B140-002
B140-002
    TRIPPLITE
    CAT5 EXTENDER SPLITTER 4-PORT
B140-002 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2-Port DVI over Cat5/6 Splitter/Extender, BoxStyle Transmitter for Video, DVI-D Single Link, 200 ft. (60 m), TAA Highlights ● Transmits up to 200 ft. for digital signage in bars, offices, classrooms, trade shows, etc. ● Supports HD resolutions up to 1920 x 1080 (@ 60 Hz) for crystal-clear 1080p video ● Works in tandem with Tripp Lite B140-1A0 or B140-1P0 remote receiver ● Plug-and-play operation with no software required for easy, immediate installation ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B140-002 Applications Transmitter/splitter extends a DVI video signal via Cat6 cable to 2 projectors, monitors or HDTVs up to 200 ft. away. ● Displaying a digital menu from a PC on monitors in a restaurant or bar ● Connecting 2 HDTVs to the same cable box, media server or DVD player for sports or movies ● Giving a presentation on large projectors or monitors in a lecture hall ● Creating digital signage for an office lobby, healthcare waiting room, church, school, trade show, conference room, retail display or airport Features Splitter Ideal for Digital Signage or Displaying DVI Video in Schools or Trade Show BoothsThis two-port transmitter/splitter allows you to split a DVI-D single-link signal and extend it to two monitors beyond the normal 16-ft. (4.88 m) DVI limitation using inexpensive Cat5/6 cabling. The B140-002 is recommended for video presentations in conference rooms, schools, trade shows, meeting facilities, houses of worship, retail settings and other digital signage applications where the source and display are farther apart than conventional A/V cables allow. System Requirements Extend a DVI Video Signal up to 200-ft. (60.96 m) from the Source DeviceThe B140-002 extends video from a DVI source device to two DVI displays up to 200-ft. (60.96 m) away via user-supplied Cat5/Cat6 cabling (such as Tripp Lite's N202-Series 24 AWG cables, sold separately). Specifically, it can extend a 1024 x 768 (@ 60 Hz) resolution up to 200-ft. (60.96 m) and a 1920 x 1080 (@ 60 Hz) resolution up to 150-ft. (45.72 m) when used with an active remote unit (Tripp Lite B140-1A0 or B140-1A0-WP, sold separately). When used with a passive remote unit (Tripp Lite B140-1P0, sold separately), it can extend a 1024 x 768 (@ 60 Hz) resolution up to 100-ft. (30.5 m) and a 1920 x 1080 (@ 60 Hz) resolution up to 50ft. (15.24 m) Include a Tripp Lite Repeater to Expand the Range and Add More DisplaysConnect a B140-110 repeater unit (sold separately) to add up to four remote units (three repeaters and one active receiver) to each channel for a total of four displays per channel. An active receiver should be the last unit in a channel. A 1920 x 1080 (@ 60 Hz) signal can be extended up to 125-ft. (38.1 m) from each repeater to the next unit in the channel, while a 1024 x 768 (@ 60 Hz) can be extended up to 175-ft. (53.34 m) Plug-and-Play Operation for Quick Setup and Immediate UseThe included transmitter works right out of the box with no software required. Mounting hardware is included for installing the unit on a wall, pole or 19-inch rack. Its durable metal housing is designed to last a long time and fit seamlessly into any home or office application. The B140-002 is compatible with HDCP standards, all DVI video sources and all operating systems. TAA-Compliant for GSA Schedule PurchasesThe B140-002 is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. 1/4 ● Works in tandem with Tripp Lite B140-1A0 or B140-1P0 extender remote receiver or B140-1A0-WP-1 extender wall plate Package Includes ● B140-002 DVI over Cat5/Cat6 Splitter/Extender ● External power supply with 5-ft. (1.52 m) cord and NEMA 1-15P plug (Input: 100-240V, 50/60 Hz, 0.5A; Output: 5V 2A) ● Mounting hardware ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332156709 Product Type Transceiver Technology DVI; Cat5/5e; Cat6 Host Connector DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK) VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 720P Range (ft) 150 Max 1080P Range (ft) 150 Max 1280 x 720 (720p) Range (ft) 150 Max 1920 x 1080 (1080p) Range (ft) 150 Transmitter Video Input DVI-I Transmitter - Number of Video Outputs 2 Range Extension using other Tripp Lite product 175ft @ 1024 x 768 XGA 125ft @ 1920 x 1080 UXGA Recommended Cabling N202-Series Cat6 Patch Cable Other Tripp Lite product used to extend range B140-110 HDR Support No 3D Video Supported Yes Maximum Signal Range (ft) 200 Maximum Signal Range (m) 61 Maximum Signal Range Details 200 ft @ 1024 x 768 XGA150 ft @ 1920 x 1080 UXGA INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.4 AC Plug Type NEMA 1-15P Power Source Unit (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators RJ45: Green (Connection), Orange (Data Transmission) PHYSICAL Color Black Included Mounting Accessories Wallmount Number of Displays 2 Optional Mounting Accessory Notes Can DIN Mount using Tripp Lite Bracket  B110-DIN-02  Form Factor/Mounting Options Box; Wall-mount Shipping Dimensions (hwd / in.) 2.20 x 6.90 x 6.40 Shipping Dimensions (hwd / cm) 5.59 x 17.53 x 16.26 Shipping Weight (lbs.) 1.00 Shipping Weight (kg) 0.45 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 2.54 x 6.35 x 9.14 Unit Packaging Type Box Unit Weight (lbs.) 0.43 Unit Weight (kg) 0.20 Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 200 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Max 480P Range (ft) 200 Max 1440 x 900 Range (ft) 150 Max 1080i Range (ft) 150 Max 480i Range (ft) 200 Max 640 x 480 Range (ft) 200 Max 800 x 600 Range (ft) 200 Max 1600 x 1200 Range (ft) 150 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 2 Side A - Connector 1 DVI-I DUAL-LINK (FEMALE) (WIRED TO DVI-D SINGLE-LINK) Side B - Connector 1 (2) RJ45 (FEMALE) FEATURES & SPECIFICATIONS Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B140-002 价格&库存
很抱歉,暂时无法提供与“B140-002”相匹配的价格&库存,您可以联系我们找货
