B157-002-DVI
B157-002-DVI
    TRIPPLITE
    SPLITTERDISPLAYPORTTODVI2PRT
B157-002-DVI 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2-Port DisplayPort to DVI Hub, DP1.2, TAA Highlights ● Supports video resolutions up to 1080p @ 60 Hz (1920 x 1080) ● Included USB Micro-B cable supplies power to unit ● Works with all operating systems ● Compact enough for easy carrying in backpack or laptop bag ● Plug and play—no software or drivers required MODEL NUMBER: B157-002-DVI Package Includes Converts and splits a DisplayPort video signal for display on two DVI monitors, projectors or televisions at the same time. Ideal for offices, conference rooms, retail settings, trade shows and classrooms. Description The B157-002-DVI 2-Port DisplayPort to DVI Splitter converts and splits a DisplayPort video signal for display on two DVI-enabled monitors, projectors or televisions at the same time. Ideal for offices, conference rooms, retail settings, trade shows and classrooms, this compact splitter features a built-in DisplayPort cable that connects to the source. It lets you use your existing DVI displays instead of buying new DisplayPort monitors or docking stations. The B157-002-DVI supports video resolutions up to 1080p @ 60 Hz (1920 x 1080), as well as HDCP, EDID and DDC. Orange LEDs next to each output port indicate whether the splitter is powered on and transmitting a signal to the connected displays. The splitter works with all operating systems and is small enough to carry in your backpack or computer bag. Plug-and-play convenience means no software or drivers are needed. An included USB Micro-B cable connects between the source and the splitter to provide power, so no external power supply is required. Features Converts and Splits DisplayPort Signal to 2 DVI Displays SimultaneouslyIdeal for offices, conference rooms, trade shows and classroomsBuilt-in DisplayPort cable connects to sourceIncluded USB Micro-B cable supplies power to splitterSave money on new DisplayPort displays or docking stations Top-Shelf PerformanceSupports video resolutions up to 1080p @ 60 Hz (1920 x 1080)Complies with HDCP, EDID and DDCLEDs indicate whether splitter is powered on and transmitting signal to connected displays Easy to Use Almost AnywhereWorks with all operating systemsPlug and play—no software, drivers or external power supply requiredCompact unit fits easily in backpack or computer bag Specifications OVERVIEW UPC Code 037332191298 Technology DVI; DisplayPort 1/3 ● B157-002-DVI 2-Port DisplayPort to DVI Splitter ● USB Micro-B cable, 3 ft. ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Host Connector DISPLAYPORT (FEMALE) VIDEO Max Supported Video Resolution 1080p @ 60 Hz (1920 x 1080) Max Supported Color Depth 24-bit True Color USER INTERFACE, ALERTS & CONTROLS LED Indicators (x2) Orange (Monitor Signal) PHYSICAL Color Black Material of Construction Plastic Wire Gauge (AWG) 28 Shipping Dimensions (hwd / in.) 1.70 x 7.90 x 5.60 Shipping Dimensions (hwd / cm) 4.32 x 20.07 x 14.22 Shipping Weight (lbs.) 0.60 Shipping Weight (kg) 0.27 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 2.55 x 6.15 x 7.6 Unit Dimensions (hwd / mm) 25.5 x 61.5 x 76 Unit Packaging Type Box Unit Weight (lbs.) 0.154 Unit Weight (kg) 0.07 COMMUNICATIONS EDID Compatible Yes CONNECTIONS Number of Ports 2 Side A - Connector 1 DISPLAYPORT (MALE) Side A - Connector 2 MICRO-USB B (FEMALE) Side B - Connector 1 (2) DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK) Connector Plating Nickel FEATURES & SPECIFICATIONS Displayport Specification 1.2 HDCP Specification 1.3 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States MST Support No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
B157-002-DVI 价格&库存
很抱歉,暂时无法提供与“B157-002-DVI”相匹配的价格&库存,您可以联系我们找货
