1000 Eaton Boulevard
Cleveland, OH 44122
United States
VGA with Audio over Cat5/Cat6 Extender Kit,
Wallplate Transmitter and Receiver with EDID,
1920x1440 at 60Hz, Up to 1000-ft.
Highlights
Extends a 1920 x 1440 (60Hz)
Video and Audio signal up to
500 ft., or a 1024 x 768 (60Hz)
1,000 ft., when using 24Awg,
Solid Wire Cat5e/6 cable, such
as Tripp Lite's N022-01K-GY
(Cat5) and N222-01K-GY (Cat6)
For optimal image quality
between 500 and 1,000 ft., use
Zero-Skew cable, such as Tripp
Lite P524-01K
RJ45 type wallplates allow you
to use standard patch cable,
eliminating the need for a 110
punchdown connection
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
MODEL NUMBER: B130-101A-WP-1
Package Includes
Description
Local (Transmitter) wallplate
Remote (Receiver) wallplate
VGA + Audio "Y" cable
Mini-Screwdriver for EQ/Gain
adjustment
Wallplate Screws
(x2) External Power Supply
(Input: 100-240V, 50/60Hz, 0.5A
Output: 5V, 2A)
Owner's Manual
Tripp Lite's B130-101A-WP-1 allows you to extend a 1920 x 1440 (60Hz) Video and Audio signal up to
500 ft., or a 1024 x 768 (60Hz) Video and Audio signal up to 1,000 ft., when using 24Awg, Solid Wire
Cat5e/6 cable, such as Tripp Lite's N022-01K-GY (Cat5) and N222-01K-GY (Cat6). For optimal image
quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P524-01K. A maximum
resolution of 1920 x 1440 (60Hz) is supported. The remote (Receiver) unit features built-in Equalization
and Gain controls to adjust the video image. Kit includes local (Transmitter) and remote (Receiver) RJ45
type wallplates, which allow you to use standard patch cable, eliminating the need for a 110 punchdown
connection. A VGA + Audio "Y" cable is included for use with the local unit, allowing for the connection of
a local monitor and speakers. Ideal for digital signage situations, such as retail, schools, churches, etc.
Features
Extends a 1920 x 1440 (60Hz) Video and Audio signal up to 500 ft., or a 1024 x 768 (60Hz) Video and
Audio signal up to 1,000 ft., when using 24Awg, Solid Wire Cat5e/6 cable, such as Tripp Lite's N02201K-GY (Cat5) and N222-01K-GY (Cat6)
For optimal image quality between 500 and 1,000 ft., use Zero-Skew cable, such as Tripp Lite P52401K
A VGA + Audio "Y" cable is included for use with the local unit, allowing for the connection of a local
RJ45 type wallplates allow you to use standard patch cable, eliminating the need for a 110 punchdown
connection
The remote (Receiver) unit features built-in Equalization and Gain controls to adjust the video image
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
1/3
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332160188
Product Type
Technology
VGA/SVGA; Stereo Audio
VIDEO
Max 720P Range (ft)
500
Max 1080P Range (ft)
500
Max 1920 x 1200 Range (ft)
500
Maximum Signal Range (ft)
1000
Maximum Signal Range (m)
305
PHYSICAL
Color
White
Shipping Dimensions (hwd / in.)
6.30 x 2.25 x 10.10
Shipping Dimensions (hwd / cm)
16.00 x 5.72 x 25.65
Shipping Weight (lbs.)
1.00
Shipping Weight (kg)
0.45
COMMUNICATIONS
Max 1024 x 768 Range (ft)
1000
Max 480P Range (ft)
1000
Max 1440 x 900 Range (ft)
500
Max 1080i Range (ft)
500
Max 1920 x 1440 Range (ft)
500
Max 480i Range (ft)
1000
Max 640 x 480 Range (ft)
1000
Max 800 x 600 Range (ft)
1000
Max 1600 x 1200 Range (ft)
500
CONNECTIONS
Number of Ports
1
Side A - Connector 1
HD15 (FEMALE)
Side A - Connector 2
RJ45 (FEMALE)
Side A - Connector 3
3.5MM (FEMALE)
Side B - Connector 1
HD15 (FEMALE)
2/3
Cleveland, OH 44122
United States
Side B - Connector 2
3.5MM (FEMALE)
Side B - Connector 3
RJ45 (FEMALE)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
