B136-004
B136-004
    TRIPPLITE
    VIDEO/AUDIOEXTDR/SPLITTER700FT
B136-004 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port Component Video + Stereo Audio over Cat5/Cat6 Extender Splitter, Box-Style Transmitter, Up to 700 ft. (213 m), TAA Highlights ● Splits a single Component Video and Stereo Audio signal into five (1 local, 4 remote) ● Extends a 1080i (60Hz) Component Video and Stereo Audio signal up to 300-ft. (91.44 m) when using 24Awg, Solid Wire UTP cable (Tripp Lite N202-Series); or, up to 400-ft. (121.92 m) when using ZeroSkew UTP cable (Tripp Lite P524-01K) ● Connect up to 13 displays (1 local, 12 remote) by daisychaining 3 B136-004 units together ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B136-004 System Requirements Package Includes Description Tripp Lite's B136-004 takes a single Component Video and Stereo Audio signal and splits it to five (1 local, 4 remote). When used in conjunction with a B136-100 remote unit, you can transmit a Component Video ( YPbPr ) and Stereo Audio signal from any DVD player, PS3, or Cable/Satellite device to up to four displays over a single CAT5, CAT5E, or CAT6 cable. A 1080i (60Hz) Component Video and Stereo Audio signal can be extended up to 300-ft. (91.44 m) when using 24Awg, Solid Wire UTP cable (Tripp Lite N202Series); or, up to 400-ft. (121.92 m) when using Zero-Skew UTP cable (Tripp Lite P524-01K). A 480p (60Hz) Component Video and Stereo Audio signal can be extended up to 500-ft. (152.4 m) when using 24Awg, Solid Wire UTP cable (Tripp Lite N202-Series); or, up to 700-ft. (213.36 m) when using Zero-Skew UTP cable (Tripp Lite P524-01K). The number of displays can be increased to up to 13 (1 local, 12 remote) by daisychaining 3 B136-004 units together. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Features ● Splits a single Component Video and Stereo Audio signal into five (1 local, 4 remote) ● Features an extra set of Component Video and Stereo Audio connectors for an optional local display ● Works in conjunction with a B136-100 remote unit ● A 1080i (60Hz) Component Video and Stereo Audio signal can be extended up to 300-ft. (91.44 m) when using 24Awg, Solid Wire UTP cable (Tripp Lite N202-Series); or, up to 400-ft. (121.92 m) when using Zero-Skew UTP cable (Tripp Lite P524-01K) ● A 480p (60Hz) Component Video and Stereo Audio signal can be extended up to 500-ft. (152.4 m) when using 24Awg, Solid Wire UTP cable (Tripp Lite N202-Series); or, up to 700-ft. (213.36 m) when using Zero-Skew UTP cable (Tripp Lite P524-01K) ● Connect up to 13 displays (1 local, 12 remote) by cascading 3 B136-004 units together ● Includes a 1 ft. Component Video + Stereo Audio daisychain cable ● Up to 3 B136-004 units can be mounted in 1U of rack space when using a B132-004-RB Extender/Splitter 19 in. rackmount bracket ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications 1/3 ● B136-004 4-Port Component Video + Stereo Audio Extender/Splitter ● External Power Supply with NEMA 1-15P Plug ( Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5-ft. (1.52 m) ● 1-ft. (0.31 m) Component Video + Stereo Audio Source / Daisychain cable ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332155559 Product Type Transceiver Technology Component; Stereo Audio; Cat5/5e; Cat6 Host Connector (5) RCA (FEMALE) VIDEO Max 720P Range (ft) 400 HDR Support No 3D Video Supported No Maximum Signal Range (ft) 700 Maximum Signal Range (m) 213 INPUT Bus Powered No POWER Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 5 ft. PHYSICAL Color Black Included Mounting Accessories Wallmount Number of Displays 4 Optional Mounting Accessory Notes Up to three transmitters local units can be mounted in 1U of rack space using a Tripp Lite  B132-004RB  Extender/Splitter 19in rackmount bracket Form Factor/Mounting Options Box; Wall-mount; Rackmount Shipping Dimensions (hwd / in.) 2.20 x 8.40 x 0.50 Shipping Dimensions (hwd / cm) 5.59 x 21.34 x 1.27 Shipping Weight (lbs.) 1.90 Shipping Weight (kg) 0.86 Unit Dimensions (hwd / in.) 1.100 x 5.000 x 4.000 Unit Dimensions (hwd / cm) 2.79 x 12.7 x 10.16 Unit Weight (lbs.) 1.1 Unit Weight (kg) 0.50 COMMUNICATIONS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Max 1024 x 768 Range (ft) 700 Max 480P Range (ft) 700 Max 1440 x 900 Range (ft) 400 Max 1080i Range (ft) 400 Max 480i Range (ft) 700 Max 640 x 480 Range (ft) 700 Max 800 x 600 Range (ft) 700 Max 1600 x 1200 Range (ft) 400 EDID Compatible No IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported No USB Extension Support No CONNECTIONS Number of Ports 4 Side A - Connector 1 (5) RCA (FEMALE) Side A - Connector 2 (5) RCA (FEMALE) Side B - Connector 1 (4) RJ45 (FEMALE) FEATURES & SPECIFICATIONS Driver Required No 10/100 Ethernet Extension Support No Built-In Equalizer No WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
B136-004 价格&库存
很抱歉,暂时无法提供与“B136-004”相匹配的价格&库存,您可以联系我们找货
