differences or high humidity.  ・Close to rubber products includes rubber adhesives. The Electrical connection is not affected by tarnishing on a silver surface due to the wiping effect of the contact pins. Storage Packing state; Packed in original packing or equivalent container Temperature -10 to +60ç Humidity 85% Max (It is recommended that the product be stored in an area of normal level of temperature and humidity, and free of any temperature fluctuation) Please use this products within 6 months of delivery. (After 6 month, please check the solderbility before use) “Storage” means long-term storage of the unused products in sealed packaging, prior to assembly to PCB. ® 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 12/2017. Contents are subject to change without notice for the purpose of improvements. 21
HR10A-7R-N 价格&库存
很抱歉,暂时无法提供与“HR10A-7R-N”相匹配的价格&库存,您可以联系我们找货
