B132-200A-SR
B132-200A-SR
    TRIPPLITE
    VGAEXTDRDUALW/AUDIO300FT
B132-200A-SR 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Dual VGA with Audio over Cat5/Cat6 Extender, Box-Style Receiver, 1440x900 60 Hz, Up to 300 ft. (90 m), TAA Highlights ● Features dual VGA and audio ports for the connection of two sets of monitors and speakers ● Works with a B132-002A-2 or B132-004A-2 Transmitter Unit to extend a VGA video and audio signal up to 300-ft. from the source ● Extends a 1440 x 900 video and audio signal up to 150-ft, or a 1024 x 768 video and audio signal up to 300-ft. ● Plug and play, no software or drivers required ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. MODEL NUMBER: B132-200A-SR Package Includes ● B132-200A-SR ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A, 4.5 ft.) ● Screwdriver for EQ adjustment ● Owner's Manual Extends a VGA and audio signal to two sets of monitors and speakers up to 300-ft. from the source Features ● Features dual VGA and audio ports for the connection of two sets of monitors and speakers ● Works with a B13 or B13 Transmitter Unit to extend a VGA video and audio signal up to 300-ft. from the source ● Extends a 1440 x 900 video and audio signal up to 150-ft, or a 1024 x 768 video and audio signal up to 300-ft. ● 24AWG, Solid Wire Cat5e/6 cable (such as Tripp Lite's N20 Cat6 cables) is required to achieve maximum distance and resolution ● Features a built-in equalization control to adjust the video image ● All operating systems supported ● Plug and play; no software or drivers required ● HDCP and EDID compliant ● Ideal for digital signage installations for retail, schools, churches, etc. ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332185570 Product Type Receiver Technology VGA/SVGA; Stereo Audio; Cat5/5e; Cat6 Host Connector RJ45 (FEMALE) 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States VIDEO Max Supported Video Resolution 1440x900 @ 60Hz Max 720P Range (ft) 150 Max 1280 x 720 (720p) Range (ft) 150 Receiver/Transceiver Video Output VGA Receiver - Number of Video Outputs 2 Recommended Cabling Solid Wire Cat6 Cables (Tripp Lite's N202-Series) HDR Support No 3D Video Supported No Maximum Signal Range (ft) 300 Maximum Signal Range (m) 91 Maximum Signal Range Details 300 ft @ 1024 x 768 (60Hz)150 ft @ 1440 x 900 (60Hz) AUDIO Audio Output 3.5mm Audio Specification Stereo Audio INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.38 AC Plug Type NEMA 1-15P Power Source Unit (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 4.5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States LED Indicators Red (Power) RJ45: Green (Connection), Orange (Data Transmission) PHYSICAL Color Black Included Mounting Accessories Wallmount Number of Displays 2 Form Factor/Mounting Options Box; Wall-mount Shipping Dimensions (hwd / in.) 2.20 x 6.20 x 7.20 Shipping Dimensions (hwd / cm) 5.59 x 15.75 x 18.29 Shipping Weight (lbs.) 1.10 Shipping Weight (kg) 0.50 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 2.7 x 11.5 x 6.24 Unit Packaging Type Box Unit Weight (lbs.) 0.5 Unit Weight (kg) 0.23 Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 122 F (0 to 50 C) Storage Temperature Range -4 to 158 (-20 to 70 C) Relative Humidity 10% to 90% RH, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 300 Max 480P Range (ft) 300 Max 1440 x 900 Range (ft) 150 Max 480i Range (ft) 300 Max 640 x 480 Range (ft) 300 Max 800 x 600 Range (ft) 300 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported No USB Extension Support No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States CONNECTIONS Number of Ports 2 Side A - Connector 1 RJ45 (FEMALE) Side B - Connector 1 (2) HD15 (FEMALE) FEATURES & SPECIFICATIONS Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer Yes STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B132-200A-SR 价格&库存
很抱歉,暂时无法提供与“B132-200A-SR”相匹配的价格&库存,您可以联系我们找货
