1000 Eaton Boulevard
Cleveland, OH 44122
United States
4-Port HDMI Splitter for Video and Audio,
1920x1200 at 60Hz/1080p (HDMI F/4xF)
MODEL NUMBER: B118-004
Highlights
Display HD video resolutions up
to 1080p, and computer video
resolutions up to 1920 x 1200
Supports up to 36-bit Deep
Color (12-bits per channel)
High Speed HDMI v1.4 and 3D
compliant
Supports DTS-HD, Dolby True
HD and 7.1 Channel Surround
Sound audio
HDCP v1.4 and EDID compliant
Plug and play; No software or
drivers required
System Requirements
TV's with an available HDMI
port and a HDMI peripheral
device (e.g. Blu-Ray player,
DVR, etc.)
The cable connecting the HDMI
source to the splitter must be no
longer than 13 ft. (4 m.)
The cable connecting the splitter
to a HDMI monitor must be no
longer than 16 ft. (5 m.)
Transmit a HDMI signal from a single source to four displays
Description
Tripp Lite's B118-004, 4-Port HDMI Splitter allows the digital signal from a Blu-Ray player or other HDMI
device to be displayed on four HDMI displays. Connect a DVI-D Single Link display using an HDMI to DVI
Package Includes
adapter, such as Tripp Lite's P566-Series cables. Installation is quick and simple, with no software or
B118-004 4-Port HDMI Splitter
drivers to install. Locate your HDMI source up to 13 ft. (4 m.) from the splitter, and the splitter up to 16 ft.
External Power Supply with
NEMA 1-15P Plug( Input: 100240V, 50/60Hz, 0.5A; Output:
5V, 1.2A, 4.9 ft. )
Owners Manual
(5 m.) from a display, for a max distance of 29 ft. (9 m.) between source and display. Multiple splitters can
be cascaded together to connect additional monitors, with no more than 6 levels of splitters in all.
Supports HD video resolutions up to 1080p, and computer video resolutions up to 1920 x 1200. High
Speed HDMI v1.4 and 3D compliant, with support for 36-bit Deep Color (12-bits per channel). Supports
DTS-HD, Dolby True HD and 7.1 Channel Surround Sound audio. HDCP v1.4 and EDID compliant.
Features
Display HD video resolutions up to 1080p, and computer video resolutions up to 1920 x 1200
Supports up to 36-bit Deep Color (12-bits per channel)
High Speed HDMI v1.4 and 3D compliant
Supports DTS-HD, Dolby True HD and 7.1 Channel Surround Sound audio
Plug and play; No software or drivers required
Locate a monitor up to 29 ft. (9 m.) from a HDMI source; up to 13 ft. (4 m.) between the source and the
switch; up to 16 ft. (5 m.) between the switch and a monitor
Cascade multiple levels of splitters together to increase the number of connected monitors, with no
Connect a DVI-D Single Link display using an HDMI to DVI adapter, such as Tripp Lite's P566-Series
cables
1/4
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332181107
Technology
HDMI
VIDEO
Max Supported Video Resolution
1080p @60Hz
Max. Distance (Between any 2
Units)
16ft (5m)
Max Number of Ports (Entire Chain)
4096
Max Supported Color Depth
12-bit
3D Video Supported
Yes
AUDIO
Audio Specification
7.1 Surround Sound, Dolby True HD, DTS-HD, DSD
INPUT
Voltage Compatibility (VAC)
100; 110; 120; 127; 200; 208; 220; 230; 240
POWER
External Power Supply Plug(s)
NEMA 1-15P North America
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 0.8A
External Power Supply Output
Specs (V / A)
5V / 2A
External Power Supply Cord Length
(ft.)
5
(m.)
1.5
DC Barrel Plug
OD: 5.5 x 2.1 x 10mm, Positive Pin, Negative Sleeve
Power Consumption (Watts)
10
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Green (Input, Output 1, Output 2, Output 3, Output 4)
PHYSICAL
Color
Black
Material of Construction
Steel
Shipping Dimensions (hwd / in.)
2.10 x 5.60 x 8.00
2/4
Cleveland, OH 44122
United States
Shipping Dimensions (hwd / cm)
5.33 x 14.22 x 20.32
Shipping Weight (lbs.)
1.00
Shipping Weight (kg)
0.45
Unit Dimensions (hwd / in.)
0.900 x 4.400 x 3.000
Unit Dimensions (hwd / cm)
2.4 x 11.1 x 7.5
Unit Packaging Type
Box
Unit Weight (lbs.)
0.5
Unit Weight (kg)
0.23
ENVIRONMENTAL
Operating Temperature Range
32 to 104 F (0 to 40 C)
Storage Temperature Range
-4 to 158 F (-20 to 70 C)
Relative Humidity
5% to 90% RH, Non-Condensing
BTUs
34.1 BTU/Hr
COMMUNICATIONS
Signal Range (ft.)
16
Signal Range (m)
5
EDID Compatible
Yes
Consumer Electronics Control (CEC)
Supported
Yes
Latency
80ms
CONNECTIONS
Number of Ports
4
Side A - Connector 1
HDMI (FEMALE)
Side B - Connector 1
(4) HDMI (FEMALE)
Connector Plating
Gold
PORT EXPANSION
Daisy-chainable or Cascadable
Cascadeable
FEATURES & SPECIFICATIONS
HDCP Specification
1.4
Driver Required
No
STANDARDS & COMPLIANCE
External Power Supply Certifications
CE; FCC; UL; RoHS
3/4
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“B118-004”相匹配的价格&库存,您可以联系我们找货
