1000 Eaton Boulevard
Cleveland, OH 44122
United States
VGA with Audio over Cat5/Cat6 Extender Kit,
Transmitter & Receiver with EDID, 2 Local/2
Remote Displays, 1440x900, Up to 500 ft. (152 m)
MODEL NUMBER: B130-202A
Highlights
Extends a VGA + Stereo Audio
signal up to 500 ft.
Connect up to four VGA
monitors: 2 Local and 2 Remote
EDID copy feature ensures
optimal display compatibility
System Requirements
PC with VGA video output and
3.5mm Stereo output
Monitors with VGA input;
speakers with 3.5mm Stereo
input
Package Includes
Features
Connect up to 4 monitors - 2 local and 2 remote
3.5mm Stereo audio support and extension
Extends a 1440 x 900 @ 60Hz signal up to 165 ft. (50 m) from the source
Extends a 1024 x 768 @ 60Hz signal up to 500 ft. (150 m) from the source
EDID copy feature ensures optimal display compatibility
Built-in equalization control allows for adjustment of the video image
All operating systems are supported
Plug-and-play; no software or drivers are required
HDCP compliant
Specifications
OVERVIEW
UPC Code
037332182647
Product Type
Extender Kit
Technology
VGA/SVGA; Stereo Audio; Cat5/5e; Cat6
Host Connector
HD15 (FEMALE)
VIDEO
Max Supported Video Resolution
1440x900 @ 60Hz
Max 720P Range (ft)
165
1/4
Transmitter Unit
Receiver Unit
(2) External Power Supplies with
NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A Output:
5V, 2A, 4.5 ft.)
Screwdriver for equalization
adjustment
Owner’s manual
Cleveland, OH 44122
United States
Max 1280 x 720 (720p) Range (ft)
165
Transmitter Video Input
VGA
Transmitter - Number of Video
Outputs
2
Transmitter - Local Display Output
VGA
Receiver/Transceiver Video Output
VGA
Receiver - Number of Video Outputs
2
Range Extension using other Tripp
Lite product
1000ft @ 1024 x 768 (60Hz) 500ft @ 1920 x 1440 (60Hz)
Recommended Cabling
Solid Wire Cat6 Cables (Tripp Lite's N202-Series)
Other Tripp Lite product used to
extend range
B132-110A
HDR Support
No
3D Video Supported
No
Maximum Signal Range (ft)
500
Maximum Signal Range (m)
152
Maximum Signal Range Details
500 ft @ 1024 x 768 (60Hz)165 ft @ 1440 x 900 (60Hz)
AUDIO
Audio Input
3.5mm
Audio Output
3.5mm
Audio Specification
Stereo Audio
INPUT
Bus Powered
No
POWER
Power Source Type
AC Adapter
External Power Supply Plug(s)
NEMA 1-15P North America
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 0.5A
External Power Supply Output
Specs (V / A)
5V / 2A
External Power Supply Cord Length
(ft.)
4.5
(m.)
1.38
AC Plug Type
NEMA 1-15P
Power Source
Transmitter and Receiver (Included)
Power Over Cable (PoC) Support
No
2/4
Cleveland, OH 44122
United States
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 4.5 ft.
DC Barrel Plug
OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
TX & RX: Red (Power); EDID (Orange); RJ45: Green (Connection), Orange (Data Transmission)
PHYSICAL
Color
Black
Included Mounting Accessories
Wallmount
Number of Displays
4
Optional Mounting Accessory Notes
Can DIN Mount using Tripp Lite Bracket B110-DIN-01
Form Factor/Mounting Options
Box; Wall-mount
Receiver Unit Dimensions (hwd / in.)
4.53 x 1.06 x 2.46
Receiver Unit Weight (lbs.)
0.5
Shipping Dimensions (hwd / in.)
2.20 x 6.20 x 8.40
Shipping Dimensions (hwd / cm)
5.59 x 15.75 x 21.34
Shipping Weight (lbs.)
1.70
Shipping Weight (kg)
0.77
Transmitter Unit Dimensions (hwd /
in.)
4.53 x 1.06 x 2.46
Transmitter Unit Weight (lbs.)
0.5
0.000 x 0.000 x 0.000
Unit Dimensions (hwd / cm)
Transmitter: 2.69 x 11.43 x 6.2 Receiver: 2.69 x 11.43 x 6.2
Unit Packaging Type
Box
Housing
Metal
ENVIRONMENTAL
Operating Temperature Range
32 to 122 F (0 to 50 C)
Storage Temperature Range
-4 to 158 (-20 to 70 C)
Relative Humidity
10% to 90% RH, Non-Condensing
COMMUNICATIONS
Max 1024 x 768 Range (ft)
500
Max 480P Range (ft)
500
Max 1440 x 900 Range (ft)
165
Max 480i Range (ft)
500
Max 640 x 480 Range (ft)
500
3/4
Cleveland, OH 44122
United States
Max 800 x 600 Range (ft)
500
EDID Compatible
Yes
IR Remote Extension Support
No
RS-232 Serial Extension Support
No
Consumer Electronics Control (CEC)
Supported
No
USB Extension Support
No
CONNECTIONS
Number of Ports
2
Side A - Connector 1
(3) HD15 (FEMALE)
Side A - Connector 2
RJ45 (FEMALE)
Side A - Connector 3
3.5MM (FEMALE)
Side B - Connector 1
(2) HD15 (FEMALE)
Side B - Connector 2
RJ45 (FEMALE)
Side B - Connector 3
3.5MM (FEMALE)
FEATURES & SPECIFICATIONS
Driver Required
No
10/100 Ethernet Extension Support
No
Built-In Equalizer
Yes
STANDARDS & COMPLIANCE
External Power Supply Certifications
FCC; PSE; TUV; UL; cUL
Product Compliance
RoHS; REACH; FCC (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“B130-202A”相匹配的价格&库存,您可以联系我们找货
