1000 Eaton Boulevard
Cleveland, OH 44122
United States
DVI over Cat5/6 Passive Extender, Remote
Receiver for Video, DVI-D Single Link, Up to 100
ft. (30 m), TAA
Highlights
For use with B140-002 or B140004 extender/splitter transmitter
units
Supports DVI-D Single-Link
video resolutions up to 1920 x
1080 @ 60Hz
Extends a 1920 x 1080 @ 60Hz
signal up to 50-ft. (15.24 m), or
a 1024 x 768 @ 60Hz signal up
to 100-ft. (30.5 m)
Use 24AWG, Solid Wire Cat5e/6
cable, such as Tripp Lite's
N202-Series, to achieve
maximum distance and
resolution
Compatible with all operating
systems
Plug and play, no external
power, software or drivers
required
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
MODEL NUMBER: B140-1P0
Transmit a DVI-D Single-Link signal up to 100 ft. away using a single Cat5e/6 patch cable
Description
The B140-1P0 is a receiver unit that is used with the B140-002 and B140-004 extender/splitter transmitter
units, and it transmits a DVI-D Single-Link signal up to 100-ft. (30.5 m) away using a single Cat5e/6 patch
cable. To achieve maximum distance and resolution, use 24AWG Solid Wire Cat5e/6 cable (Tripp Lite's
N202-Series). The B140-1P0 is compatible with all operating systems, and is plug and play, with no
external power, software or drivers required. Compliant with the Federal Trade Agreements Act (TAA) for
GSA Schedule purchases.
Installation is simple. Connect a B140-002 or B140-004 transmitter (not included) to a DVI source using a
Tripp Lite P561-Series DVI cable (not included). Connect the B140-1P0's built-in DVI connector to a
display. Finally, the receiver unit is connected to an RJ45 port on the transmitter unit using a single
Cat5e/6 cable. A 1920 x 1080 @ 60Hz signal can be extended up to 50-ft. (15.24 m) from the source, or a
1024 x 768 @ 60Hz signal up to 100-ft. (30.5 m)
Features
Transmit a DVI-D Single-Link signal up to 100-ft. (30.5 m) away using a single Cat5e/6 patch cable
For use with B140-002 or B140-004 extender/splitter transmitter units
Supports DVI-D Single-Link video resolutions up to 1920 x 1080 @ 60Hz
Extends a 1920 x 1080 @ 60Hz signal up to 50-ft. (15.24 m), or a 1024 x 768 @ 60Hz signal up to 100ft. (30.5 m)
Use 24AWG, Solid Wire Cat5e/6 cable, such as Tripp Lite's N202-Series, to achieve maximum distance
and resolution
HDCP compatible
Compatible with all operating systems
Plug and play; no external power, software or drivers required
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
1/4
Package Includes
B140-1P0 DVI Over Cat5
Passive Extender Remote Unit
Owner's manual
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332156655
Product Type
Receiver
Technology
DVI; Cat5/5e; Cat6
VIDEO
Max Supported Video Resolution
1920x1080 (1080p @ 60Hz)
Max 720P Range (ft)
100
Max 1080P Range (ft)
50
Max 1280 x 720 (720p) Range (ft)
50
Max 1920 x 1080 (1080p) Range (ft)
50
Receiver/Transceiver Video Output
DVI-D (Single Link)
Receiver - Number of Video Outputs
1
Range Extension using other Tripp
Lite product
175ft @ 1024 x 768 XGA 125ft @ 1920 x 1080 UXGA
Recommended Cabling
N202-Series Cat6 Patch Cable
Other Tripp Lite product used to
extend range
B140-110
HDR Support
No
3D Video Supported
Yes
Maximum Signal Range (ft)
100
Maximum Signal Range (m)
30
Maximum Signal Range Details
100 ft @ 1024 x 768 XGA50 ft @ 1920 x 1080 UXGA
INPUT
Bus Powered
No
POWER
Power Over Cable (PoC) Support
No
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Power (Green); Activity (Orange)
PHYSICAL
Color
Black
Number of Displays
1
Form Factor/Mounting Options
Pigtail
Shipping Dimensions (hwd / in.)
2.00 x 6.30 x 7.20
2/4
Cleveland, OH 44122
United States
Shipping Dimensions (hwd / cm)
5.08 x 16.00 x 18.29
Shipping Weight (lbs.)
0.60
Shipping Weight (kg)
0.27
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Packaging Type
Box
Unit Weight (lbs.)
0.14
Unit Weight (kg)
0.06
Housing
Plastic
ENVIRONMENTAL
Operating Temperature Range
32 to 104 °F (0 to 40 °C)
Storage Temperature Range
5 to 122 °F (-15 to 50 °C)
Relative Humidity
0% to 85%, Non-Condensing
COMMUNICATIONS
Max 1024 x 768 Range (ft)
100
Max 480P Range (ft)
100
Max 1440 x 900 Range (ft)
100
Max 1080i Range (ft)
50
Max 480i Range (ft)
100
Max 640 x 480 Range (ft)
100
Max 800 x 600 Range (ft)
100
Max 1600 x 1200 Range (ft)
100
EDID Compatible
Yes
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
Yes
USB Extension Support
No
CONNECTIONS
Number of Ports
1
Side A - Connector 1
RJ45 (FEMALE)
Side B - Connector 1
DVI-D SINGLE LINK (MALE)
FEATURES & SPECIFICATIONS
Driver Required
No
3/4
Cleveland, OH 44122
United States
10/100 Ethernet Extension Support
No
Built-In Equalizer
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“B140-1P0”相匹配的价格&库存,您可以联系我们找货
