B122-000-60
B122-000-60
    TRIPPLITE
    EXTENDER60HZVIDEOHDMIF/F
B122-000-60 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Tripp Lite P568-Series HDMI cabling recommended for maximum distance and best performance and required for distances over 75 ft.Most installations are self powered. On the rare occasion where Highlights ● Allows you to store expensive source device in a secure location for controlled access ● Delivers HD picture quality at resolutions up to 1920 x 1200 (1080p) @ 60 Hz ● Supports DTS-HD, Dolby TrueHD and 7.1 surround sound for rich, clear audio ● Compact unit fits easily into briefcase or laptop bag for instant use anywhere ● Plug-and-play operation with no software required for easy, immediate installation additional power is needed, power can be added via a USB Micro-B port on the extender. Connect a USB Micro-B cable between the port and a USB wall charger, monitor or computer. Cable and charger not included. HDMI Signal Booster / Extender, 1920 x 1200 (1080p) 60Hz, Up to 125 ft. (38 m), (HDMI F/F), TAA MODEL NUMBER: B122-000-60 Applications ● Digital signage in office lobbies, churches, retail stores, restaurants and hotels ● Video presentations in conference rooms, lecture halls, classrooms and trade shows ● Home theater systems where the source devices are secured in a closet or other room System Requirements In-line HDMI signal extender boosts a high-quality HDMI audio/video transmission up to 125 ft. from the source device. ● Source device with HDMI output ● Display device with HDMI input ● 24 AWG HDMI cable required for distances over 75-ft. (22.86 m) (Tripp Lite P568-Series) Features HDMI Booster Extends High-Definition 1080p Video and Digital Audio Signals up to 125-ft. (38.1 m)Don't let HDMI's 16-ft. (4.88 m) distance limitation limit your audio/video application. This in-line HDMI signal extender boosts your 1080p transmission up to 125-ft. (38.1 m) from the source device without a drop in signal quality. This gives you the flexibility to hide your Blu-ray player or media server away in a secure, remote location for controlled access, while delivering video to an HDMI display somewhere else. The B122-000-60 is recommended for digital signs or video presentations in schools, conference rooms, retail displays, trade show booths and anywhere else you need to display high-definition video. Meets HDMI Industry Standards to Deliver High-Definition ResultsThis HDMI signal booster supports computer video resolutions up to 1920 x 1200 and HD resolutions up to 1080p at 60 Hz, as well as 36-bit Deep Color (12 bits per channel). It also supports DTS-HD, Dolby TrueHD and 7.1-channel surround sound to ensure your speakers deliver rich, clear audio to match the video quality. Greater Distance Gives You More Freedom in Placing Your Source and Display DevicesThis lowprofile HDMI booster is designed for use with Tripp Lite P568-Series HDMI cables (sold separately). Connect the longer cable (up to 125-ft. (38.1 m) to your source device, such as a Blu-ray player or computer, to transmit a 1080p (60 Hz) signal. The shorter cable connects the B122-000-60 and the HDMI display device, and must be no longer than 16-ft. (4.88 m). For distances over 75-ft. (22.86 m), a 24 AWG HDMI cable, such as Tripp Lite's P568-100-HD, is required. In addition, this unit can also extend a 3D signal up to 125-ft. (38.1 m) (24 AWG cable required for 3D transmissions over 50-ft. (15.24 m). Ready to Use Right from the Package, So You Can Plug and Play ImmediatelyThe plug-and-play unit requires no software, drivers or (usually) external power. In the extreme case that external power is needed, connect a USB Micro-B cable (such as Tripp Lite's UR050-Series) between the unit's USB Micro1/5 Package Includes ● B122-000-60 HDMI Signal Booster ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States B port and a USB wall charger or USB port on your monitor or computer. With its low-profile design, the B122-000-60 is easy to stow in your laptop bag and carry to school, the office or the latest trade show. TAA-Compliant for GSA Schedule PurchasesThe B122-000-60 is compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. 3-Year WarrantyThe B122-000-60 is backed by a 3-year warranty, ensuring reliability and performance. Specifications OVERVIEW UPC Code 037332160294 Product Type Signal Booster Technology HDMI VIDEO Video Input HDMI (FEMALE) Video Output HDMI (FEMALE) Number of Monitors Supported 1 Video Ports HDMI (FEMALE) Video Ports Details HDMI 2.0; HDCP 2.2 Resolutions Supported 1080p @ 60 Hz, up to 125-ft. Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 720P Range (ft) 150 Max 1080P Range (ft) 150 Max 1280 x 720 (720p) Range (ft) 125 Max 1920 x 1080 (1080p) Range (ft) 125 Recommended Cabling 24 AWG Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 125 Maximum Signal Range (m) 38 Maximum Signal Range Details Extend a 1080p @ 60Hz (1920 x 1200) HDMI signal up to 125 ft. from the source AUDIO Audio Ports HDMI (FEMALE) 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Audio Ports Details HDMI (Female) port allows for pass-through audio Audio Input HDMI Audio Output HDMI Audio Specification Pass-through audio INPUT Bus Powered No Product Length (in.) 2.362 Product Length (cm.) 6 Product Length (ft.) 0.197 Product Length (m.) 0.06 POWER Power Source Type USB Power Source Unit (Optional) Power Over Cable (PoC) Support No PHYSICAL Color Black Material of Construction Plastic Number of Displays 1 Form Factor/Mounting Options Box Shipping Dimensions (hwd / in.) 1.60 x 4.60 x 6.20 Shipping Dimensions (hwd / cm) 4.06 x 11.68 x 15.75 Shipping Weight (lbs.) 0.10 Shipping Weight (kg) 0.05 Unit Dimensions (hwd / in.) 2.360 x 0.600 x 1.020 Unit Packaging Type Box Unit Weight (lbs.) 0.03 Unit Weight (kg) 0.01 Housing Plastic ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85% RH, Non-Condensing 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States COMMUNICATIONS Max 1024 x 768 Range (ft) 150 Max 480P Range (ft) 154 Max 1440 x 900 Range (ft) 150 Max 1080i Range (ft) 150 Max 480i Range (ft) 154 Max 640 x 480 Range (ft) 150 Max 800 x 600 Range (ft) 150 Max 1600 x 1200 Range (ft) 150 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 HDMI (FEMALE) Side A - Connector 2 MICRO-USB B (FEMALE) Side B - Connector 1 HDMI (FEMALE) FEATURES & SPECIFICATIONS HDCP Specification 1.4 Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B122-000-60 价格&库存
很抱歉,暂时无法提供与“B122-000-60”相匹配的价格&库存,您可以联系我们找货
