B136-100
B136-100
    TRIPPLITE
    REMOTEEXTENDERCAT5/6700FT
B136-100 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Component Video with Stereo Audio over Cat5/Cat6 Extender, In-Line Remote Receiver, Up to 700 ft. Highlights ● Remote extender unit for the B136-004 4-Port Extender/Splitter ● Extends a 1080i (60Hz) Component Video and Stereo Audio signal up to 300 ft. when using 24Awg, Solid Wire UTP cable (Tripp Lite N202-Series); or, up to 400 ft. when using Zero-Skew UTP cable (Tripp Lite P524-01K) ● No external power required MODEL NUMBER: B136-100 Package Includes Description The B136-100 is a remote extender unit for the B136-004 4-Port Component Video + Stereo Audio Extender/Splitter. A 1080i (60Hz) Component Video and Stereo Audio signal can be extended up to 300 ft. when using 24Awg, Solid Wire UTP cable (Tripp Lite N202-Series); or, up to 400 ft. when using ZeroSkew UTP cable (Tripp Lite P524-01K). A 480p (60Hz) Component Video and Stereo Audio signal can be extended up to 500 ft. when using 24Awg, Solid Wire UTP cable (Tripp Lite N202-Series); or, up to 700 ft. when using Zero-Skew UTP cable (Tripp Lite P524-01K). Plugs directly into the TV's Component Video and Stereo Audio ports...no external power required. Features ● Remote extender unit for the B136-004 4-port Extender/Splitter ● A 1080i (60Hz) Component Video and Stereo Audio signal can be extended up to 300 ft. when using 24Awg, Solid Wire UTP cable (Tripp Lite N202-Series); or, up to 400 ft. when using Zero-Skew UTP cable (Tripp Lite P524-01K) ● A 480p (60Hz) Component Video and Stereo Audio signal can be extended up to 500 ft. when using 24Awg, Solid Wire UTP cable (Tripp Lite N202-Series); or, up to 700 ft. when using Zero-Skew UTP cable (Tripp Lite P524-01K) ● Plugs directly into the TV's Component Video and Red/White Audio ports ● No external power required Specifications OVERVIEW UPC Code 037332155450 Product Type Cat5/Cat6 Receiver 1/2 ● B136-100 Component Video + Stereo Audio Remote Extender Unit ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology Component; Stereo Audio VIDEO Max 720P Range (ft) 400 Maximum Signal Range (ft) 700 Maximum Signal Range (m) 213 PHYSICAL Color Black Shipping Dimensions (hwd / in.) 1.00 x 3.00 x 5.20 Shipping Dimensions (hwd / cm) 2.54 x 7.62 x 13.21 Shipping Weight (lbs.) 0.30 Shipping Weight (kg) 0.14 COMMUNICATIONS Max 1024 x 768 Range (ft) 700 Max 480P Range (ft) 700 Max 1440 x 900 Range (ft) 400 Max 1080i Range (ft) 400 Max 480i Range (ft) 700 Max 640 x 480 Range (ft) 700 Max 800 x 600 Range (ft) 700 Max 1600 x 1200 Range (ft) 400 CONNECTIONS Number of Ports 1 Side A - Connector 1 (5) RCA (MALE) Side B - Connector 1 RJ45 (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B136-100 价格&库存
很抱歉,暂时无法提供与“B136-100”相匹配的价格&库存,您可以联系我们找货
