B132-100A-SR
B132-100A-SR
    TRIPPLITE
    VGAEXTENDERW/AUDIO300FT
B132-100A-SR 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States VGA with Audio over Cat5/Cat6 Extender, Receiver, USB-Powered, 1440x900 60 Hz, Up to 300 ft. (90 m), TAA MODEL NUMBER: B132-100A-SR Highlights ● Works with a B132-002A-2 or B132-004A-2 Transmitter Unit to extend a VGA video and audio signal up to 300-ft. from the source ● Extends a 1440 x 900 video and audio signal up to 150-ft, or a 1024 x 768 video and audio signal up to 300-ft. ● Power is supplied via the included USB Micro-B cable; no external power supplies required ● Plug and play, no software or drivers required ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Package Includes Extends a VGA video and audio signal up to 300-ft. (91M) from the source Features ● Works with a B13 or B13 Transmitter Unit to extend a VGA video and audio signal up to 300-ft. from the source ● Extends a 1440 x 900 video and audio signal up to 150-ft, or a 1024 x 768 video and audio signal up to 300-ft. ● 24AWG, Solid Wire Cat5e/6 cable (such as Tripp Lite's N20 Cat6 cables) is required to achieve maximum distance and resolution ● Power is supplied via the included USB Micro-B cable; no external power supply required ● Features built-in equalization and gain controls to adjust the video image ● All operating systems supported ● Plug and play; no software or drivers required ● HDCP and EDID compliant ● Ideal for digital signage installations for retail, schools, churches, etc. ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332185563 Product Type Receiver Technology VGA/SVGA; Stereo Audio; Cat5/5e; Cat6 VIDEO 1/3 ● B132-100A-SR ● USB Micro-B cable ● Screwdriver for EQ/Gain adjustment ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Max 720P Range (ft) 150 HDR Support No 3D Video Supported No Maximum Signal Range (ft) 300 Maximum Signal Range (m) 91 INPUT Bus Powered No POWER Power Over Cable (PoC) Support No PHYSICAL Color White Number of Displays 1 Shipping Dimensions (hwd / in.) 6.14 x 4.80 x 1.30 Shipping Dimensions (hwd / cm) 15.60 x 12.19 x 3.30 Shipping Weight (lbs.) 0.37 Shipping Weight (kg) 0.17 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 COMMUNICATIONS Max 1024 x 768 Range (ft) 300 Max 480P Range (ft) 300 Max 1440 x 900 Range (ft) 150 Max 480i Range (ft) 300 Max 640 x 480 Range (ft) 300 Max 800 x 600 Range (ft) 300 EDID Compatible No IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported No USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 RJ45 (FEMALE) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Side B - Connector 1 HD15 (FEMALE) Side B - Connector 2 3.5MM (FEMALE) FEATURES & SPECIFICATIONS Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer No WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
B132-100A-SR 价格&库存
很抱歉,暂时无法提供与“B132-100A-SR”相匹配的价格&库存,您可以联系我们找货
