1000 Eaton Boulevard
Cleveland, OH 44122
United States
VGA with Audio over Cat5/Cat6 Extender,
Receiver, USB-Powered, 1920x1080 60 Hz, Up to
750 ft. (228 m), TAA
MODEL NUMBER: B132-100A-MR
Highlights
Extends a 1920 x 1080 video
and audio signal up to 300-ft.
(91.44 m), or a 1024 x 768 video
and audio signal up to 750-ft.
(228.6 m)
EDID copy feature stores the
monitor's EDID information and
sends it to the connected
computer, ensuring optimal
display compatibility
Power is supplied via the
included USB Micro-B cables;
no external power supplies
required
Plug and play, no software or
drivers required
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases.
Package Includes
B132-100A-MR
USB Micro-B cable
Extends a VGA video and audio signal up to 750-ft. (230M) from the source
Screwdriver for EQ/Gain
adjustment
Description
Owner's Manual
Tripp Lite's B132-100A-MR VGA with Audio over Cat5 Extender Receiver Unit is designed to work with
Tripp Lite's B132-002A-2 and B132-004A-2 VGA with Audio over Cat5 Extender / Splitter Transmitter
Units. Unlike the B132-100A Receiver Unit, which supports distances up to 1,000-ft, the B132-100A-MR is
a cost effective solution for distances up to 750-ft. (228.6 m) It extends a 1920 x 1080 video and audio
signal up to 300-ft. (91.44 m) from the source, or a 1024 x 768 video and audio signal up to 750-ft. (228.6
m). Power is supplied via the included USB Micro-B cable, with no external power supply required.
Connect the included Micro-B cables between the Receiver and a USB port on a computer, monitor, or
USB wall charger, such as the Tripp Lite U280-W01-QC3. It also features equalization and gain controls
to adjust the video image. Audio connections are made with standard 3.5mm stereo cables (not included).
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases.
Features
Works with a B132-002A-2 or B132-004A-2 local unit to extend a VGA video and audio signal up to
750-ft. (228.6 m) from the source
Extends a 1920 x 1080 video and audio signal up to 300-ft. (91.44 m), or a 1024 x 768 video and audio
signal up to 750-ft. (228.6 m)
24AWG, Solid Wire Cat5e/6 cable (such as Tripp Lite's N202-Series Cat6 cables) is required to achieve
maximum distance and resolution
Power is supplied via the included USB Micro-B cable; no external power supply required
Features built-in equalization and gain controls to adjust the video image.
All operating systems supported
Plug and play; no software or drivers required
HDCP and EDID compliant
Ideal for digital signage installations for retail, schools, churches, etc.
1/4
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332185556
Product Type
Receiver
Technology
VGA/SVGA; Stereo Audio; Cat5/5e; Cat6
VIDEO
Max Supported Video Resolution
1920x1080 (1080p @ 60Hz)
Max 720P Range (ft)
300
Max 1080P Range (ft)
300
Max 1280 x 720 (720p) Range (ft)
300
Max 1920 x 1080 (1080p) Range (ft)
300
Receiver/Transceiver Video Output
VGA
Receiver - Number of Video Outputs
1
Range Extension using other Tripp
Lite product
1000ft @ 1024 x 768 (60Hz) 500ft @ 1920 x 1440 (60Hz)
Recommended Cabling
Solid Wire Cat6 Cables (Tripp Lite's N202-Series)
Other Tripp Lite product used to
extend range
B132-110A
HDR Support
No
3D Video Supported
No
Maximum Signal Range (ft)
750
Maximum Signal Range (m)
229
Maximum Signal Range Details
750 ft @ 1024 x 768 (60Hz)300 ft @ 1920 x 1080 (60Hz)
AUDIO
Audio Output
3.5mm
Audio Specification
Stereo Audio
INPUT
Bus Powered
No
POWER
Power Source Type
USB
Power Source
Unit (Included)
2/4
Cleveland, OH 44122
United States
Power Over Cable (PoC) Support
No
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Red (Green); Orange (Activity, EDID)
PHYSICAL
Color
Black
Number of Displays
1
Form Factor/Mounting Options
Pigtail
Shipping Dimensions (hwd / in.)
1.60 x 4.60 x 6.10
Shipping Dimensions (hwd / cm)
4.06 x 11.68 x 15.49
Shipping Weight (lbs.)
0.30
Shipping Weight (kg)
0.14
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Dimensions (hwd / cm)
2.54 x 6.35 x 9.14
Unit Packaging Type
Box
Unit Weight (lbs.)
0.1
Unit Weight (kg)
0.05
Housing
Metal
ENVIRONMENTAL
Operating Temperature Range
32 to 122 F (0 to 50 C)
Storage Temperature Range
-4 to 158 (-20 to 70 C)
Relative Humidity
10% to 90% RH, Non-Condensing
COMMUNICATIONS
Max 1024 x 768 Range (ft)
750
Max 480P Range (ft)
750
Max 1440 x 900 Range (ft)
300
Max 1080i Range (ft)
300
Max 480i Range (ft)
750
Max 640 x 480 Range (ft)
750
Max 800 x 600 Range (ft)
750
Max 1600 x 1200 Range (ft)
300
EDID Compatible
Yes
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
3/4
Cleveland, OH 44122
United States
Consumer Electronics Control (CEC)
Supported
No
USB Extension Support
No
CONNECTIONS
Number of Ports
1
Side A - Connector 1
RJ45 (FEMALE)
Side B - Connector 1
HD15 (MALE)
Side B - Connector 2
3.5MM (FEMALE)
FEATURES & SPECIFICATIONS
Driver Required
No
10/100 Ethernet Extension Support
No
Built-In Equalizer
Yes
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“B132-100A-MR”相匹配的价格&库存,您可以联系我们找货
