B130-101S-WP
B130-101S-WP
    TRIPPLITE
    EXTENDER WALL TRANSMITTER REC
B130-101S-WP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States VGA with RS232 over Cat5/Cat6 Extender Kit, Wallplate Transmitter and Receiver, 1920x1440 at 60Hz, Up to 1000-ft. Highlights ● Extends a 1920 x 1440 (60Hz) Video and RS232 Serial signal up to 500 ft., or a 1024 x 768 (60Hz) Video and RS232 Serial signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6) ● For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P524-01K ● Connections for optional local monitor ● Wallplate style Transmitter & Receiver for clean installation MODEL NUMBER: B130-101S-WP System Requirements ● Computer with VGA video output connector and DB9 Male RS232 output ● Monitor(s) with VGA input ● Serial device with DB9 connection Description Tripp Lite's B130-101S-WP allows you to extend a 1920 x 1440 (60Hz) Video and RS232 Serial signal up Package Includes to 500 ft., or a 1024 x 768 (60Hz) Video and RS232 Serial signal up to 1,000 ft., when using 24Awg, Solid ● Local Wallplate Unit Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6). For optimal ● Remote Wallplate Unit image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P524-01K. Kit includes ● "Y" VGA cable a Wallplate style Transmitter and Receiver. A "Y" cable is included for use at the computer to allow a local ● DB9M to 3.5mm plug Serial cable ( Remote serial connection ) ● DB9F to 3.5mm plug Serial cable ( Local serial connection ) ● Owners Manual ● Screwdriver ● 110 Punch Down tool ● 2 x External Power Supply with NEMA 1-15P Plug (5-15P Plug), Input: 100-240V, 50/60Hz, 0.4A, Output: +5V, 2A monitor to be attached. Ideal for digital signage situations, such as retail, schools, church, etc, as well as serial POS. Remote unit contains Equalization length ( EQ ) and Brightness ( Gain ) adjustment screws for crystal clear images...small screwdriver is included with the unit. Cat5e/Cat6 Solid conductor cable recommended. Features ● Extends a 1920 x 1440 (60Hz) Video and RS232 Serial signal up to 500 ft., or a 1024 x 768 (60Hz) Video and RS232 Serial signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6) ● For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P52401K ● Connections for optional local monitor ( "Y" Cable ) ● Wallplate style Transmitter & Receiver for clean installation ● 110 Punchdown Tool, and Screwdriver to adjust Gain and Brightness, included ● Secure, screw down power connection on wallplates ● Works with: Monitors, Projectors, HDTV's, Flat panels, and any type of Serial Device Specifications 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332151858 Product Type Cat5/Cat6 Extender Kit Technology VGA/SVGA VIDEO Maximum Signal Range (ft) 1000 Maximum Signal Range (m) 305 POWER AC Adapter Input: 100-240V, 50/60Hz, 0.4A; Output: 5V, 2A, 5 ft. PHYSICAL Color White Shipping Dimensions (hwd / in.) 2.25 x 8.00 x 9.30 Shipping Dimensions (hwd / cm) 5.72 x 20.32 x 23.62 Shipping Weight (lbs.) 1.70 Shipping Weight (kg) 0.77 CONNECTIONS Number of Ports 1 Side A - Connector 1 HD15 (FEMALE) Side A - Connector 2 110 IDC Side A - Connector 3 DB9 (FEMALE) Side B - Connector 1 HD15 (FEMALE) Side B - Connector 2 110 IDC Side B - Connector 3 DB9 (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B130-101S-WP 价格&库存
很抱歉,暂时无法提供与“B130-101S-WP”相匹配的价格&库存,您可以联系我们找货
