B118-004-UHD
B118-004-UHD
    TRIPPLITE
    4-PORTHIGHSPEEDHDMISPLITTER
B118-004-UHD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port HDMI Splitter - 4K, HDCP 1.3 Highlights ● Transmits up to 39 ft. for digital signage in bars, offices, classrooms, trade shows, etc. ● Capable of daisy-chaining up to 256 total displays in sophisticated applications ● Delivers UHD picture quality at resolutions up to 4K @ 30 Hz (3840 x 2160) ● Provides clear, rich sound in DTS-HD, Dolby TrueHD and 7.1-channel surround ● Plug-and-play operation with no software required for easy, immediate installation MODEL NUMBER: B118-004-UHD Applications 1x4 HDMI splitter transmits 4K audio/video from an HDMI source to 4 HDMI display devices at the same time. ● Displaying a digital menu from a PC on monitors in a restaurant or bar ● Connecting HDTVs to the same cable box, media server, game system or Blu-ray player for sports, video games or movies ● Playing a promotional video from a laptop at a trade show ● Giving a presentation on large projectors or monitors in a lecture hall ● Creating digital signage for an office lobby, healthcare waiting room or airport Features 1 x 4 HDMI Splitter Transmits 4K Audio/Video to 4 HDMI Displays at the Same TimeIdeal for displaying digital signage in classrooms, healthcare facilities, churches, offices, restaurants, bars and trade shows, this Ultra HD HDMI splitter is quick and easy to install. It connects to an HDMI source device, such as a computer, media server, cable box/DVR or Blu-ray player, and transmits an audio/video signal to four HDMI monitors, projectors or televisions simultaneously. You can daisy-chain up to three levels of splitters, which expands the total number of connected displays to 256. Note: The B118-004UHD sends the same image to all connected displays. If you would like to extend an image over multiple displays, you will need an MST hub, such as the B156-002-HD-V2. Supports Ultra High Definition Signals up to 39 ft.Using standard 28 AWG HDMI cabling, the B118004-UHD Ultra HD HDMI splitter distributes a 4K audio/video signal up to 39.4 feet (12 meters). Place your HDMI source up to 16.4 feet from the splitter and the splitter up to 23 feet from an HDMI display for a maximum distance of 39.4 feet between source and display. System Requirements Maintains 4K x 2K Video Resolutions and Rich Stereo SoundThe splitter maintains full 3D and video resolutions up to 4K at 30 Hz (3840 x 2160) and 36-bit Deep Color (12 bits per channel). It also supports a wide range of audio formats, including DTS-HD, Dolby TrueHD, Dolby Digital Plus and LPCM 7.1-channel surround sound. *Will work with DVI-D single-link sources and displays when used with an HDMI to DVI adapter Also Works with DVI Sources and DisplaysYou can also use legacy DVI-D single-link sources and displays with the B118-004-UHD to avoid an expensive upgrade to HDMI equipment. Connect DVI-D components using HDMI to DVI adapters, such as Tripp Lite's P566-Series. You will be able to transmit video only, and resolutions will be limited to those supported by the adapter. Ready to Use Right Out of the PackageThe plug-and-play splitter comes ready to connect right out of the package and requires no additional software or drivers. Its durable metal housing is designed to last a long time and fit seamlessly into any home or office application. Specifications 1/4 ● Source device with HDMI output ● Up to 4 display devices with HDMI input Package Includes ● B118-004-UHD 4K 4-Port HDMI Splitter ● External power supply w/NEMA 1-15P plug and 4 ft. cord (Input: 100-240V, 50/60 Hz, 0.35A; Output: 5V 2A) ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332183897 Technology HDMI Host Connector HDMI (FEMALE) VIDEO Max Supported Video Resolution 4K @ 30Hz (3840 x 2160) Max. Distance (Between any 2 Units) 10ft (3m) Max Number of Ports (Entire Chain) 256 Max Supported Color Depth 36-bit Deep Color 3D Video Supported Yes AUDIO Audio Specification DTS-HD, Dolby TrueHD, Dolby Digital Plus and LPCM 7.1 Channel Surround Sound INPUT Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Bus Powered No Product Length (in.) 6.06 Product Length (ft.) 0.51 POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.35A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4 External Power Supply Cord Length (m.) 1.2 AC Adapter Input: 100-240V, 50/60Hz, 1.5A; Output: 5V, 2A, 4 ft. DC Barrel Plug OD: 3.5 x 1.35 x 7.5mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 3.3 USER INTERFACE, ALERTS & CONTROLS LED Indicators Red (Power), Blue (1, 2, 3, 4) 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Black Material of Construction Metal Rackmountable No Shipping Dimensions (hwd / in.) 2.60 x 10.00 x 7.90 Shipping Dimensions (hwd / cm) 6.60 x 25.40 x 20.07 Shipping Weight (lbs.) 1.52 Shipping Weight (kg) 0.69 Unit Dimensions (hwd / in.) 0.870 x 6.100 x 2.700 Unit Packaging Type Box Unit Weight (lbs.) 0.6 Unit Weight (kg) 0.27 ENVIRONMENTAL Operating Temperature Range 32 to 158 °F (0 to 70 °C) Storage Temperature Range 14 to 176 °F (-10 to 80 °C) BTUs 11.3 BTU/Hr Operating Humidity Range 10% to 85 % RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes CONNECTIONS Number of Ports 4 Side A - Connector 1 HDMI (FEMALE) Side B - Connector 1 (4) HDMI (FEMALE) PORT EXPANSION Daisy-chainable or Cascadable Cascadable FEATURES & SPECIFICATIONS HDCP Specification 1.3 Driver Required No STANDARDS & COMPLIANCE External Power Supply Certifications CE; ETL; UL 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B118-004-UHD 价格&库存
很抱歉,暂时无法提供与“B118-004-UHD”相匹配的价格&库存,您可以联系我们找货
