B116-002A
B116-002A
    TRIPPLITE
    DVISPLITTER2-PORT1920X1200
B116-002A 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2-Port DVI Splitter with Audio and Signal Booster, Single-Link 1920x1200 at 60Hz/1080p (DVI F/2xF), TAA MODEL NUMBER: B116-002A Highlights ● Transmits a DVI-D Single Link video signal and 3.5mm audio signal to two sets of DVI monitors and speakers ● Supports DVI Single Link computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p. ● Built-in signal booster extends the distance between the splitter and connected monitors past the 16-ft. (4.88 m) distance limitation ● Expand the number of connected monitors/speakers by cascading up to 3 levels of splitters together ● Supports HDCP, EDID and DDC ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases System Requirements Description With Tripp Lite's 2-Port DVI + Audio Splitter, you can transmit a DVI-D Single Link video signal and 3.5 mm. audio signal to two sets of monitors and speakers. Supports DVI Single Link computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p. The unit is HDCP, EDID, and DDC compatible. A built-in signal booster allows you to extend the distance between the splitter and connected monitors past the 16-ft. (4.88 m) distance limitation. For source video resolutions anywhere from 1600 x 1200 @ 60Hz to 1920 x 1200 @ 60Hz - The distance between the splitter and the connected monitor/speakers must not exceed 49-ft. (14.93 m). This distance can be extended by using a B120-000-SL DVI extender. The B120-000-SL can be located up to 65-ft. (19.81 m) from the splitter, and 16-ft. (4.88 m) from the connected monitor. For source video resolutions lower than 1600 x 1200 @ 60Hz - The distance between the splitter and the connected monitor/speakers must not exceed 65-ft. (19.81 m). This distance can be extended by using a B120-000-SL DVI extender. The B120-000-SL can be located up to 114-ft. (34.74 m) from the splitter, and 16-ft. (4.88 m.) from the connected monitor. The number of connected monitors/speakers can be expanded by cascading up to three levels of splitters. Plug and Play...no software or drivers required. Mounting hardware is included with the product, and allows it to be rackmounted, wallmounted or pole-mounted. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Features ● Transmit a DVI-D Single Link video signal and 3.5 mm. audio signal to two sets of monitors and speakers ● Supports DVI Single Link computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p ● HDCP, EDID, and DDC compatible ● Built-in signal booster allows you to extend the distance between the splitter and connected monitors past the 16-ft. (4.88 m) distance limitation ● The number of connected monitors/speakers can be expanded by cascading up to three levels of splitters ● Plug and Play...no software or drivers required. Mounting hardware is included with the product, and allows it to be rackmounted, wallmounted or pole-mounted ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases 1/4 ● Video graphics card with a DVID or DVI-I connector ● Monitors with a DVI-D or DVI-I connector ● Speakers and/or monitor with a 3.5 mm. audio connector Package Includes ● B116-002A ● Mounting Hardware ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5-ft. (1.52 m) ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332156747 Product Type Signal Booster Technology DVI; Stereo Audio Host Connector DVI-I (FEMALE) VIDEO Max Supported Video Resolution 1920 x 1200 @ 60 Hz Max 720P Range (ft) 80 Max 1080P Range (ft) 65 Max 1920 x 1200 Range (ft) 65 INPUT Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Product Length (in.) 4.53 Product Length (ft.) 0.38 POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.37 AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators Red (Power), Green (Signal/Connection) PHYSICAL Color Black 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Included Mounting Accessories Yes Rackmountable Yes Shipping Dimensions (hwd / in.) 7.00 x 2.40 x 6.40 Shipping Dimensions (hwd / cm) 17.78 x 6.10 x 16.26 Shipping Weight (lbs.) 1.10 Shipping Weight (kg) 0.50 Unit Dimensions (hwd / in.) 1.060 x 4.530 x 2.460 Unit Dimensions (hwd / cm) 2.8 x 11.4 x 6.4 Unit Packaging Type Box Unit Weight (lbs.) 0.5 Unit Weight (kg) 0.23 ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 20 to 90% Storage Humidity Range 20 to 90% COMMUNICATIONS Max 1024 x 768 Range (ft) 80 Max 480P Range (ft) 80 Max 1440 x 900 Range (ft) 80 Max 1080i Range (ft) 65 Max 480i Range (ft) 80 Max 640 x 480 Range (ft) 80 Max 800 x 600 Range (ft) 80 Max 1600 x 1200 Range (ft) 80 CONNECTIONS Number of Ports 2 Side A - Connector 1 DVI-I (FEMALE) Side A - Connector 2 3.5MM (FEMALE) Side B - Connector 1 (2) DVI-I (FEMALE) Side B - Connector 2 (2) 3.5MM (FEMALE) FEATURES & SPECIFICATIONS HDCP Specification 1.1 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE External Power Supply Certifications C-Tick; CCC; CE; FCC; GS; PSE; RoHS; TUV; UL; cUL Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B116-002A 价格&库存
很抱歉,暂时无法提供与“B116-002A”相匹配的价格&库存,您可以联系我们找货
