B140-1P1-WP-1
B140-1P1-WP-1
    TRIPPLITE
    DVIEXTDRWALLPLATECAT5/6100FT
B140-1P1-WP-1 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States To connect the DVI source to the local transmitter unit, Tripp Lite P561 Series DVI Cable is needed. (sold separately)To connect the the Display to the remote receiver unit, Tripp Lite P561 Series DVI Cable is Highlights ● Extends a 1920 x 1080 @ 60Hz DVI Single-Link signal up to 50ft. (15.24 m), or a 1024 x 768 @ 60Hz signal up to 100ft. ● Wallplate local and remote units with RJ-45 connectors are ideal for permanent mounting and easy wiring of Cat5/6 cabling ● Plug and play, no external power, software or drivers required ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases needed. (sold separately) DVI over Cat5/Cat6 Passive Extender Wallplate Kit, Transmitter and Receiver, 1920x1080 60Hz, Up to 100 ft. (30 m), TAA MODEL NUMBER: B140-1P1-WP-1 Package Includes Perfect for digital signage, video conferencing and meeting rooms that need a remote display located up to 100 ft. from a DVI video source with support of 1080p for Full HD video quality Description Do you need to locate digital display in a conference room, auditorium or classroom a long distance from a DVI source (e.g., DVD recorder) and still want to get an HD quality video experience? Then Tripp Lite's DVI over Cat5/6 Passive Extender Wallplate Kit is the solution for you! Using a simple-to-install kit, containing local transmitter and remote receiver units, it can flawlessly transmit a 1920 x 1080 @ 60Hz DVI Single-Link signal up to 50-ft. (15.24 m), or a 1024 x 768 @ 60Hz signal up to 100ft. with single, 24AWG Solid Wire Cat5e/6 patch cable (Tripp Lite's N202 Series). The wallplate mounting configuration is perfect for permanent installations. For quick and convenient wiring, the wallplate's RJ45 female jacks are rear-facing and fit standard Cat5/6 connections. It's compatible with all operating systems, and requires no external power, software or drivers. It's compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases, and is backed by a 1-year warranty. Features ● Maximum Extension Distance: Extends a 1920 x 1080 @ 60Hz signal up to 50-ft. (15.24 m), or a 1024 x 768 @ 60Hz signal up to 100-ft. (30.5 m) ● Components: Local (transmitter) and remote (receiver) units are mounted in a wallplate configuration. (Cabling is sold separately) ● Wallplate Connectors: Front-facing DVI port/display connectors; rear-facing RJ45 Female jacks for quick and easy connection to standard Cat5/6 cabling. (110 punchdown connections are not required.) ● Recommended Cabling: Tripp Lite 24AWG, Solid Wire Cat5e/6 cabling for maximum distance and resolution (Tripp Lite's N202 Series) ● Compatibility: HDCP; all operating systems ● Power: Plug and play, with no external power, software or drivers required ● LED Indicator: When the DVI source power is energized, the green wallplate LED will illuminate ● Compliance: Federal Trade Agreements Act (TAA) for GSA Schedule purchases 1/4 ● B140-1P1-WP-1 local wallplate ● B140-1P1-WP-1 remote wallplate ● Wallplate screws ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332163028 Product Type Extender Kit Technology DVI; Cat5/5e; Cat6 Host Connector DVI-I DUAL LINK (FEMALE) VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 720P Range (ft) 100 Max 1080P Range (ft) 50 Max 1280 x 720 (720p) Range (ft) 50 Max 1920 x 1080 (1080p) Range (ft) 50 Transmitter Video Input DVI-I (Dual Link) Wired to DVI-D (Single Link) Transmitter - Number of Video Outputs 1 Receiver/Transceiver Video Output DVI-I (Dual Link) Wired to DVI-D (Single Link) Receiver - Number of Video Outputs 1 Range Extension using other Tripp Lite product 175ft @ 1024 x 768 XGA 125ft @ 1920 x 1080 UXGA Recommended Cabling N202-Series Cat6 Patch Cable Other Tripp Lite product used to extend range B140-110 HDR Support No 3D Video Supported Yes Maximum Signal Range (ft) 100 Maximum Signal Range (m) 30 Maximum Signal Range Details 75 ft @ 1024 x 768 XGA50 ft @ 1920 x 1080 UXGA INPUT Bus Powered No POWER Power Over Cable (PoC) Support No PHYSICAL 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Color White Number of Displays 1 Form Factor/Mounting Options Wallplate Receiver Unit Dimensions (hwd / in.) 4.5 x 2.75 x 1 Receiver Unit Weight (lbs.) 0.57 Shipping Dimensions (hwd / in.) 2.20 x 8.40 x 6.50 Shipping Dimensions (hwd / cm) 5.59 x 21.34 x 16.51 Shipping Weight (lbs.) 0.70 Shipping Weight (kg) 0.32 Transmitter Unit Dimensions (hwd / in.) 4.5 x 2.75 x 1 Transmitter Unit Weight (lbs.) 0.57 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Housing Plastic ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 100 Max 480P Range (ft) 100 Max 1440 x 900 Range (ft) 100 Max 1080i Range (ft) 50 Max 480i Range (ft) 100 Max 640 x 480 Range (ft) 100 Max 800 x 600 Range (ft) 100 Max 1600 x 1200 Range (ft) 100 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States CONNECTIONS Number of Ports 1 Side A - Connector 1 DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK) Side A - Connector 2 RJ45 (FEMALE) Side B - Connector 1 DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK) Side B - Connector 2 RJ45 (FEMALE) FEATURES & SPECIFICATIONS Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B140-1P1-WP-1 价格&库存
很抱歉,暂时无法提供与“B140-1P1-WP-1”相匹配的价格&库存,您可以联系我们找货
