B119-002-UHD
B119-002-UHD
    TRIPPLITE
    HDMISWITCH2-PORT3840X2160
B119-002-UHD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2-Port HDMI Switch with Remote Control - 4K @ 60 Hz, 4:4:4, HDR, 3D, HDCP 2.2, EDID MODEL NUMBER: B119-002-UHD Highlights ● Supports UHD resolutions up to 4K @ 60 Hz (4:4:4) for crystalclear video ● Up to 18 Gbps data rate ● Switch source devices using button or included remote control ● Supports DTS-HD, Dolby TrueHD and 7.1-channel surround sound ● Plug-and-play operation with no software required for easy, immediate installation Package Includes Connect 2 HDMI source devices, such as a Blu-ray player and DVR, to a single port on an HDMI display and switch back and forth between them. Description The B119-002-UHD 2-Port HDMI Switch allows you to connect two HDMI source devices to one port on an HDMI display and switch back and forth between them. For instance, you can connect a Blu-ray player and video game system or a computer and cable/satellite DVR to one HDMI port on a monitor, projector or TV. Or you can connect two computers or media centers to a display for exhibiting digital signage or giving presentations. Connect your devices to the HDMI ports, and plug the included external power supply into an AC power source. A red LED indicates the unit is receiving power, and green LEDs indicate connected HDMI inputs. Switch between source devices using the unit’s Select button or the included remote control. When the currently used device is powered off, the unit automatically switches to the next powered-on device. The B119-002-UHD ensures top-quality performance with video resolutions up to 4K @ 60Hz 4:4:4, as specified in HDMI 2.0. It is also capable of 48-bit True Color (16 bits per channel), as well as DTS-HD, Dolby TrueHD and 7.1-channel surround sound audio. It’s compatible with 3D, HDR, HDCP v2.2 and EDID. Plug-and-play functionality requires no software or drivers to download and install. Features Connects 2 HDMI Devices to a Single HDMI DisplayIdeal for home entertainment systems, digital signs and video presentationsSwitch between source devices via button on unit or included remote controlAutomatically switches to next available device when currently used device is powered offRed LED indicates unit is receiving power from AC outletGreen LEDs indicate connected HDMI inputs Top-of-the-Line Audio and VideoSupports video resolutions up to 4K @ 60 Hz (4:4:4), as specified in HDMI 2.0Supports 48-bit True Color (16 bits per channel)Up to 18Gbps Data RateSupports DTS-HD, Dolby TrueHD and 7.1-channel surround sound audioCompatible with 3D, HDCP v2.2 and EDID Sets Up in SecondsPlug and play right from the box with no software or drivers needed Specifications OVERVIEW 1/4 ● B119-002-UHD 2-Port HDMI Switch ● Remote control ● External power supply (Input: 100–240V, 50/60 Hz, 0.3A; Output: 5V 1A) ● (4) International plug adapters (North America, Europe, United Kingdom, Australia) ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332191335 Technology HDMI; IR VIDEO Max Supported Video Resolution 4K @ 60Hz (3840 x 2160) Max Supported Color Depth 48-bit Deep Color HDR Support Yes 3D Video Supported Yes AUDIO Audio Specification DTS-HD, Dolby TrueHD and 7.1 Channel Surround Sound INPUT Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Bus Powered No Product Length (in.) 2.15 Product Length (ft.) 0.26 POWER Power Source Type AC Adapter External Power Supply Plug(s) AS/NZS 3112 Australia; BS 1363 UK; CEE 7/16 Schuko; NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.3A External Power Supply Output Specs (V / A) 5V / 1A External Power Supply Cord Length (ft.) 5 External Power Supply Cord Length (m.) 1.5 AC Adapter Input: 100-240V, 50/60Hz, 0.3A; Output: 5V, 1A, 5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 10mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 1.7 USER INTERFACE, ALERTS & CONTROLS LED Indicators Red (Power), (x2) Green (Connection) PHYSICAL Color Black Material of Construction Steel Rackmountable No 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 2.40 x 6.70 x 5.00 Shipping Dimensions (hwd / cm) 6.10 x 17.02 x 12.70 Shipping Weight (lbs.) 0.80 Shipping Weight (kg) 0.36 Unit Dimensions (hwd / in.) 0.800 x 3.100 x 2.000 Unit Packaging Type Box Unit Weight (lbs.) 0.24 Unit Weight (kg) 0.11 ENVIRONMENTAL Operating Temperature Range 32 to 104°F (0 to 40°C) Storage Temperature Range 14 to 176°F (-10 to 80°C) BTUs 5.8 BTU/Hr Operating Humidity Range 10% to 85 % RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing COMMUNICATIONS Port Control Push Buttons EDID Compatible Yes IR Remote Extension Support Yes Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Number of Ports 2 Side A - Connector 1 (2) HDMI (FEMALE) Side B - Connector 1 HDMI (FEMALE) FEATURES & SPECIFICATIONS Port Selection Pushbutton; Remote Selector HDCP Specification 2.2 Driver Required No STANDARDS & COMPLIANCE External Power Supply Certifications BS; C-Tick; CB; CE; DOE; FCC; GS; RoHS; UL; cUL Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B119-002-UHD 价格&库存
很抱歉,暂时无法提供与“B119-002-UHD”相匹配的价格&库存,您可以联系我们找货
