B136-101-WP-1
B136-101-WP-1
    TRIPPLITE
    VIDEO/AUDEXTDRWALLPLATE700FT
B136-101-WP-1 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Component Video with Stereo Audio over Cat5/Cat6 Extender Kit, Wallplate Transmitter and Receiver, Up to 700 ft. (213 m) MODEL NUMBER: B136-101-WP-1 Highlights ● Extends a 1080i (60Hz) Component Video and Stereo Audio signal up to 300-ft. (91.44 m) ● No external power required Package Includes Is your TV or other display far away from your audio/video source? This wallplate kit allows a TV, projector, etc. with component video input to be placed up to 300 ft. away from a component audio/video source using ordinary Cat5e UTP cabling. It's great for presentation/conference rooms at a great price! Description Tripp Lite's B136-101-WP-1 Cat5 Extender Wallplate Kit with Component Video + Stereo Audio comes with both local and remote wallplates, allowing you to place a TV, Projector, etc up to 300-ft. (91.44 m) away from the source. A 1080i (60Hz) Component Video and Stereo Audio signal can be extended up to 300-ft. (91.44 m) when using 24Awg, Solid Wire UTP cable (Tripp Lite N022-01K-GY or N222-01K-GY); or up to 400-ft. (121.92 m) when using Zero-Skew UTP cable (Tripp Lite P524-01K). A 480p (60Hz) Component Video and Stereo Audio signal can be extended up to 500-ft. (152.4 m) when using 24Awg, Solid Wire UTP cable (Tripp Lite N022-01K-GY or N222-01K-GY); or up to 700-ft. (213.36 m) when using Zero-Skew UTP cable (Tripp Lite P524-01K). Simple RJ45 Jack connection on the back of the wallplates. No external power required. Features ● Comes with both local and remote wallplates ● Easy RJ45 rear connection jacks on both wallplates ● A 1080i (60Hz) Component Video and Stereo Audio signal can be extended up to 300-ft. (91.44 m) when using 24Awg, Solid Wire UTP cable (Tripp Lite N022-01K-GY or N222-01K-GY); or, up to 400-ft. (121.92 m) when using Zero-Skew UTP cable (Tripp Lite P524-01K) ● No external power required Specifications OVERVIEW UPC Code 037332162878 Product Type Extender Kit 1/4 ● B136-101-WP-1 Cat5 Extender Wallplate Kit with Component Video + Stereo Audio ( 2 pieces ) ● Wallplate Mounting Screws ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology Component; Stereo Audio; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920x1080 (1080i @ 60Hz) Max 720P Range (ft) 400 Max 1280 x 720 (720p) Range (ft) 328 Transmitter Video Input Component (RCA) Transmitter - Number of Video Outputs 1 Receiver/Transceiver Video Output Component (RCA) Receiver - Number of Video Outputs 1 Recommended Cabling P524-01K HDR Support No 3D Video Supported Yes Maximum Signal Range (ft) 700 Maximum Signal Range (m) 213 AUDIO Audio Input RCA (x2) Stereo Audio Output RCA (x2) Stereo Audio Specification Stereo Audio INPUT Bus Powered No POWER Power Over Cable (PoC) Support No PHYSICAL Color White Number of Displays 1 Form Factor/Mounting Options Wallplate Receiver Unit Dimensions (hwd / in.) 4.53 x 2.76 x 2 Receiver Unit Weight (lbs.) 0.5 Shipping Dimensions (hwd / in.) 1.70 x 7.90 x 5.50 Shipping Dimensions (hwd / cm) 4.32 x 20.07 x 13.97 Shipping Weight (lbs.) 0.70 Shipping Weight (kg) 0.32 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Transmitter Unit Dimensions (hwd / in.) 4.53 x 2.76 x 2 Transmitter Unit Weight (lbs.) 0.5 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Housing Plastic ENVIRONMENTAL Operating Temperature Range 32 to 104°F (0 to 40°C) Storage Temperature Range 14 to 158 F (-10 to 70 C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 700 Max 480P Range (ft) 700 Max 1440 x 900 Range (ft) 400 Max 1080i Range (ft) 400 Max 480i Range (ft) 700 Max 640 x 480 Range (ft) 700 Max 800 x 600 Range (ft) 700 Max 1600 x 1200 Range (ft) 400 EDID Compatible No IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported No USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 (5) RCA (FEMALE) Side A - Connector 2 RJ45 (FEMALE) Side B - Connector 1 (5) RCA (FEMALE) Side B - Connector 2 RJ45 (FEMALE) FEATURES & SPECIFICATIONS Driver Required No 10/100 Ethernet Extension Support No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Built-In Equalizer No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B136-101-WP-1 价格&库存
很抱歉,暂时无法提供与“B136-101-WP-1”相匹配的价格&库存,您可以联系我们找货
