1000 Eaton Boulevard
Cleveland, OH 44122
United States
VGA with Audio over Cat5/6 Extender, Box-Style
Remote Repeater, 1920x1440 60 Hz, Up to 1000ft. (305 m), TAA
Highlights
Both extends and expands your
Tripp Lite VGA + Audio over
Cat5 installation, allowing you to
locate multiple
monitors/speakers at different
points in a chain of up to 2,000
ft.
Up to 4 remote units (3
remote/repeaters and 1
receiver) can be connected
together, providing audio/video
to up to 4 remote
displays/speakers in a full chain
24Awg, Solid Wire Cat5e/6
cable, such as Tripp Lite's
N022-01K-GY (Cat5) and N22201K-GY (Cat6), is required to
achieve maximum distance and
resolution
For optimal image quality
between 500 and 1,000 ft., use
Zero-Skew cable, such as Tripp
Lite P524-01K
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
MODEL NUMBER: B132-110A
Features
Both extends and expands your Tripp Lite VGA + Audio over Cat5 installation, allowing you to locate
multiple monitors/speakers at different points in a chain of up to 2,000 ft..
Up to 4 remote units (3 remote/repeaters and 1 receiver) can be connected together, providing
audio/video to up to 4 remote displays/speakers in a full chain.
24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6),
is required to achieve maximum distance and resolution.
For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P52401K.
Extend a 1920 x 1440 (60Hz) video and audio signal up to 500 ft., or a 1024 x 768 (60Hz) video and
audio signal up to 1,000 ft., between the local transmitter and the first remote/repeater unit in the
installation.
Extend a 1920 x 1440 (60Hz) video and audio signal up to an additional 500 ft., or a 1024 x 768 (60Hz)
video and audio signal up to an additional 1,000 ft., from the first remote/repeater unit to the last set of
display and speakers in the installation.
Features built-in Equalization and Gain controls for video image adjustment.
Includes mounting hardware that allows wall mounting, rackmounting or pole mounting.
System Requirements
Computer with VGA video and
3.5mm audio outputs
Monitor / TV / Speakers with
VGA video and 3.5mm audio
inputs
A B132-002A-2 extender/splitter
local unit or a B130-101A-WP-2
extender kit
For international use, a power
supply with the appropriate plug
type must be purchased
separately.
Package Includes
B132-110A remote/repeater unit
External Power Supply with
NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output:
5V, 2A, 5 ft.)
Screwdriver for video
adjustment
Mounting hardware
Owner's manual
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases.
Specifications
1/5
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332161635
Product Type
Transceiver
Technology
VGA/SVGA; Stereo Audio; Cat5/5e; Cat6
VIDEO
Max Supported Video Resolution
1920x1440 @ 60Hz
Max 720P Range (ft)
500
Max 1080P Range (ft)
500
Max 1280 x 720 (720p) Range (ft)
500
Max 1920 x 1080 (1080p) Range (ft)
500
Max 1920 x 1200 Range (ft)
500
Receiver/Transceiver Video Output
VGA
Receiver - Number of Video Outputs
1
Recommended Cabling
Solid Wire Cat6 Cables (Tripp Lite's N202-Series)
HDR Support
No
3D Video Supported
No
Maximum Signal Range (ft)
1000
Maximum Signal Range (m)
305
Maximum Signal Range Details
1000 ft @ 1024 x 768 (60Hz)500 ft @ 1920 x 1440 (60Hz)
AUDIO
Audio Output
3.5mm
Audio Specification
Stereo Audio
INPUT
Bus Powered
No
POWER
Power Source Type
AC Adapter
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50-60Hz / 0.5A
External Power Supply Output
Specs (V / A)
5V/2A
External Power Supply Cord Length
(ft.)
4.5
(m.)
1.38
2/5
Cleveland, OH 44122
United States
AC Plug Type
NEMA 1-15P
Power Source
Unit (Included)
Power Over Cable (PoC) Support
No
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft.
DC Barrel Plug
OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Red (Power) RJ45: Green (Connection), Orange (Data Transmission)
PHYSICAL
Color
Black
Included Mounting Accessories
Wallmount
Number of Displays
1
Optional Mounting Accessory Notes
Can DIN Mount using Tripp Lite Bracket B110-DIN-01
Form Factor/Mounting Options
Box; Wall-mount
Shipping Dimensions (hwd / in.)
2.20 x 7.20 x 6.50
Shipping Dimensions (hwd / cm)
5.59 x 18.29 x 16.51
Shipping Weight (lbs.)
1.50
Shipping Weight (kg)
0.68
Unit Dimensions (hwd / in.)
1.100 x 4.500 x 2.500
Unit Dimensions (hwd / cm)
2.54 x 11.43 x 6.35
Unit Packaging Type
Box
Unit Weight (lbs.)
0.5
Unit Weight (kg)
0.23
Housing
Metal
ENVIRONMENTAL
Operating Temperature Range
32 to 122 F (0 to 50 C)
Storage Temperature Range
-4 to 158 (-20 to 70 C)
Relative Humidity
10% to 90% RH, Non-Condensing
COMMUNICATIONS
Max 1024 x 768 Range (ft)
1000
Max 480P Range (ft)
1000
Max 1440 x 900 Range (ft)
500
Max 1080i Range (ft)
500
3/5
Cleveland, OH 44122
United States
Max 1920 x 1440 Range (ft)
500
Max 480i Range (ft)
1000
Max 640 x 480 Range (ft)
1000
Max 800 x 600 Range (ft)
1000
Max 1600 x 1200 Range (ft)
500
EDID Compatible
Yes
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
No
USB Extension Support
No
CONNECTIONS
Number of Ports
1
Side A - Connector 1
RJ45 (FEMALE)
Side B - Connector 1
HD15 (FEMALE)
Side B - Connector 2
3.5MM (FEMALE)
Side B - Connector 3
RJ45 (FEMALE)
PORT EXPANSION
Daisy-chainable or Cascadable
Daisychainable
FEATURES & SPECIFICATIONS
Driver Required
No
10/100 Ethernet Extension Support
No
Built-In Equalizer
Yes
STANDARDS & COMPLIANCE
External Power Supply Certifications
FCC; PSE; TUV; UL; cUL
Product Compliance
RoHS; REACH; FCC (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
4/5
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
