B123-001-60
B123-001-60
    TRIPPLITE
    HDMISIGNALEXTENDER60HZM/F1'
B123-001-60 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States The B123-001-60 has been designed for use with Tripp Lite P568-Series HDMI cables. To ensure maximum distance and performance, it is recommended that you use Tripp Lite P568-Series HDMI cabling. For distances over 75-ft, 24AWG cable such as Tripp Lite's P568-100-HD is required.Although most installations will not require power, a Micro USB port is provided in the event power is needed. Using a Micro USB cable(such as Tripp Lite's UR05C-Series), connect the Micro USB port to a USB wall charger, the USB port on your monitor, or the USB port on a computer. HDMI Signal Booster / Extender Cable, 1920 x 1200 (1080p) 60Hz, Up to 125 ft. (38 m), (HDMI M/F), 1 ft, TAA Highlights ● Extend a 1080p @ 60Hz (or 1920 x 1200) HDMI signal up to 125-ft. (38.1 m) from the source ● Supports DTS-HD, Dolby True HD and 7.1 Channel Surround Sound Audio ● No external power required in most installations ● Built-in HDMI cable features a latching connector for a more secure connection ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B123-001-60 Package Includes ● Extend a 1080p @ 60Hz (or 1920 x 1200) signal up to 125ft Description Tripp Lite's B123-001-60 HDMI Signal Extender increases the distance a 1080p @ 60Hz (or 1920 x 1200) signal can be transmitted beyond the recommended 16-ft. (4.88 m). It supports computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p @ 60Hz, at a maximum distance of 125-ft. (38.1 m) from the source. Use P568-Series HDMI cables in most applications. When extending a 1080p @ 60Hz (or 1920 x 1200) signal more than 75-ft. (22.86 m), use cable made with 24Awg wiring, such as the P568-100-HD. (Lengths over 100-ft. (30.5 m) are available from Tripp Lite as a custom order) 24Awg HDMI cable is also needed when extending a 3D signal more than 50-ft. (15.24 m). A 3D signal can be extended up to 125-ft. (38.1 m) using 24Awg HDMI cable. Simply connect the longer cable between the source and the B123-001-60, and the built-in cable between the adapter and the monitor/TV. The built-in HDMI cable features a latching connector for a more secure connection. Software or drivers are not required. HDCP compliant. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Features ● Extend a 1080p @ 60Hz (or 1920 x 1200) HDMI signal up to 125-ft. (38.1 m) from the source ● Use P568-Series HDMI cables in most applications ● Built-in HDMI cable features a latching connector for a more secure connection ● When extending a 1080p @ 60Hz (or 1920 x 1200) signal more than 75-ft. (22.86 m), use cable made with 24Awg wiring, such as the P568-100-HD. ● Lengths over 100-ft. (30.5 m) are available from Tripp Lite as a custom order) ● 24Awg HDMI cable is also needed when extending a 3D signal more than 50-ft. (15.24 m). A 3D signal can be extended up to 125-ft. (38.1 m) using 24Awg HDMI cable ● Supports DTS-HD, Dolby True HD and 7.1 Channel Surround Sound Audio ● No external power required in most installations 1/5 B123-001-60 HDMI Active Extender 1000 Eaton Boulevard Cleveland, OH 44122 United States ● HDCP compliant ● No software or drivers required ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332171184 Product Type Signal Booster Technology HDMI; Cat5/5e; Cat6 VIDEO Video Input HDMI (FEMALE) Video Output HDMI (MALE) Number of Monitors Supported 1 Video Ports HDMI (FEMALE) Video Ports Details HDMI 1.4; HDCP 1.4 Resolutions Supported Extend a 1080p @ 60Hz (or 1920 x 1200) HDMI signal up to 125-ft. (38.1 m) from the source Max Supported Video Resolution 1920x1200 @ 60Hz Max 720P Range (ft) 125 Max 1080P Range (ft) 125 Max 1280 x 720 (720p) Range (ft) 125 Max 1920 x 1080 (1080p) Range (ft) 125 Max 1920 x 1200 Range (ft) 125 Recommended Cabling 24 AWG Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 125 Maximum Signal Range (m) 38 Maximum Signal Range Details Extend a 1080p @ 60Hz (or 1920 x 1200) HDMI signal up to 125-ft. (38.1 m) from the source AUDIO Audio Input HDMI Audio Output HDMI 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Audio Specification Pass-through audio INPUT Built-In Cable Length (ft.) 0.5 Built-In Cable Length (in.) 6 Bus Powered No Product Length (in.) 8.362 Product Length (cm.) 21.239 Product Length (ft.) 0.696 Product Length (m.) 0.06 POWER Power Source Type USB Power Source Unit (Optional) Power Over Cable (PoC) Support No PHYSICAL Color Black Material of Construction Plastic Cable Jacket Color Black Cable Length (ft.) 1 Cable Length (m) 0.30 Number of Displays 1 Form Factor/Mounting Options Pigtail Shipping Dimensions (hwd / in.) 1.30 x 6.14 x 4.80 Shipping Dimensions (hwd / cm) 3.30 x 15.60 x 12.19 Shipping Weight (lbs.) 0.11 Shipping Weight (kg) 0.05 Unit Dimensions (hwd / in.) 0.600 x 1.020 x 8.360 Unit Packaging Type Box Unit Weight (lbs.) 0.05 Unit Weight (kg) 0.02 Housing Plastic ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Relative Humidity 0% to 85% RH, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 125 Max 480P Range (ft) 125 Max 1440 x 900 Range (ft) 125 Max 1080i Range (ft) 125 Max 480i Range (ft) 125 Max 640 x 480 Range (ft) 125 Max 800 x 600 Range (ft) 125 Max 1600 x 1200 Range (ft) 125 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 HDMI (MALE) Side A - Connector 2 MICRO-USB B (FEMALE) Side B - Connector 1 HDMI (FEMALE) FEATURES & SPECIFICATIONS HDCP Specification 1.4 Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B123-001-60 价格&库存
很抱歉,暂时无法提供与“B123-001-60”相匹配的价格&库存,您可以联系我们找货
