B130-101-2
B130-101-2
    TRIPPLITE
    VGA OVER CAT5 EXTENDER KIT
B130-101-2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States VGA over Cat5/6 Extender Kit, Box-Style Transmitter/Receiver for Video, Up to 1000 ft. (305 m), TAA Highlights ● Extends a 1920 x 1440 (60Hz) video signal up to 500 ft., or a 1024 x 768 (60Hz) video signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N22201K-GY (Cat6) ● Can further expand the range and number of monitors by adding B132-110A (Video Only) repeaters ● EDID copy feature ensures optimal display compatibility For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P524-01K MODEL NUMBER: B130-101-2 ● ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases System Requirements Features Package Includes ● Extends a 1920 x 1440 (60Hz) video signal up to 500 ft., or a 1024 x 768 (60Hz) video signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6) ● EDID copy feature ensures optimal display compatibility ● ● ● A 1920 x 1440 (60Hz) signal can be extended up to 500 ft. from the first repeater in the chain to the last receiver. A 1024 x 768 (60Hz) signal can be extended up to 1,000 ft. from the first repeater in the chain to the last receiver. ● For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P52401K ● The remote (Receiver) unit features built-in Equalization and Gain controls to adjust the video image ● Includes mounting hardware for both local and remote units, allowing them to be wallmounted, rackmounted or pole mounted ● Ideal for digital signage situations, such as retail, schools, churches, etc. ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases ● Local (Transmitter) unit 1 x 4.5 x 2.5 (in.) ● Remote (Receiver) unit 1 x 2.5 x 3.5 (in.) Can further expand the range and number of monitors by adding B132-110A (Video Only) repeaters ● Connect up to 3 repeaters, with the B130-101-2 receiver at the end of the chain, for a total of 4 monitors. Mini-Screwdriver for EQ/Gain adjustment ● (x2) Mounting Hardware Kits ● (x2) External Power Supplies with NEMA 1-15P Plug(Input: 100-240V, 50/60Hz, 0.5A Output: 5V, 2A, 5 ft.) ● Owner's Manual Specifications OVERVIEW UPC Code 037332178367 Product Type Extender Kit Technology VGA/SVGA; Cat5/5e; Cat6 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States VIDEO Max Supported Video Resolution 1920x1440 @ 60Hz Max 720P Range (ft) 500 Max 1080P Range (ft) 500 Max 1280 x 720 (720p) Range (ft) 500 Max 1920 x 1080 (1080p) Range (ft) 500 Max 1920 x 1200 Range (ft) 500 Transmitter Video Input VGA Transmitter - Number of Video Outputs 1 Transmitter - Local Display Output VGA Receiver/Transceiver Video Output VGA Receiver - Number of Video Outputs 1 Range Extension using other Tripp Lite product 1000ft @ 1024 x 768 (60Hz) 500ft @ 1920 x 1440 (60Hz) Recommended Cabling Solid Wire Cat6 Cables (Tripp Lite's N202-Series) Other Tripp Lite product used to extend range B132-110A HDR Support No 3D Video Supported No Maximum Signal Range (ft) 1000 Maximum Signal Range (m) 305 Maximum Signal Range Details 1000 ft @ 1024 x 768 (60Hz)500 ft @ 1920 x 1440 (60Hz) INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.38 AC Plug Type NEMA 1-15P 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Power Source Transmitter and Receiver (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators TX & RX: Red (Power); RJ45: Green (Connection), Orange (Data Transmission) PHYSICAL Color Black Included Mounting Accessories Wallmount Number of Displays 1 Optional Mounting Accessory Notes Can DIN Mount using Tripp Lite Bracket  B110-DIN-01  and  B110-DIN02  Form Factor/Mounting Options Box; Wall-mount Receiver Unit Dimensions (hwd / in.) 2.53 x 3.61 x 1.01 Receiver Unit Weight (lbs.) 0.4 Shipping Dimensions (hwd / in.) 2.20 x 8.40 x 6.50 Shipping Dimensions (hwd / cm) 5.59 x 21.34 x 16.51 Shipping Weight (lbs.) 1.80 Shipping Weight (kg) 0.82 Transmitter Unit Dimensions (hwd / in.) 4.53 x 1.06 x 2.46 Transmitter Unit Weight (lbs.) 0.5 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Housing Metal ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Relative Humidity 10% to 90% RH, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 1000 Max 480P Range (ft) 1000 Max 1440 x 900 Range (ft) 500 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Max 1080i Range (ft) 500 Max 1920 x 1440 Range (ft) 500 Max 480i Range (ft) 1000 Max 640 x 480 Range (ft) 1000 Max 800 x 600 Range (ft) 1000 Max 1600 x 1200 Range (ft) 500 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported No USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 (2) HD15 (FEMALE) Side A - Connector 2 RJ45 (FEMALE) Side B - Connector 1 HD15 (FEMALE) Side B - Connector 2 RJ45 (FEMALE) FEATURES & SPECIFICATIONS Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer Yes STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; TUV; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B130-101-2 价格&库存
很抱歉,暂时无法提供与“B130-101-2”相匹配的价格&库存,您可以联系我们找货
