B125-150
B125-150
    TRIPPLITE
    HDMIEXTDRKITDUALCAT5/6150FT
B125-150 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States HDMI over Dual Cat5/6 Extender Kit, In-Line Transmitter/Receiver for Video/Audio, Up to 150 ft. (45 m) MODEL NUMBER: B125-150 Highlights ● Extends a 1080p @ 24Hz (or 1920 x 1200) signal up to 150-ft. (45.72 m) using 24Awg, Solid Wire Cat6* cabling (Tripp Lite N202-Series) ● Extends a 3D signal up to 125ft. (38.1 m) using 24Awg, Solid Wire Cat6* cabling (Tripp Lite N202-Series) ● Supports 24-bit True Color (8bits per channel) ● Supports DTS-HD, Dolby True HD and 7.1 Channel Surround Sound Audio ● Supports HDCP, EDID and DDC Package Includes ● HDMI Extender Local Transmitter Unit ● HDMI Extender Remote Receiver Unit ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.4A; Output: 9V, 1.5A, 4.5-ft. (1.37 m) ● Owner's Manual Transmit a HDMI signal up to 150ft, 1080p @ 24Hz using two Cat6 patch cables. Description Tripp Lite's HDMI Over Dual Cat5 Extender Kit is the perfect solution for those who need to extend a HDMI signal over a long distance over two Cat5/6 cables. ● When using 24Awg, Solid Wire Cat6 cable, a 1080p @ 24Hz (or 1920 x 1200) signal can be extended up to 150-ft. (45.72 m) from the source. ● When using 24Awg, Solid Wire Cat6 cable, a 3D signal can be extended up to 125-ft. (38.1 m) ● When using 24Awg, Solid Wire Cat5 cable, a 1080p @ 24Hz (or 1920 x 1200) signal can be extended up to 100-ft. (30.5 m) from the source. ● When using 24Awg, Solid Wire Cat5 cable, a 3D signal can be extended up to 75-ft. (22.86 m) Simply run two Cat5/6 cables between the local transmitter and remote receiver units, and plug in standard Tripp Lite HDMI cables to the HDMI source and the display. The B125-150 comes with both local transmitter and remote receiver units. DTS-HD, Dolby True HD and 7.1 Channel Surround Sound audio are supported, and it is compliant with HDCP, EDID and DDC. 24-bit True Color (8-bits per channel) is supported. Features ● Extends a 1080p @ 24Hz (or 1920 x 1200) signal up to 150-ft. (45.72 m) using 24Awg, Solid Wire Cat6 cabling (Tripp Lite N202-Series) ● Extends a 1080p @ 24Hz (or 1920 x 1200) signal up to 100-ft. (30.5 m) using 24Awg, Solid Wire Cat5 cabling ● Extends a 3D signal up to 125-ft. (38.1 m) using 24Awg, Solid Wire Cat6 cabling, or up to 75-ft. (22.86 m) using 24Awg, Solid Wire Cat5 cabling ● Supports DTS-HD, Dolby True HD and 7.1 Channel Surround Sound Audio ● Supports HDCP, EDID and DDC ● Supports 24-bit True Color (8-bits per channel) ● Use Tripp Lite P568-Series HDMI cables to connect to HDMI source and monitor ● Supports Lip-Sync Pass Through, and CEC pass through ● Green LED on the remote unit will illuminate to indicate that power is being received 1/5 1000 Eaton Boulevard Cleveland, OH 44122 United States ● The Red LED on the remote unit will illuminate only if a working signal is NOT being received. The unit is functioning properly when the Red LED is not illuminated Specifications OVERVIEW UPC Code 037332143723 Product Type Extender Kit Technology HDMI; Cat5/5e; Cat6 VIDEO Video Input HDMI (FEMALE) Video Output HDMI (FEMALE) Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 720P Range (ft) 150 Max 1080P Range (ft) 150 Max 1280 x 720 (720p) Range (ft) 195 Max 1920 x 1080 (1080p) Range (ft) 115 Transmitter Video Input HDMI Transmitter - Number of Video Outputs 1 Receiver/Transceiver Video Output HDMI Receiver - Number of Video Outputs 1 Recommended Cabling N202-Series Cat6 Patch Cable Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 Maximum Signal Range (ft) 150 Maximum Signal Range (m) 46 Maximum Signal Range Details 230 ft via Cat6 @ 480p197 ft via Cat6 @ 720p115 ft via Cat6 @ 1080p AUDIO Audio Input HDMI Audio Output HDMI Audio Specification Pass-through audio 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.38 AC Plug Type NEMA 1-15P Power Source Receiver end only (Included) Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.4A; Output: 9V, 1.5A, 4.5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators Power (Green), Signal (Red) PHYSICAL Color Black Number of Displays 1 Form Factor/Mounting Options Box Receiver Unit Dimensions (hwd / in.) 2.45 x 1.85 x 0.85 Receiver Unit Weight (lbs.) 0.06 Shipping Dimensions (hwd / in.) 7.20 x 6.40 x 2.20 Shipping Dimensions (hwd / cm) 18.29 x 16.26 x 5.59 Shipping Weight (lbs.) 0.80 Shipping Weight (kg) 0.36 Transmitter Unit Dimensions (hwd / in.) 2.45 x 1.85 x 0.85 Transmitter Unit Weight (lbs.) 0.06 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) Source Unit: 2.375"W x 1.75"D x 0.75"H 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Packaging Type Box Housing Plastic ENVIRONMENTAL Operating Temperature Range 32 to 104 °F (0 to 40 °C) Storage Temperature Range 5 to 122 °F (-15 to 50 °C) Relative Humidity 0% to 85% RH, Non-Condensing COMMUNICATIONS Max 1024 x 768 Range (ft) 150 Max 480P Range (ft) 150 Max 1440 x 900 Range (ft) 150 Max 1080i Range (ft) 150 Max 480i Range (ft) 150 Max 640 x 480 Range (ft) 150 Max 800 x 600 Range (ft) 150 Max 1600 x 1200 Range (ft) 150 EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 HDMI (FEMALE) Side A - Connector 2 (2) RJ45 (FEMALE) Side B - Connector 1 HDMI (FEMALE) Side B - Connector 2 (2) RJ45 (FEMALE) FEATURES & SPECIFICATIONS HDCP Specification 1.4 Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States External Power Supply Certifications FCC; PSE; TUV; UL; cUL Product Compliance RoHS; REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B125-150 价格&库存
很抱歉,暂时无法提供与“B125-150”相匹配的价格&库存,您可以联系我们找货
