B118-002-UHD
B118-002-UHD
    TRIPPLITE
    HDMISPLITTER2-PORT1080PHDCP
B118-002-UHD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2-Port HDMI Splitter - 4K @ 30Hz, HDCP 1.3 Highlights ● Supports UHD resolutions up to 4K @ 30 Hz (3840 x 2160) for crystal-clear video ● Supports DTS-HD, Dolby True HD, Dolby Digital Plus and LPCM 7.1-channel surround sound ● Add more displays, up to 128, by cascading up to 3 levels of splitters together ● Plug-and-play operation with no software required for easy, immediate installation MODEL NUMBER: B118-002-UHD Package Includes Transmit a 4K x 2K HDMI signal from a single source to two displays. Description Tripp Lite's B118-002-UHD 2-Port 4K 3D HDMI Splitter allows the 4K digital signal from a Blu-ray player or other HDMI device to be displayed on two HDMI displays or connects a DVI-D Single-Link display using an HDMI to DVI adapter, such as Tripp Lite's P566-Series cables. Installation is quick and simple with no software or drivers to install. Locate your HDMI source up to 1.64 feet from the splitter and the splitter up to 23 feet from a display for a maximum distance of approximately 24 feet between splitter and display. Supports Full 3D and video resolutions up to 4K at 30 Hz (3840 x 2160). HDMI and 3D compliant with support for 36-bit Deep Color (12 bits per channel). Supports DTS-HD, Dolby True HD, Dolby Digital Plus and LPCM 7.1-channel surround sound audio. HDCP and EDID compliant. Note: The B118-002-UHD sends the same image to all connected displays. If you would like to extend an image over multiple displays, you will need an MST hub, such as Tripp Lite's B156-002-HD-V2. Features ● Simultaneously transmit the video and audio from an HDMI source to multiple HDMI monitors ● Supports Full 3D and video resolutions up to 4K @ 30 Hz (3840 x 2160) ● Supports 36-bit Deep Color (12-bits per channel) ● Supports DTS-HD, Dolby True HD, Dolby Digital Plus and LPCM 7.1 Channel Surround Sound audio ● Supports video amplifier bandwidth of 340MHz / 3.4Gbps per channel (10.2Gbps total) ● HDCP and EDID compatible ● Plug and play; no software or drivers required ● The B118-002-UHD features a built-in cable (1.6-ft / 0.5m) to connect to the source ● Supports Lip Sync pass-through ● Supports xvYCC and x.vColor ● Supports the use of DVI sources and displays with the use of an optional DVI to HDMI adapter (sold separately) ● Supports a maximum distance 23 ft. (7 m) from splitter to display ● Cascade up to 3 levels of splitters together to increase the number of connected monitors up to 128 Specifications 1/4 ● 2-Port 4K 3D HDMI Splitter ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60 Hz, 0.2A Output: 5V, 1A) ● Owner’s Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332183880 Technology HDMI Host Connector HDMI (FEMALE) VIDEO Video Input HDMI (MALE) Video Output HDMI (FEMALE) Max Supported Video Resolution 4K @ 30Hz (3840 x 2160) Max. Distance (Between any 2 Units) 10ft (3m) Max Number of Ports (Entire Chain) 128 Max Supported Color Depth 36-bit Deep Color HDR Support Yes 3D Video Supported Yes AUDIO Audio Specification DTS-HD, Dolby TrueHD, Dolby Digital Plus and LPCM 7.1 Channel Surround Sound INPUT Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Built-In Cable Length (ft.) 1.64 Built-In Cable Length (m) 0.5 Built-In Cable Length (in.) 19.68 Built-In Cable Length (cm) 50 Bus Powered No Product Length (in.) 2.28 Product Length (ft.) 0.19 POWER External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V, 50/60Hz, 0.2A External Power Supply Output Specs (V / A) 5V / 1A External Power Supply Cord Length (ft.) 4 External Power Supply Cord Length (m.) 1.2 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.2A; Output: 5V, 1A, 4 ft. DC Barrel Plug OD: 5.5 x 2.1 x 9mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 2.1 USER INTERFACE, ALERTS & CONTROLS LED Indicators Red (Signal) PHYSICAL Color Black Material of Construction ABS Included Mounting Accessories No Rackmountable No Shipping Dimensions (hwd / in.) 2.40 x 6.70 x 5.00 Unit Dimensions (hwd / in.) 0.670 x 2.000 x 2.300 Unit Packaging Type Box Unit Weight (lbs.) 0.33 Unit Weight (kg) 0.15 ENVIRONMENTAL Operating Temperature Range 32 to 158 °F (0 to 70 °C) Storage Temperature Range 14 to 176 °F (-10 to 80 °C) BTUs 7.2 BTU/Hr Operating Humidity Range 10% to 85 % RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No CONNECTIONS Number of Ports 2 Side A - Connector 1 HDMI (MALE) Side B - Connector 1 (2) HDMI (FEMALE) Connector Plating Gold 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States PORT EXPANSION Daisy-chainable or Cascadable Cascadable FEATURES & SPECIFICATIONS HDCP Specification 1.3 Driver Required No STANDARDS & COMPLIANCE External Power Supply Certifications CE; ETL; UL Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B118-002-UHD 价格&库存
很抱歉,暂时无法提供与“B118-002-UHD”相匹配的价格&库存,您可以联系我们找货
