B119-000-REC
B119-000-REC
    TRIPPLITE
    HDMISWITCH
B119-000-REC 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States IR Remote Control Extender/Receiver with 5-ft. Cord for B119-003-1 MODEL NUMBER: B119-000-REC Highlights ● Extend the range of B119-003-1 HDMI switch remote control System Requirements ● B119-003-1 HDMI 3-port Switch Package Includes ● Description Tripp Lite B119-000-REC allows you to extend the range of the remote control unit included with Tripp Lite B119-003-1 HDMI 3-port switch. 5 meter range from IR Receiver to Remote. Features ● Connects to IR EXT port of B119-003-1 3-port HDMI switch ● Extends the range of the remote control included with B119-003-1 ● 5ft extender length....5 meter range from extender to Remote control Specifications OVERVIEW UPC Code 037332181091 Technology IR PHYSICAL Color Black Material of Construction PVC, ABS Cable Length (ft.) 5 Cable Length (m) 1.52 Shipping Dimensions (hwd / in.) 0.50 x 0.25 x 2.00 Shipping Dimensions (hwd / cm) 1.27 x 0.64 x 5.08 1/2 5ft, B119-000-REC extender 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (lbs.) 0.05 Shipping Weight (kg) 0.02 Unit Packaging Type Polybag Unit Weight (lbs.) 0.05 Unit Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range 32 to 104 F (0 to 40 C) Storage Temperature Range -4 to 158 F (-20 to 70 C) Relative Humidity 5% to 90% RH, Non-Condensing COMMUNICATIONS Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Number of Ports 3 Side A - Connector 1 3.5MM (MALE) Connector Plating Gold FEATURES & SPECIFICATIONS Driver Required No WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B119-000-REC 价格&库存
很抱歉,暂时无法提供与“B119-000-REC”相匹配的价格&库存,您可以联系我们找货
