B150-1A1-DVI
B150-1A1-DVI
    TRIPPLITE
    EXTENDERDIPLAYPORTTODVI125FT
B150-1A1-DVI 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DisplayPort to DVI over Cat5/6 Active Extender Kit, Pigtail Transmitter/Receiver for Video/Audio, 125 ft. (38 m) Highlights ● Supports high-definition video resolutions up to 1920 x 1080 (60 Hz) ● Supports 24-bit True Color (8 bits per channel) and stereo audio ● Included USB Micro-B cables supply power to both units ● Works with all operating systems ● Plug and play—no software or drivers to install ● HDCP 1.3 compliant MODEL NUMBER: B150-1A1-DVI System Requirements Transmitter and receiver work in tandem to convert a DisplayPort signal to DVI and extend it via Cat5e/6 cable to a projector, monitor or television up to 125 ft. away. Ideal for digital signs, schools and trade shows. Description The B150-1A1-DVI DisplayPort to DVI over Cat5/6 Active Extender Kit includes a transmitter unit and a receiver unit that work in tandem to convert a DisplayPort audio/video signal to DVI and then extend it to a projector, monitor or television up to 125-ft. (38.1 m) away. The kit is ideal for digital signs, trade shows, presentations, classrooms, churches, retail settings and other applications where the video source is located farther than convention cables allow. One Cat5e/6 cable connects the transmitter and receiver (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite’s N202-Series). A built-in DisplayPort plug connects the transmitter to the source, while a built-in DVI-D single-link plug connects the receiver to the display. Included USB Micro-B cables supply power to the units via USB ports on the source and display or USB wall chargers. Please note: In order to properly power the unit via an external source, a minimum of 500mA will be needed. Any type of power supply will work as well as any standard USB port that is USB 2.0 or newer. The B150-1A1-DVI can extend a high-definition 1920 x 1080 (60 Hz) signal up to 125-ft. (38.1 m). In addition to crystal-clear video, including 24-bit True Color (8 bits per channel), the kit delivers full, rich stereo. LEDs on the RJ45 ports indicate when the units are receiving power and a DVI signal from the source. Built-in equalization control lets you fine-tune the image on the DVI display. Easy to set up with no software or drivers to install. Compatible with all operating systems. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Features Converts DisplayPort Signal to DVI, Extends It Up to 125-ft. (38.1 m) ● Ideal for digital signs, trade shows, presentations, classrooms, churches and retail settings ● Extends a high-definition 1920 x 1080 (60 Hz) signal up to 125-ft. (38.1 m) ● Transmitter and receiver connect with one Cat5e/6 cable (for best results, use 24 AWG solid-wire Cat5e/6 cable, such as Tripp Lite's N202-Series) ● Supports 24-bit True Color (8 bits per channel) and stereo audio ● Built-in equalization control lets you adjust the image on the display ● HDCP 1.3 compliant 1/4 ● Computer with DisplayPort output port* ● Display with DVI-D input port Package Includes ● Transmitter unit ● Receiver unit ● Screwdriver for adjusting equalization ● (2) USB Micro-B cables, 3-ft. (0.91 m) ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Easy to Set Up and Use ● Plug-and-play engineering—no software or drivers to download and install ● Works with all operating systems ● Built-in cables connect transmitter to DisplayPort source and receiver to DVI-D display ● Included USB Micro-B cables provide power to the units ● LEDs indicate when the units are receiving power and sharing a signal TAA Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332191311 Product Type Extender Kit Technology DVI; DisplayPort; Cat5/5e; Cat6 VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 720P Range (ft) 150 Max 1080P Range (ft) 125 Max 1280 x 720 (720p) Range (ft) 125 Max 1920 x 1080 (1080p) Range (ft) 125 Transmitter Video Input DisplayPort Transmitter - Number of Video Outputs 1 Receiver/Transceiver Video Output DVI-D (Single Link) Receiver - Number of Video Outputs 1 Recommended Cabling Solid Wire Cat6 Cables (Tripp Lite's N202-Series) HDR Support No 3D Video Supported Yes Maximum Signal Range (ft) 125 Maximum Signal Range (m) 38 AUDIO Audio Input Displayport INPUT 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Bus Powered No POWER Power Source Type USB Power Source Transmitter and Receiver (Included) Power Over Cable (PoC) Support No USER INTERFACE, ALERTS & CONTROLS LED Indicators TX & RX: (x1) Green (Connection), (x1) Orange (Data transmission) PHYSICAL Color Black Number of Displays 1 Form Factor/Mounting Options Pigtail Receiver Unit Dimensions (hwd / in.) 2.4 x 0.94 x 2.04 Receiver Unit Weight (lbs.) 0.07 Shipping Dimensions (hwd / in.) 1.73 x 7.87 x 5.95 Shipping Dimensions (hwd / cm) 4.39 x 19.99 x 15.11 Shipping Weight (lbs.) 0.49 Shipping Weight (kg) 0.22 Transmitter Unit Dimensions (hwd / in.) 2.42 x 1 x 3 Transmitter Unit Weight (lbs.) 0.07 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Housing Plastic ENVIRONMENTAL Operating Temperature Range 32 to 122 °F (0 to 50 °C) Storage Temperature Range -40 to 158 °F (-40 to 70 °C) Relative Humidity 0% to 85%, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 150 Max 480P Range (ft) 150 Max 1440 x 900 Range (ft) 150 Max 1080i Range (ft) 150 Max 480i Range (ft) 150 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Max 640 x 480 Range (ft) 150 Max 800 x 600 Range (ft) 150 Max 1600 x 1200 Range (ft) 150 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 DISPLAYPORT (MALE) Side A - Connector 2 RJ45 (FEMALE) Side A - Connector 3 MICRO-USB B (FEMALE) Side B - Connector 1 DVI-D SINGLE LINK (MALE) Side B - Connector 2 RJ45 (FEMALE) Side B - Connector 3 MICRO-USB B (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS Displayport Specification 1.2 Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer Yes STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B150-1A1-DVI 价格&库存
很抱歉,暂时无法提供与“B150-1A1-DVI”相匹配的价格&库存,您可以联系我们找货
