B118-008-UHD
B118-008-UHD
    TRIPPLITE
    8-PORTHIGHSPEEDHDMISPLITTER
B118-008-UHD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 8-Port HDMI Splitter - 4K, HDCP 1.3 Highlights ● Supports UHD resolutions up to 4K @ 30 Hz for crystal-clear video ● Supports DTS-HD, Dolby True HD, Dolby Digital Plus and LPCM 7.1-channel surround sound ● Expand the number of connected displays, up to 512, by cascading up to 3 levels ● Plug-and-play operation with no software required for easy, immediate installation ● Power supply includes international plug adapters (North America, Europe, UK and Australia) MODEL NUMBER: B118-008-UHD Package Includes ● B118-008-UHD 4K x 2K HDMI 8-Port Splitter ● External Power Supply (Input: 100-240V, 50/60Hz, 0.6A; Output: 5V, 3A, 5 ft.) ● International plug adapters (North America, Europe, UK and Australia) ● Owner’s Manual Transmit a 4K HDMI signal from a single source to 8 displays. Description Tripp Lite's B118-008-UHD HDMI Splitter allows the 4K signal from a Blu-Ray player or other HDMI source device to be displayed on up to eight HDMI displays. You can also connect a DVI-D single-link display using an HDMI to DVI adapter, such as Tripp Lite's P566-Series. Installation is quick and simple with no software or drivers to install. Locate your HDMI source up to 16.4 feet (5 meters) from the splitter and the splitter up to 23 feet (7 meters) from the display for a maximum distance of 39.4 feet (12 meters) between splitter and display. Supports Full 3D and video resolutions up to 4K at 30 Hz (3840 x 2160). HDMI and 3D compliant with support for 36-bit Deep Color (12 bits per channel). Supports DTS-HD, Dolby True HD, Dolby Digital Plus and LPCM 7.1-channel surround sound audio. HDCP and EDID compliant. Note: The B118-008-UHD sends the same image to all connected displays. If you would like to extend an image over multiple displays, you will need an MST hub, such as the B156-002-HD-V2. Features ● Simultaneously transmit the video and audio from an HDMI source to multiple HDMI monitors ● Supports UHD resolutions up to 4K @ 30 Hz for crystal-clear video (3840 x 2160) ● Supports 36-bit Deep Color (12 bits per channel) ● Supports DTS-HD, Dolby True HD, Dolby Digital Plus and LPCM 7.1-channel surround sound ● Supports video amplifier bandwidth of 340 MHz / 3.4 Gbps per channel (10.2 Gbps total) ● HDCP and EDID compatible ● Plug-and-play operation with no software required for easy, immediate installation ● Supports Lip Sync pass-through ● Supports xvYCC and x.vColor ● Supports the use of DVI sources and displays with the use of an optional DVI to HDMI adapter (sold separately) ● Supports a maximum distance of 16.4 ft. (5 m) from source to splitter and 23 ft. (7 m) from splitter to display for a total of up to 39.4 ft. (12 m) ● Cascade up to 3 levels of splitters together to increase the number of connected monitors up to 512. ● Power Supply includes international plug adapters (North America, Europe, UK and Australia) Specifications 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332183903 Technology HDMI Host Connector HDMI (FEMALE) VIDEO Max Supported Video Resolution 4K @ 30Hz (3840 x 2160) Max. Distance (Between any 2 Units) 10ft (3m) Max Number of Ports (Entire Chain) 512 Max Supported Color Depth 36-bit Deep Color 3D Video Supported Yes AUDIO Audio Specification DTS-HD, Dolby TrueHD, Dolby Digital Plus and LPCM 7.1 Channel Surround Sound INPUT Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Bus Powered No Product Length (in.) 10.157 Product Length (ft.) 0.846 POWER Power Source Type AC Adapter External Power Supply Plug(s) AS/NZS 3112 Australia; BS 1363 UK; CEE 7/16 Schuko; NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.6A External Power Supply Output Specs (V / A) 5V / 3A External Power Supply Cord Length (ft.) 5 External Power Supply Cord Length (m.) 1.5 AC Adapter Input: 100-240V, 50/60Hz, 0.6A; Output: 5V, 3A, 5 ft. DC Barrel Plug OD: 5.5 x 2.1 x 10mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 8.5 USER INTERFACE, ALERTS & CONTROLS LED Indicators Red (Power), (x8) Blue (Connection) 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Black Material of Construction Metal Rackmountable Yes Shipping Dimensions (hwd / in.) 2.70 x 10.10 x 12.80 Shipping Dimensions (hwd / cm) 6.86 x 25.65 x 32.51 Shipping Weight (lbs.) 2.70 Shipping Weight (kg) 1.22 Unit Dimensions (hwd / in.) 1.000 x 10.200 x 4.500 Unit Packaging Type Box Unit Weight (lbs.) 1.6 Unit Weight (kg) 0.73 ENVIRONMENTAL Operating Temperature Range 32 to 158 °F (0 to 70 °C) Storage Temperature Range 14 to 176 °F (-10 to 80 °C) BTUs 29 BTU/Hr Operating Humidity Range 10% to 85 % RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes CONNECTIONS Number of Ports 8 Side A - Connector 1 HDMI (FEMALE) Side B - Connector 1 (8) HDMI (FEMALE) PORT EXPANSION Daisy-chainable or Cascadable Cascadable FEATURES & SPECIFICATIONS HDCP Specification 1.3 Driver Required No STANDARDS & COMPLIANCE External Power Supply Certifications CB; CE; DOE; FCC; GS; UL; cUL 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B118-008-UHD 价格&库存
很抱歉,暂时无法提供与“B118-008-UHD”相匹配的价格&库存,您可以联系我们找货
