1000 Eaton Boulevard
Cleveland, OH 44122
United States
2-Port Mini DisplayPort to DVI Hub, DP1.2, TAA
Highlights
Supports video resolutions up to
1920 x 1080 @ 60 Hz
Included USB Micro-B cable
supplies power to unit
Works with all operating
systems
Compact enough for easy
carrying in backpack or laptop
bag
Plug and play—no software or
drivers required
MODEL NUMBER: B155-002-DVI
Package Includes
Converts and splits a Mini DisplayPort video signal for display on two DVI monitors, projectors or
televisions at the same time. Ideal for offices, conference rooms, retail settings, trade shows and
classrooms.
Description
The B155-002-DVI 2-Port Mini DisplayPort to DVI Splitter converts and splits a Mini DisplayPort video
signal for display on two DVI-enabled monitors, projectors or televisions at the same time. Ideal for offices,
conference rooms, retail settings, trade shows and classrooms, this compact splitter features a built-in
Mini DisplayPort cable that connects to the source. It lets you use your existing DVI displays instead of
buying new Mini DisplayPort monitors or docking stations.
The B155-002-DVI supports video resolutions up to 1920 x 1080 (1080p) at 60 Hz, as well as HDCP,
EDID and DDC. Orange LEDs next to each output port indicate whether the splitter is powered on and
transmitting a signal to the connected displays. The splitter works with all operating systems and is small
enough to carry in your backpack or computer bag. Plug-and-play convenience means no software or
drivers are needed. An included USB Micro-B cable connects between the source and the splitter to
provide power, so no external power supply is required.
Features
Converts and Splits Mini DisplayPort Signal to 2 DVI Displays Simultaneously
● Ideal for offices, conference rooms, trade shows and classrooms
Built-in Mini DisplayPort cable connects to source
Included USB Micro-B cable supplies power to splitter
Save money on new Mini DisplayPort displays or docking stations
Top-Shelf Performance
● Supports video resolutions up to 1920 x 1080 (1080p) @ 60 Hz
Complies with HDCP, EDID and DDC
1/3
USB Micro-B cable, 3 ft.
Owner’s manual
Cleveland, OH 44122
United States
LEDs indicate whether splitter is powered on and transmitting signal to connected displays
Easy to Use Almost Anywhere
● Works with all operating systems
Plug and play—no software, drivers or external power supply required
Compact unit fits easily in backpack or computer bag
Specifications
OVERVIEW
UPC Code
037332191274
Technology
DVI; DisplayPort
VIDEO
Max Supported Video Resolution
1080p @ 60 Hz (1920 x 1080)
Max Supported Color Depth
24-bit True Color
3D Video Supported
Yes
INPUT
Bus Powered
Yes
POWER
Power Consumption (Watts)
4.1
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
(x2) Orange (Monitor Signal)
PHYSICAL
Color
Black
Material of Construction
Plastic
Rackmountable
No
Shipping Dimensions (hwd / in.)
1.70 x 7.90 x 5.60
Shipping Dimensions (hwd / cm)
4.32 x 20.07 x 14.22
Shipping Weight (lbs.)
0.60
Shipping Weight (kg)
0.27
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Dimensions (hwd / cm)
2.55 x 7.6 x 6.15
Unit Dimensions (hwd / mm)
61.5 x 76 x 25.5
2/3
Cleveland, OH 44122
United States
Unit Packaging Type
Box
Unit Weight (lbs.)
0.154
Unit Weight (kg)
0.07
ENVIRONMENTAL
Operating Temperature Range
14 to 167 °F (-10 to 75 °C)
Storage Temperature Range
-4 to 176 °F (-20 to 80 °C)
Relative Humidity
0% to 85%, Non-Condensing
BTUs
14 BTU/Hr
COMMUNICATIONS
EDID Compatible
Yes
CONNECTIONS
Number of Ports
2
Side A - Connector 1
MINI DISPLAYPORT (MALE)
Side A - Connector 2
MICRO-USB B (FEMALE)
Side B - Connector 1
(2) DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK)
Connector Plating
Nickel
Contact Plating
Gold
FEATURES & SPECIFICATIONS
Displayport Specification
1.2
HDCP Specification
1.3
Driver Required
No
MST Support
No
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“B155-002-DVI”相匹配的价格&库存,您可以联系我们找货
