B130-202
B130-202
    TRIPPLITE
    VGA+AUDIOOVERCAT5EXTENDER
B130-202 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1 x 4 VGA over Cat5/6 Extender Kit, Transmitter/Receiver for Video, 2 Local/2 Remote Displays, Up to 500 ft. (152 m) MODEL NUMBER: B130-202 Highlights ● Extends a VGA signal up to 500 ft. ● Connect up to four VGA monitors: 2 Local and 2 Remote ● EDID copy feature ensures optimal display compatibility System Requirements ● PC with VGA video output ● Monitors with VGA input Package Includes Features ● Connect up to 4 VGA monitors - 2 local and 2 remote ● Extends a 1440 x 900 @ 60Hz signal up to 165 ft. (50 m) from the source ● Extends a 1024 x 768 @ 60Hz signal up to 500 ft. (150 m) from the source ● EDID copy feature ensures optimal display compatibility ● Built-in equalization control allows for adjustment of the video image ● All operating systems supported ● Plug-and-play; no software or drivers are required ● HDCP compliant Specifications OVERVIEW UPC Code 037332182630 Product Type Extender Kit Technology VGA/SVGA; Cat5/5e; Cat6 Host Connector HD15 (FEMALE) VIDEO Max Supported Video Resolution 1440x900 @ 60Hz Max 720P Range (ft) 165 1/4 ● Transmitter Unit ● Receiver Unit ● (2) External Power Supplies with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A, 4.5 ft.) ● Screwdriver for equalization adjustment ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Max 1280 x 720 (720p) Range (ft) 165 Transmitter Video Input VGA Transmitter - Number of Video Outputs 2 Transmitter - Local Display Output VGA Receiver/Transceiver Video Output VGA Receiver - Number of Video Outputs 2 Range Extension using other Tripp Lite product 1000ft @ 1024 x 768 (60Hz) 500ft @ 1920 x 1440 (60Hz) Recommended Cabling Solid Wire Cat6 Cables (Tripp Lite's N202-Series) Other Tripp Lite product used to extend range B132-110A HDR Support No 3D Video Supported No Maximum Signal Range (ft) 500 Maximum Signal Range (m) 152 Maximum Signal Range Details 500 ft @ 1024 x 768 (60Hz)165 ft @ 1440 x 900 (60Hz) INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Input Specs (V / Hz / A) 100-240V / 50-60Hz / 0.5A External Power Supply Output Specs (V / A) 5V/2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.38 AC Plug Type NEMA 1-15P Power Source Transmitter and Receiver (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 4.5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators TX & RX: Red (Power); EDID (Orange); RJ45: Green (Connection), Orange (Data Transmission) 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Black Included Mounting Accessories Wallmount Number of Displays 4 Optional Mounting Accessory Notes Can DIN Mount using Tripp Lite Bracket  B110-DIN-01  Form Factor/Mounting Options Box; Wall-mount Receiver Unit Dimensions (hwd / in.) 4.53 x 1.06 x 2.46 Receiver Unit Weight (lbs.) 0.5 Shipping Dimensions (hwd / in.) 2.20 x 6.30 x 8.40 Shipping Dimensions (hwd / cm) 5.59 x 16.00 x 21.34 Shipping Weight (lbs.) 1.80 Shipping Weight (kg) 0.82 Transmitter Unit Dimensions (hwd / in.) 4.53 x 1.06 x 2.46 Transmitter Unit Weight (lbs.) 0.5 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) Transmitter: 2.69 x 11.43 x 6.2 Receiver: 2.69 x 11.43 x 6.2 Unit Packaging Type Box Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 122 F (0 to 50 C) Storage Temperature Range -4 to 158 (-20 to 70 C) Relative Humidity 10% to 90% RH, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 500 Max 480P Range (ft) 500 Max 1440 x 900 Range (ft) 165 Max 480i Range (ft) 500 Max 640 x 480 Range (ft) 500 Max 800 x 600 Range (ft) 500 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Consumer Electronics Control (CEC) Supported No USB Extension Support No CONNECTIONS Number of Ports 2 Side A - Connector 1 (3) HD15 (FEMALE) Side A - Connector 2 RJ45 (FEMALE) Side B - Connector 1 (2) HD15 (FEMALE) Side B - Connector 2 RJ45 (FEMALE) FEATURES & SPECIFICATIONS Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer Yes STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV; UL; cUL Product Compliance RoHS; REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B130-202 价格&库存
很抱歉,暂时无法提供与“B130-202”相匹配的价格&库存,您可以联系我们找货
