B140-101
B140-101
    TRIPPLITE
    DVIEXTENDERCAT5/6100FT
B140-101 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DVI over Cat5/6 Passive Extender Kit, Box-Style Transmitter/Receiver for Video, Up to 100 ft. (30 m), TAA Highlights ● Extender kit comes with transmitter and receiver units ● Supports DVI-D Single-Link video resolutions up to 1920 x 1080 @ 60Hz ● Extends a 1920 x 1080 @ 60Hz signal up to 50-ft. (15.24 m), or a 1024 x 768 @ 60Hz signal up to 100-ft. (30.5 m) ● Use 24AWG, Solid Wire Cat5e/6 cable, such as Tripp Lite's N202-Series, to achieve maximum distance and resolution ● Compatible with all operating systems ● Plug and play, no external power, software or drivers required ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B140-101 Transmit a DVI-D Single-Link signal up to 100 ft. away using a single Cat5e/6 patch cable Description The B140-101 is a DVI over Cat5 Passive Extender kit, which comes with both transmitter and receiver units. It transmits a DVI-D Single-Link signal up to 100-ft. (30.5 m) away using a single Cat5e/6 patch cable. To achieve maximum distance and resolution, use 24AWG Solid Wire Cat5e/6 cable (Tripp Lite's N202-Series). The B140-101 is compatible with all operating systems, and is plug and play, with no external power, software or drivers required.Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Installation is simple. Connect the built-in DVI connector on the transmitter unit to the source. Connect the built-in DVI connector on the receiver unit to a display. Finally, the RJ45 ports on the transmitter and receiver units are connected using a single Cat5e/6 cable. A 1920 x 1080 @ 60Hz signal can be extended up to 50-ft. (15.24 m) from the source,, or a 1024 x 768 @ 60Hz signal up to 100-ft. (30.5 m) Features ● Extender kit comes with transmitter and receiver units ● Transmit a DVI-D Single-Link signal up to 100-ft. (30.5 m) away using a single Cat5e/6 patch cable ● Supports DVI-D Single-Link video resolutions up to 1920 x 1080 @ 60Hz ● Extends a 1920 x 1080 @ 60Hz signal up to 50-ft. (15.24 m), or a 1024 x 768 @ 60Hz signal up to 100ft. (30.5 m) ● Use 24AWG, Solid Wire Cat5e/6 cable, such as Tripp Lite's N202-Series, to achieve maximum distance and resolution ● HDCP compatible ● Compatible with all operating systems ● Plug and play; no external power, software or drivers required ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications 1/4 Package Includes ● B140-101 local transmitter unit ● B140-101 remote receiver unit ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332154088 Product Type Extender Kit Technology DVI; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 720P Range (ft) 100 Max 1080P Range (ft) 50 Max 1280 x 720 (720p) Range (ft) 50 Max 1920 x 1080 (1080p) Range (ft) 50 Transmitter Video Input DVI-D (Single Link) Transmitter - Number of Video Outputs 1 Receiver/Transceiver Video Output DVI-D (Single Link) Receiver - Number of Video Outputs 1 Range Extension using other Tripp Lite product 175ft @ 1024 x 768 XGA 125ft @ 1920 x 1080 UXGA Recommended Cabling N202-Series Cat6 Patch Cable Other Tripp Lite product used to extend range B140-110 HDR Support No 3D Video Supported Yes Maximum Signal Range (ft) 100 Maximum Signal Range (m) 30 Maximum Signal Range Details 100 ft @ 1024 x 768 XGA50 ft @ 1920 x 1080 UXGA INPUT Bus Powered No POWER Power Over Cable (PoC) Support No USER INTERFACE, ALERTS & CONTROLS LED Indicators TX & RX: Power (Green); Activity (Orange) PHYSICAL Color Black 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Number of Displays 1 Form Factor/Mounting Options Pigtail Receiver Unit Dimensions (hwd / in.) 1.36 x 0.94 x 14.16 Receiver Unit Weight (lbs.) 0.14 Shipping Dimensions (hwd / in.) 1.70 x 7.90 x 5.60 Shipping Dimensions (hwd / cm) 4.32 x 20.07 x 14.22 Shipping Weight (lbs.) 0.44 Shipping Weight (kg) 0.20 Transmitter Unit Dimensions (hwd / in.) 1.36 x 0.94 x 14.16 Transmitter Unit Weight (lbs.) 0.14 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Housing Plastic ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 100 Max 480P Range (ft) 100 Max 1440 x 900 Range (ft) 100 Max 1080i Range (ft) 50 Max 480i Range (ft) 100 Max 640 x 480 Range (ft) 100 Max 800 x 600 Range (ft) 100 Max 1600 x 1200 Range (ft) 100 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Number of Ports 1 Side A - Connector 1 DVI-D SINGLE LINK (MALE) Side A - Connector 2 RJ45 (FEMALE) Side B - Connector 1 DVI-D SINGLE LINK (MALE) Side B - Connector 2 RJ45 (FEMALE) FEATURES & SPECIFICATIONS Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B140-101 价格&库存
很抱歉,暂时无法提供与“B140-101”相匹配的价格&库存,您可以联系我们找货
