B165-101
B165-101
    TRIPPLITE
    RS-232SERIALOVERCAT5EXTKIT
B165-101 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Serial over Cat5/Cat6 RS232 Extender, Transmitter and Receiver, Up to 3280 ft. (999.74 m), TAA Highlights ● Locates an RS-232 Serial device up to 3280-ft. (999.74 m) from your system ● Supports full-duplex, 3 pin, data communication (signal ground, transmit data line, and receive data line) ● No software or drivers required...Plug-n-Play ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B165-101 Package Includes Description Tripp Lites B165-101 RS232 Serial over Cat5 Extender Kit is a low cost solution that provides remote access and control of any RS232 protocol device. The B165-101 extends control of a serial device to over 3280-ft. (999.74 m). Supports full-duplex, 3 pin, data communication (signal ground, transmit data line, and receive data line). Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Features ● Locates an RS-232 Serial device up to 1,000 Meters from your system ● Supports full-duplex, 3 pin, data communication (signal ground, transmit data line, and receive data line) ● No software or drivers required...Plug-n-Play ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases ● Supported Baud Rates: 110, 1200, 9600, 19200, 38400, 57600, 115200 (max) Specifications OVERVIEW UPC Code 037332155474 Product Type Cat5/Cat6 Extender Kit VIDEO HDR Support No Maximum Signal Range (ft) 3280 Maximum Signal Range (m) 1,000 1/2 ● B165-101 Local Transmitter Unit ● B165-101 Remote Receiver Unit ● 2 External Power Supplies with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A) ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States POWER Power Over Cable (PoC) Support No AC Adapter (x2) Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A PHYSICAL Color Black Shipping Dimensions (hwd / in.) 2.00 x 6.30 x 8.30 Shipping Dimensions (hwd / cm) 5.08 x 16.00 x 21.08 Shipping Weight (lbs.) 0.90 Shipping Weight (kg) 0.41 COMMUNICATIONS IR Remote Extension Support No RS-232 Serial Extension Support Yes USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 DB9 (FEMALE) Side A - Connector 2 RJ45 (FEMALE) Side B - Connector 1 DB9 (FEMALE) Side B - Connector 2 RJ45 (FEMALE) STANDARDS & COMPLIANCE Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B165-101 价格&库存
很抱歉,暂时无法提供与“B165-101”相匹配的价格&库存,您可以联系我们找货
