B118-004-UHD-WM
B118-004-UHD-WM
    TRIPPLITE
    4-PORTHIGHSPEEDHDMISPLITTER
B118-004-UHD-WM 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port Wall-Mountable 4K HDMI Splitter for UltraHD (4Kx2K) Video and Audio - 3840x2160 @ 24/30Hz Highlights ● Supports Full 3D and video resolutions up to UHD 4Kx2K 3840 x 2160 (24Hz and 30Hz) ● Supports DTS-HD, Dolby True HD, Dolby Digital Plus and LPCM 7.1 Channel Surround Sound audio ● Plug and play; no software or drivers required MODEL NUMBER: B118-004-UHD-WM Package Includes Transmit a 4Kx2K HDMI signal from a single source to four displays Description Tripp Lite's B118-004-UHD-WM HDMI Splitter allows the 4K2K digital signal from a Blu-Ray player or other HDMI device to be displayed on two HDMI displays, or, connect a DVI-D Single Link display using an HDMI to DVI adapter, such as Tripp Lite's P566-Series cables. Installation is quick and simple, with no software or drivers to install. Locate your HDMI source up to 16.4 ft. (5 m.) from the splitter, and the splitter up to 16 ft. (5 m.) from a display, for a max distance of 23 ft. (7 m.) between splitter and display. Supports Full 3D and video resolutions up to UHD 4Kx2K 3840 x 2160 (24Hz and 30Hz). High Speed HDMI and 3D compliant, with support for 36-bit Deep Color (12-bits per channel). Supports DTS-HD, Dolby True HD, Dolby Digital Plus, and LPCM 7.1 Channel Surround Sound audio. HDCP and EDID compliant. Includes wall mounting hardware. Features ● Simultaneously transmit the video and audio from an HDMI source to multiple HDMI monitors ● Wall Mounting hardware included ● Supports Full 3D and video resolutions up to UHD 4Kx2K 3840 x 2160 (24Hz and 30Hz) ● Supports 36-bit Deep Color (12-bits per channel) ● Supports DTS-HD, Dolby True HD, Dolby Digital Plus and LPCM 7.1 Channel Surround Sound audio ● Supports video amplifier bandwidth of 340MHz / 3.4Gbps per channel (10.2Gbps total) ● HDCP and EDID compatible ● Plug and play; no software or drivers required ● Supports Lip Sync pass-through ● Supports xvYCC and x.vColor ● Supports the use of DVI sources and displays with the use of an optional DVI to HDMI adapter (sold separately) 1/2 ● UHD 4Kx2K HDMI 4-port Wall Mountable Splitter ● External Power Supply with NEMA 1-15P Plug(Input: 100240V, 50/60Hz, 1.5A; Output: 5V, 3A, 4 ft.) ● Owner’s Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Supports a maximum distance of 16.4 ft. (5 m) from source to splitter, and 23 ft. (7 m) from splitter to display, for a total of up to 39.4 ft. (12 m) Specifications OVERVIEW UPC Code 037332183873 Technology HDMI POWER AC Adapter Input: 100-240V, 50/60Hz, 1.5A; Output: 5V, 3A, 4 ft. PHYSICAL Color Black Shipping Dimensions (hwd / in.) 2.60 x 7.60 x 9.80 Shipping Dimensions (hwd / cm) 6.60 x 19.30 x 24.89 Shipping Weight (lbs.) 1.50 Shipping Weight (kg) 0.68 CONNECTIONS Number of Ports 4 Side A - Connector 1 HDMI (FEMALE) Side B - Connector 1 (4) HDMI (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B118-004-UHD-WM 价格&库存
很抱歉,暂时无法提供与“B118-004-UHD-WM”相匹配的价格&库存,您可以联系我们找货
