1000 Eaton Boulevard
Cleveland, OH 44122
United States
4-Port VGA over Cat5/6 Splitter/Extender, BoxStyle Transmitter for Video, Up to 1000 ft. (305
m), TAA
MODEL NUMBER: B132-004-2
Highlights
Splits a single VGA signal into 5
(1 local, 4 remote)
EDID copy feature ensures
optimal display compatibility
Extends a 1920 x 1440 (60Hz)
signal up to 500 ft., or a 1024 x
768 (60Hz) signal up to 1,000
ft., when using 24Awg, Solid
Wire Cat5e/6 cable, such as
Tripp Lite's N022-01K-GY
(Cat5) and N222-01K-GY (Cat6)
Can further expand the range
and number of monitors by
adding B132-110A (Video Only)
repeaters
For optimal image quality
between 500 and 1,000 ft., use
Zero-Skew cable, such as Tripp
Lite P524-01K
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
System Requirements
Features
Splits a single VGA signal into 5 (1 local, 4 remote)
Increase the number of displays to up to 25 (1 local, 24 remote) by daisychaining up to six B132-004-2
units together
A B132-100-1 or B132-100-WP-1 remote receiver unit is required for each connected monitor
Extends a 1920 x 1440 (60Hz) signal up to 500 ft., or a 1024 x 768 (60Hz) signal up to 1,000 ft., when
using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY
(Cat6)
Can further expand the range and number of monitors by adding B132-110A (Video Only) repeaters
EDID copy feature ensures optimal display compatibility
Connect up to 4 remote units in a repeater chain (3 repeaters and 1 receiver), with a monitor at each
location
A 1920 x 1440 (60Hz) signal can be extended up to 500 ft. from the first repeater in the chain to the last
receiver. A 1024 x 768 (60Hz) signal can be extended up to 1,000 ft. from the first repeater in the chain
to the last receiver.
For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P52401K
Includes mounting hardwarethat allows unit to be wallmounted, rackmounted or pole mounted.
Up to three B132-004-2 units can be mounted in 1U of rack space using a Tripp Lite B132-004-RB
Extender/Splitter 19 in. rackmount bracket
Ideal for digital signage situations, such as retail, schools, churches, etc.
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
1/5
Package Includes
4 Port Extender/Splitter local
(Transmitter) unit
1 ft. VGA daisychain cable
Mounting hardware
External Power Supply with
NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output:
5V, 2A, 5 ft.)
Owner's Manual
Cleveland, OH 44122
United States
UPC Code
037332178442
Product Type
Transceiver
Technology
VGA/SVGA; Cat5/5e; Cat6
Host Connector
HD15 (FEMALE)
VIDEO
Max Supported Video Resolution
1920x1440 @ 60Hz
Max 720P Range (ft)
500
Max 1080P Range (ft)
500
Max 1280 x 720 (720p) Range (ft)
500
Max 1920 x 1080 (1080p) Range (ft)
500
Max 1920 x 1200 Range (ft)
500
Transmitter Video Input
VGA
Transmitter - Number of Video
Outputs
4
Transmitter - Local Display Output
VGA
Range Extension using other Tripp
Lite product
1000ft @ 1024 x 768 (60Hz) 500ft @ 1920 x 1440 (60Hz)
Recommended Cabling
Solid Wire Cat6 Cables (Tripp Lite's N202-Series)
Other Tripp Lite product used to
extend range
B132-110A
HDR Support
No
3D Video Supported
No
Maximum Signal Range (ft)
1000
Maximum Signal Range (m)
305
Maximum Signal Range Details
1000 ft @ 1024 x 768 (60Hz)500 ft @ 1920 x 1440 (60Hz)
INPUT
Bus Powered
No
POWER
Power Source Type
AC Adapter
External Power Supply Plug(s)
NEMA 1-15P North America
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 0.5A
External Power Supply Output
Specs (V / A)
5V / 2A
External Power Supply Cord Length
(ft.)
4.5
2/5
Cleveland, OH 44122
United States
(m.)
1.38
AC Plug Type
NEMA 1-15P
Power Source
Unit (Included)
Power Over Cable (PoC) Support
No
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft.
DC Barrel Plug
OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
RJ45: Green (Connection), Orange (Data Transmission)
PHYSICAL
Color
Black
Included Mounting Accessories
Wallmount
Number of Displays
4
Optional Mounting Accessory Notes
Up to three transmitters local units can be mounted in 1U of rack space using a Tripp Lite B132-004RB Extender/Splitter 19in rackmount bracket Can DIN Mount using Tripp Lite Bracket B110-DIN-02
Form Factor/Mounting Options
Box; Wall-mount; Rackmount
Shipping Dimensions (hwd / in.)
2.20 x 6.20 x 10.20
Shipping Dimensions (hwd / cm)
5.59 x 15.75 x 25.91
Shipping Weight (lbs.)
1.80
Shipping Weight (kg)
0.82
Unit Dimensions (hwd / in.)
1.200 x 5.000 x 4.000
Unit Dimensions (hwd / cm)
3.05 x 13.46 x 9.91
Unit Packaging Type
Box
Unit Weight (lbs.)
0.85
Unit Weight (kg)
0.39
Housing
Metal
ENVIRONMENTAL
Operating Temperature Range
32 to 122 F (0 to 50 C)
Storage Temperature Range
-4 to 158 (-20 to 70 C)
Relative Humidity
10% to 90% RH, Non-Condensing
COMMUNICATIONS
Max 1024 x 768 Range (ft)
1000
3/5
Cleveland, OH 44122
United States
Max 480P Range (ft)
1000
Max 1440 x 900 Range (ft)
500
Max 1080i Range (ft)
500
Max 1920 x 1440 Range (ft)
500
Max 480i Range (ft)
1000
Max 640 x 480 Range (ft)
1000
Max 800 x 600 Range (ft)
1000
Max 1600 x 1200 Range (ft)
500
EDID Compatible
Yes
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
No
USB Extension Support
No
CONNECTIONS
Number of Ports
4
Side A - Connector 1
HD15 (FEMALE)
Side B - Connector 1
(4) RJ45 (FEMALE)
Side B - Connector 2
HD15 (FEMALE)
FEATURES & SPECIFICATIONS
Driver Required
No
10/100 Ethernet Extension Support
No
Built-In Equalizer
No
STANDARDS & COMPLIANCE
External Power Supply Certifications
FCC; PSE; TUV; UL; cUL
Product Compliance
RoHS; REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
4/5
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
