B126-1P0-WP-1
B126-1P0-WP-1
    TRIPPLITE
    HDMIPASSEXTDRWALLPLATE100FT
B126-1P0-WP-1 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States HDMI over Cat5/6 Passive Extender, Wall Plate Remote Receiver for Video/Audio, Up to 50 ft. (15 m), TAA MODEL NUMBER: B126-1P0-WP-1 Highlights ● Supports high-definition video resolutions up to 1080p (60 Hz) ● Supports stereo and 7.1channel surround sound audio ● Works with all operating systems and HDMI video sources ● Plug and play—no software or drivers to install ● Included mounting hardware lets you install the unit on a wall Package Includes Works with Tripp Lite’s B126-Series transmitters to extend an HDMI signal via one Cat5e/6 cable up to 100 ft. to a projector, monitor or television. Ideal for digital signs, schools and trade show presentations. Description The B126-1P0-WP-1 HDMI over Cat5/Cat6 Passive Remote Receiver works with Tripp Lite's B126-002 or B126-004 transmitter to extend an HDMI signal to a projector, monitor or television. It's ideal for digital signs, trade shows, presentations, classrooms, churches, retail settings and other applications where the video source is located farther than conventional cables allow. The receiver uses HDMI cable (see Tripp Lite's P568-Series) to connect to the monitor and a single Cat5e/6 cable to receive the signal from the transmitter (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series). No 110 punchdown connection is required. The B126-1P0-WP-1 can extend a 1080i (60 Hz) signal up to 100 feet (30.5 m) or a 1080p (60 Hz) signal up to 50-ft. (15.24 m) with a single Cat5e/6 cable between it and the transmitter. No external power is needed. In addition to crystal-clear video, the B126-1P0-WP-1 delivers full, rich stereo and 7.1-channel surround sound (multi-channel or PCM) audio when paired with a B126-002 or B126-004 transmitter unit. Supports 24-bit True Color (8 bits per channel) and HDCP compatibility. Easy to set up with no software or drivers to install. Works with all operating systems and HDMI video sources. Features Extends High-Definition Signals ● Works in tandem with Tripp Lite's B126-002 or B126-004 transmitter unit ● Extends a 1080i (60 Hz) signal up to 100-ft. (30.5 m) ● Extends a 1080p (60 Hz) signal up to 50-ft. (15.24 m) ● Connects to transmitter with one Cat5e/6 cable (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series) ● No 110 punchdown connection required Supports the Latest Video and Audio Resolutions ● Works with all operating systems and HDMI video sources ● Supports HD resolutions up to 1080p (60 Hz) 1/4 ● B126-1P0-WP-1 HDMI over Cat5/Cat6 Passive Remote Receiver ● Mounting hardware ● Owner’s Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Supports stereo and 7.1-channel surround sound (multi-channel or PCM) audio when paired with B126002 or B126-004 transmitter unit ● Supports 24-bit True Color (8 bits per channel) and HDCP Easy to Set Up and Use ● Plug-and-play engineering—no software or drivers to download and install ● Connects quickly to monitor with HDMI cable, such as Tripp Lite's P568-Series ● Green LED indicates at a glance when the unit is receiving power ● Included mounting hardware lets you install the unit on a wall ● No external power required TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332162854 Product Type Receiver Technology HDMI; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 720P Range (ft) 100 Max 1080P Range (ft) 50 Max 1280 x 720 (720p) Range (ft) 100 Max 1920 x 1080 (1080p) Range (ft) 50 Receiver/Transceiver Video Output HDMI Receiver - Number of Video Outputs 1 Recommended Cabling N202-Series Cat6 Patch Cable Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 100 Maximum Signal Range (m) 30 Maximum Signal Range Details 100 ft @ 1080i50 ft @ 1080p AUDIO 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Audio Output HDMI Audio Specification Pass-through audio INPUT Bus Powered No POWER Power Over Cable (PoC) Support No USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (Power) PHYSICAL Color White Number of Displays 1 Form Factor/Mounting Options Wallplate Shipping Dimensions (hwd / in.) 2.20 x 7.25 x 6.50 Shipping Dimensions (hwd / cm) 5.59 x 18.42 x 16.51 Shipping Weight (lbs.) 0.55 Shipping Weight (kg) 0.25 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 11.43 x 6.99 x 2.54 Unit Packaging Type Box Unit Weight (lbs.) 0.1 Unit Weight (kg) 0.05 Housing Plastic ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 100 Max 480P Range (ft) 100 Max 1440 x 900 Range (ft) 100 Max 1080i Range (ft) 100 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Max 480i Range (ft) 100 Max 640 x 480 Range (ft) 100 Max 800 x 600 Range (ft) 100 Max 1600 x 1200 Range (ft) 100 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 HDMI (FEMALE) FEATURES & SPECIFICATIONS HDCP Specification 1.4 Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B126-1P0-WP-1 价格&库存
很抱歉,暂时无法提供与“B126-1P0-WP-1”相匹配的价格&库存,您可以联系我们找货
