B118-002
B118-002
    TRIPPLITE
    HDMISPLITTER2-PORT1080PHDCP
B118-002 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2-Port HDMI Splitter for Video with Audio 1920x1200 at 60Hz/1080p (HDMI F/2xF) MODEL NUMBER: B118-002 Highlights ● Display HD video resolutions up to 1080p, and computer video resolutions up to 1920 x 1200 ● Supports up to 36-bit Deep Color (12-bits per channel) ● High Speed HDMI v1.4 and 3D compliant ● Supports DTS-HD, Dolby True HD and 7.1 Channel Surround Sound audio ● HDCP v1.4 and EDID compliant ● Plug and play; No software or drivers required System Requirements ● TV's with an available HDMI port and a HDMI peripheral device (e.g. Blu-Ray player, DVR, etc.) ● The cable connecting the HDMI source to the splitter must be no longer than 13 ft. (4 m.) ● The cable connecting the splitter to a HDMI monitor must be no longer than 16 ft. (5 m.) Transmit a HDMI signal from a single source to two displays Description Tripp Lite's B118-002 HDMI Splitter allows the digital signal from a Blu-Ray player or other HDMI device to be displayed on two HDMI displays, or, connect a DVI-D Single Link display using an HDMI to DVI Package Includes adapter, such as Tripp Lite's P566-Series cables. Installation is quick and simple, with no software or ● B118-002 2-Port HDMI Splitter drivers to install. Locate your HDMI source up to 13 ft. (4 m.) from the splitter, and the splitter up to 16 ft. ● External Power Supply with NEMA 1-15P Plug (Input:100240V, 50/60Hz, 0.5A; Output: 5V, 2A, 4.9 ft.) ● Owner's Manual (5 m.) from a display, for a max distance of 29 ft. (9 m.) between source and display. Multiple splitters can be cascaded together to connect additional monitors, with no more than 6 levels of splitters in all. Supports HD video resolutions up to 1080p, and computer video resolutions up to 1920 x 1200. High Speed HDMI v1.4 and 3D compliant, with support for 36-bit Deep Color (12-bits per channel). Supports DTS-HD, Dolby True HD and 7.1 Channel Surround Sound audio. HDCP v1.4 and EDID compliant. Features ● Transmit a HDMI signal from a single source to two displays ● Display HD video resolutions up to 1080p, and computer video resolutions up to 1920 x 1200 ● Supports up to 36-bit Deep Color (12-bits per channel) ● High Speed HDMI v1.4 and 3D compliant ● Supports DTS-HD, Dolby True HD and 7.1 Channel Surround Sound audio ● HDCP v1.4 and EDID compliant ● Plug and play; No software or drivers required ● Locate a monitor up to 29 ft. (9 m.) from a HDMI source; up to 13 ft. (4 m.) between the source and the switch; up to 16 ft. (5 m.) between the switch and a monitor ● Cascade multiple levels of splitters together to increase the number of connected monitors, with no more than 6 levels of splitters in all ● Connect a DVI-D Single Link display using an HDMI to DVI adapter, such as Tripp Lite's P566-Series cables. 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332180520 Technology HDMI VIDEO Max Supported Video Resolution 1080p @60Hz Max. Distance (Between any 2 Units) 16ft (5m) Max Number of Ports (Entire Chain) 2048 Max Supported Color Depth 12-bit 3D Video Supported Yes AUDIO Audio Specification 7.1 Surround Sound, Dolby True HD, DTS-HD, DSD INPUT Voltage Compatibility (VAC) 100; 110; 120; 127; 200; 208; 220; 230; 240 POWER External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.8A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 5 External Power Supply Cord Length (m.) 1.5 DC Barrel Plug OD: 5.5 x 2.1 x 10mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 10 USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (Power, Input, Output 1, Output 2) PHYSICAL Color Black Material of Construction Steel Shipping Dimensions (hwd / in.) 2.09 x 8.07 x 5.71 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / cm) 5.31 x 20.50 x 14.50 Shipping Weight (lbs.) 0.88 Shipping Weight (kg) 0.40 Unit Dimensions (hwd / in.) 0.900 x 4.400 x 3.000 Unit Dimensions (hwd / cm) 2.4 x 11.1 x 7.5 Unit Packaging Type Box Unit Weight (lbs.) 0.5 Unit Weight (kg) 0.23 ENVIRONMENTAL Operating Temperature Range 32 to 104 F (0 to 40 C) Storage Temperature Range -4 to 158 F (-20 to 70 C) Relative Humidity 5% to 90% RH, Non-Condensing BTUs 34.1 BTU/Hr COMMUNICATIONS Signal Range (ft.) 16 Signal Range (m) 5 EDID Compatible Yes Consumer Electronics Control (CEC) Supported Yes Latency 80ms CONNECTIONS Number of Ports 2 Side A - Connector 1 HDMI (FEMALE) Side B - Connector 1 (2) HDMI (FEMALE) Connector Plating Gold PORT EXPANSION Daisy-chainable or Cascadable Cascadeable FEATURES & SPECIFICATIONS HDCP Specification 1.4 Driver Required No STANDARDS & COMPLIANCE External Power Supply Certifications CE; FCC; UL; RoHS 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B118-002 价格&库存
很抱歉,暂时无法提供与“B118-002”相匹配的价格&库存,您可以联系我们找货
