B137-101
B137-101
    TRIPPLITE
    S-VIDEOEXTENDERKIT
B137-101 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States S-Video with Stereo Audio over Cat5/Cat6 Extender Kit, In-Line Transmitter and Receiver, Up to 700-ft. Highlights ● Comes with both local and remote units ● Extends a 480p (60Hz) S-Video and Stereo Audio signal up to 500 ft. when using 24Awg, Solid Wire UTP cable (Tripp Lite N202-Series); or, up to 700 ft. when using Zero-Skew UTP cable (Tripp Lite P524-01K) ● No external power required MODEL NUMBER: B137-101 Package Includes Description Tripp Lite's B137-101 S-Video + Stereo Audio extender kit comes with both local and remote units, allowing you to place a TV, Projector, etc, up to 700 ft. away from the source. A 480p (60Hz) S-Video and Stereo Audio signal can be extended up to 500 ft. using 24Awg, Solid Wire UTP cable (Tripp Lite N202Series); or, up to 700 ft. using Zero-Skew UTP cable (Tripp Lite P524-01K). Built-in S-Video and Stereo Audio connectors plug directly into the source and display, without the need for additional cables....no external power required. Features ● Comes with both local and remote units ● Built-in S-Video and Stereo Audio connectors plug directly into the source and display, without the need for additional cables ● Extends a 480p (60Hz) S-Video and Stereo Audio signal up to 500 ft. using 24Awg, Solid Wire UTP cable (Tripp Lite N202-Series); or, up to 700 ft. using Zero-Skew UTP cable (Tripp Lite P524-01K) ● No external power required Specifications OVERVIEW UPC Code 037332155542 Product Type Cat5/Cat6 Extender Kit Technology S-Video; Stereo Audio VIDEO 1/2 ● B137-101 S-Video + Stereo Audio Extender Kit (2pc) ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Maximum Signal Range (ft) 700 Maximum Signal Range (m) 213 PHYSICAL Color Black Shipping Dimensions (hwd / in.) 1.60 x 5.30 x 4.80 Shipping Dimensions (hwd / cm) 4.06 x 13.46 x 12.19 Shipping Weight (lbs.) 0.50 Shipping Weight (kg) 0.23 COMMUNICATIONS Max 480P Range (ft) 700 Max 480i Range (ft) 700 CONNECTIONS Number of Ports 1 Side A - Connector 1 S-VIDEO (MALE) Side A - Connector 2 (2) RCA (MALE) Side A - Connector 3 RJ45 (FEMALE) Side B - Connector 1 S-VIDEO (MALE) Side B - Connector 2 (2) RCA (MALE) Side B - Connector 3 RJ45 (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B137-101 价格&库存
很抱歉,暂时无法提供与“B137-101”相匹配的价格&库存,您可以联系我们找货
