1000 Eaton Boulevard
Cleveland, OH 44122
United States
HDMI over Cat5/6 Passive Extender, Box-Style
Remote Receiver for Video/Audio, Up to 100 ft.
(30 m), TAA
MODEL NUMBER: B126-1P0
Highlights
Supports high-definition video
resolutions up to 1080p (60 Hz)
Supports stereo and 7.1channel surround sound audio
Works with all operating
systems and HDMI video
sources
Plug and play—no software or
drivers to install
Built-in HDMI cable latches
tightly for more secure
connection
Package Includes
Works with Tripp Lite's B126-Series transmitters to extend an HDMI signal via Cat5e/6 cable up to 100 ft.
to a projector, monitor or television. Ideal for digital signs, schools and trade show presentations.
Description
The B126-1P0 HDMI over Cat5/Cat6 Passive Remote Receiver works with Tripp Lite's B126-002 and
B126-004 transmitters to extend an HDMI signal to multiple projectors, monitors or televisions in a chain.
It's ideal for digital signs, trade shows, presentations, classrooms, churches, retail settings and other
applications where the video source is located farther than conventional cables allow.
The B126-1P0 can extend a 1080i (60 Hz) signal up to 100-ft. (30.5 m) or a 1080p (60 Hz) signal up to 50ft. (15.24 m) with a single Cat5e/6 cable (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as
Tripp Lite's N202-Series) between it and the transmitter. The built-in HDMI cable features a latching
connector that helps prevent accidental disconnection. No external power is required.
In addition to crystal-clear video, the B126-1P0 delivers full, rich stereo and 7.1-channel surround sound
(multi-channel or PCM) audio when paired with a B126-002 or B126-004 transmitter. Supports 24-bit True
Color (8 bits per channel) and HDCP compatibility. Easy to set up with no software or drivers to install.
Features
Extends High-Definition Signals
● Works in tandem with Tripp Lite's B126-002 and B126-004 transmitter units
Extends a 1080i (60 Hz) signal up to 100-ft. (30.5 m)
Extends a 1080p (60 Hz) signal up to 50-ft. (15.24 m)
Connects to transmitter with one Cat5e/6 cable (for best results, use 24 AWG solid-wire Cat5e/6 cable,
such as Tripp Lite's N202-Series)
Built-in HDMI cable with latching connector to help prevent accidental disconnection
Supports the Latest Video and Audio Resolutions
● Works with all operating systems and HDMI video sources
Supports HD resolutions up to 1080p (60 Hz)
Supports stereo and 7.1-channel surround sound (multi-channel or PCM) audio when paired with a
Supports 24-bit True Color (8 bits per channel) and HDCP
1/4
Owner’s Manual
Cleveland, OH 44122
United States
Easy to Set Up and Use
● Plug-and-play engineering—no software or drivers to download and install
No external power required
TAA-Compliant
● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332157461
Product Type
Receiver
Technology
HDMI; Cat5/5e; Cat6
VIDEO
Video Input
HDMI (MALE)
Video Output
RJ45 (FEMALE)
Max Supported Video Resolution
1920x1080 (1080p @ 60Hz)
Max 720P Range (ft)
100
Max 1080P Range (ft)
50
Max 1280 x 720 (720p) Range (ft)
50
Max 1920 x 1080 (1080p) Range (ft)
50
Receiver/Transceiver Video Output
HDMI
Receiver - Number of Video Outputs
1
Range Extension using other Tripp
Lite product
175ft @ 1080i 125ft @ 1080p
Recommended Cabling
N202-Series Cat6 Patch Cable
Other Tripp Lite product used to
extend range
B126-110
Max Supported Color Depth
24-bit True Color
HDR Support
No
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
Maximum Signal Range (ft)
100
Maximum Signal Range (m)
30
Maximum Signal Range Details
175ft @ 1080i25ft @ 1080p
2/4
Cleveland, OH 44122
United States
AUDIO
Audio Output
HDMI
Audio Specification
Pass-through audio
INPUT
Bus Powered
No
POWER
Power Source
Receiver end only (Optional)
Power Over Cable (PoC) Support
No
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Green = Connection
PHYSICAL
Color
Black
Number of Displays
1
Form Factor/Mounting Options
Pigtail
Shipping Dimensions (hwd / in.)
1.30 x 6.14 x 4.80
Shipping Dimensions (hwd / cm)
3.30 x 15.60 x 12.19
Shipping Weight (lbs.)
0.17
Shipping Weight (kg)
0.08
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Packaging Type
Box
Unit Weight (lbs.)
0.03
Unit Weight (kg)
0.01
Housing
Plastic
ENVIRONMENTAL
Operating Temperature Range
32 to 104 °F (0 to 40 °C)
Storage Temperature Range
5 to 122 °F (-15 to 50 °C)
Relative Humidity
0% to 85%, Non-Condensing
COMMUNICATIONS
Max 1024 x 768 Range (ft)
100
Max 480P Range (ft)
100
Max 1440 x 900 Range (ft)
100
3/4
Cleveland, OH 44122
United States
Max 1080i Range (ft)
100
Max 480i Range (ft)
100
Max 640 x 480 Range (ft)
100
Max 800 x 600 Range (ft)
100
Max 1600 x 1200 Range (ft)
100
EDID Compatible
Yes
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
Yes
USB Extension Support
No
CONNECTIONS
Number of Ports
1
Side A - Connector 1
RJ45 (FEMALE)
Side A - Connector 2
MICRO-USB B (FEMALE)
Side B - Connector 1
HDMI (MALE)
Connector Plating
Gold
FEATURES & SPECIFICATIONS
HDCP Specification
1.4
Driver Required
No
10/100 Ethernet Extension Support
No
Built-In Equalizer
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“B126-1P0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+574.125821+74.41764
- 10+488.0218610+63.25693
- 25+457.4879225+59.29915
- 50+435.6696950+56.47109
- 100+414.90084100+53.77905
