B120-000-SL
B120-000-SL
    TRIPPLITE
    SIGNALEXTENDERBOOSTERDVIF/F
B120-000-SL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DVI Signal Booster / Extender, Single-Link, 1920x1200 60Hz / 1080p, up to 150 ft. (45 m), (DVI F/F), TAA Highlights ● Extend a DVI-D Single-Link signal up to 150-ft. (45.72 m) from the source ● Supports DVI Single Link computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p. ● Use P561-Series DVI SingleLink cables in most applications. ● When extending a 1920 x 1200 (or 1080p) video signal more than 75-ft. (22.86 m), use cable made with 24Awg wiring ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B120-000-SL Package Includes Description Tripp Lite's B120-000-SL DVI Single-Link Signal Extender increases the distance a DVI-D signal can be transmitted beyond the recommended 16-ft. (4.88 m). Supports DVI Single Link computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p, as well as a maximum distance of 150-ft. (45.72 m) from the source. Use P561-Series DVI Single-Link cables in most applications. When extending a 1920 x 1200 (or 1080p) video signal more than 75-ft. (22.86 m), use cable made with 24Awg wiring. (Available from Tripp Lite as a custom order) Simply connect the longer cable between the source and the B120-000-SL, and the shorter cable (16-ft. (4.88 m) or less) between the adapter and the monitor. Software or drivers are not required. Built-in Equalization control to adjust the video image. HDCP and DDC compatible. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Features ● Extend a DVI-D Single-Link signal up to 150-ft. (45.72 m) from the source ● Supports computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p. ● Use P561-Series DVI Single-Link cables in most applications ● When extending a 1920 x 1200 (or 1080p) video signal more than 75-ft. (22.86 m), use a cable made with 24Awg wiring (Available from Tripp Lite as a custom order) ● Built-in Equalization control to adjust the video image ● HDCP and DDC compatible ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332167118 Product Type Signal Booster 1/4 ● B120-000-SL DVI Single Link Extender ● External Power Supply with NEMA 1-15P Plug(Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A) ● Screwdriver for equalization adjustment ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology DVI VIDEO Video Input DVI-D SINGLE LINK (FEMALE) Video Output DVI-D SINGLE LINK (FEMALE) Max Supported Video Resolution 1920x1200 @ 60Hz Max 720P Range (ft) 150 Max 1080P Range (ft) 150 Max 1280 x 720 (720p) Range (ft) 150 Max 1920 x 1080 (1080p) Range (ft) 150 Max 1920 x 1200 Range (ft) 150 Signal Range (ft) 150 Signal Range (m) 46 Recommended Cabling P561-Series HDR Support No 3D Video Supported Yes Maximum Signal Range (ft) 150 Maximum Signal Range (m) 46 Maximum Signal Range Details 150 ft via 24 AWG Cable100 ft via 28 AWG Cable INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.4 AC Plug Type NEMA 1-15P Power Source Unit (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States DC Barrel Plug OD: 5.5 x 2.1 x 12mm, Positive Pin, Negative Sleeve PHYSICAL Color Black Number of Displays 1 Form Factor/Mounting Options Box Shipping Dimensions (hwd / in.) 2.20 x 7.20 x 6.50 Shipping Dimensions (hwd / cm) 5.59 x 18.29 x 16.51 Shipping Weight (lbs.) 0.60 Shipping Weight (kg) 0.27 Unit Dimensions (hwd / in.) 2.400 x 2.040 x 0.940 Unit Packaging Type Box Unit Weight (lbs.) 0.1 Unit Weight (kg) 0.05 Housing Plastic ENVIRONMENTAL Operating Temperature Range 32 to 104°F (0 to 40°C) Storage Temperature Range 14 to 158 F (-10 to 70 C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 150 Max 480P Range (ft) 151 Max 1440 x 900 Range (ft) 150 Max 1080i Range (ft) 150 Max 480i Range (ft) 151 Max 640 x 480 Range (ft) 150 Max 800 x 600 Range (ft) 150 Max 1600 x 1200 Range (ft) 150 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States CONNECTIONS Number of Ports 1 Side A - Connector 1 DVI-I SINGLE LINK (FEMALE) Side B - Connector 1 DVI-I SINGLE LINK (FEMALE) FEATURES & SPECIFICATIONS Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer Yes STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B120-000-SL 价格&库存
很抱歉,暂时无法提供与“B120-000-SL”相匹配的价格&库存,您可以联系我们找货
