B132-100A
B132-100A
    TRIPPLITE
    VGAEXTENDERW/AUDIO1000FT
B132-100A 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States VGA over Cat5/6 Extender, Box-Style Receiver for Video/Audio, Up to 1000 ft. (305 m), TAA Highlights ● Works with a B132-002A-2 or B132-004A-2 local unit to extend a 1920 x 1440 (60Hz) Video and Audio signal up to 500 ft., or a 1024 x 768 (60Hz) Video and Audio signal up to 1,000 ft. ● 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N22201K-GY (Cat6), is required to achieve maximum distance and resolution ● For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P524-01K ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B132-100A System Requirements Features ● Works with a B132-002A-2 or B132-004A-2 local unit to extend a 1920 x 1440 (60Hz) Video and Audio signal up to 500 ft., or a 1024 x 768 (60Hz) Video and Audio signal up to 1,000 ft. ● 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6), is required to achieve maximum distance and resolution ● For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P52401K ● Features built-in Equalization and Gain controls to adjust the video image ● Includes mounting hardware that allows unit to be wallmounted, rackmounted or pole mounted ● Ideal for digital signage situations, such as retail, schools, churches, etc.. ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases ● 1 year limited waranty. Specifications OVERVIEW UPC Code 037332148773 Product Type Receiver Technology VGA/SVGA; Stereo Audio; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920x1440 @ 60Hz Max 720P Range (ft) 500 Max 1080P Range (ft) 500 1/4 Package Includes ● Extender remote (Receiver) unit ● Mini-Screwdriver for EQ/Gain adjustment ● Mounting Hardware ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft.) ● Owner’s Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Max 1280 x 720 (720p) Range (ft) 500 Max 1920 x 1080 (1080p) Range (ft) 500 Max 1920 x 1200 Range (ft) 500 Receiver/Transceiver Video Output VGA Receiver - Number of Video Outputs 1 Range Extension using other Tripp Lite product 1000ft @ 1024 x 768 (60Hz) 500ft @ 1920 x 1440 (60Hz) Recommended Cabling Solid Wire Cat6 Cables (Tripp Lite's N202-Series) Other Tripp Lite product used to extend range B132-110A HDR Support No 3D Video Supported No Maximum Signal Range (ft) 1000 Maximum Signal Range (m) 305 Maximum Signal Range Details 1000 ft @ 1024 x 768 (60Hz)500 ft @ 1920 x 1440 (60Hz) AUDIO Audio Output 3.5mm Audio Specification Stereo Audio INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.38 AC Plug Type NEMA 1-15P Power Source Unit (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States USER INTERFACE, ALERTS & CONTROLS LED Indicators Red (Power); RJ45: Green (Connection), Orange (Data Transmission) PHYSICAL Color Black Included Mounting Accessories Wallmount Number of Displays 1 Optional Mounting Accessory Notes Can DIN Mount using Tripp Lite Bracket  B110-DIN-02  Form Factor/Mounting Options Box; Wall-mount Shipping Dimensions (hwd / in.) 2.20 x 7.20 x 6.50 Shipping Dimensions (hwd / cm) 5.59 x 18.29 x 16.51 Shipping Weight (lbs.) 1.00 Shipping Weight (kg) 0.45 Unit Dimensions (hwd / in.) 1.000 x 2.500 x 3.600 Unit Dimensions (hwd / cm) 2.54 x 6.35 x 9.14 Unit Packaging Type Box Unit Weight (lbs.) 0.45 Unit Weight (kg) 0.20 Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 122 F (0 to 50 C) Storage Temperature Range -4 to 158 (-20 to 70 C) Relative Humidity 10% to 90% RH, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 1000 Max 480P Range (ft) 1000 Max 1440 x 900 Range (ft) 500 Max 1080i Range (ft) 500 Max 1920 x 1440 Range (ft) 500 Max 480i Range (ft) 1000 Max 640 x 480 Range (ft) 1000 Max 800 x 600 Range (ft) 1000 Max 1600 x 1200 Range (ft) 500 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported No USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 HD15 (FEMALE) Side B - Connector 2 3.5MM (FEMALE) FEATURES & SPECIFICATIONS Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer Yes STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B132-100A 价格&库存
很抱歉,暂时无法提供与“B132-100A”相匹配的价格&库存,您可以联系我们找货
